25371165
The IB firmware upgrade is not supported in the BUI.
When running firmware 2.2, the BUI in the firmware upgrade does
not work. The BUI also does not work for upgrades and downgrades
between 2.2 firmware versions or downgrades to the 2.1 firmware.
However, the BUI in the firmware upgrade from 2.1 to 2.2
works.
Workaround: Use the ILOM CLI
upgrade and downgrade tool as a workaround.
25219512
The /conf/lag.conf file gets deleted when
upgrading the firmware from 2.1.6 to 2.2.2.
When upgrading from firmware 2.1 to 2.2.2 or 2.2.4, LAGs are not
preserved and need to be recreated. This issue was fixed in firmware
version 2.2.5, so you will not experience this issue when you
upgrade from 2.1 to 2.2.5 (or later).
Workaround:
Step 1. Prior to the upgrade from 2.1.x, perform the
following:
The output of these commands have all the required information for
recreating the LAGs after the firmware upgrade to 2.2.2 or
2.2.4.
Step 2. After the upgrade to 2.2.2 or 2.2.4 from 2.1.x, perform
the following:
Step a. To recreate the LAGs, use the command
createlag for the LAGs in Step
1b,with the parameters from the output in Step 1a.
0xffff is default for Discover PKey
NA is default for data SL
static (i.e. no LACP) is default for LACP
1k is default for VNIC limit and Default is
default for Pkey
If the showlag command in Step 1a shows
the use of the default values for a LAG,only the LAG name
and the connectors need to be provided as parameters for the
createlag command.
Step b. Reboot the NM2 GW to enable the VLANs and VNICs on
top of the LAGs.
24665004
The default location for the toolbox config files
(cli and fabric
conf) are not correct.
The default location for the toolbox config files are not in the
config directory, so if using this default location, future firmware
updates will overwrite the configuration and the user will need to
re-enter the configuration.
Workaround: Do not use the
default location for the toolbox config files, instead specify the
location that will be used for future firmware versions, which is
/config/conf/ using the toolbox
CLI.
18129290
smpartition command fails from firmware version
2.0 switch with firmware version 2.1 or 2.2 peer.
In a mixed firmware fabric where the master Subnet Manager is on a
gateway with firmware version 2.0 and other gateways or switches in
the fabric are firmware version 2.1 or 2.2, issuing the
smpartition commit command fails.
Workaround: When you use the
smpartition commands to partition the mixed
firmware fabric, issue the commands from a master Subnet Manager on
a switch or gateway with firmware version 2.1 or 2.2.
17159243
VNICs with MAC addresses having eight leading zeros are disabled
after a reboot.
VNICs with MAC addresses having four or more leading bytes which
are zero (00:00:00:00:12:34) are not persistent after a reboot,
including reboots that occur during a firmware downgrade or
upgrade.
Workaround: Do not create VNICs
with MAC addresses having four or more leading bytes which are zero
(eight or more leading zeros).
15703751
No way to set Fabric Monitor console timeout.
The Fabric Monitor will timeout after 15 minutes of idle
time.
Workaround: You must log in to
the web interface and start the Fabric Monitor again.
