door_create - create a door descriptor
#include <door.h>
int door_create(void (*server_procedure) (void *cookie, char *argp,
size_t arg_size, door_desc_t *dp, uint_t n_desc), void *cookie,
uint_t attributes);
The door_create() function creates a door descriptor that describes the procedure specified by the function server_procedure. The data item, cookie, is associated with the door descriptor, and is passed as an argument to the invoked function server_procedure during door_call(3C) invocations. Other arguments passed to server_procedure from an associated door_call() are placed on the stack and include argp and dp. The argp argument points to arg_size bytes of data and the dp argument points to n_desc door_desc_t structures. The attributes argument specifies attributes associated with the newly created door. Valid values for attributes are constructed by OR-ing one or more of the following values:
Delivers a special invocation on the door when the number of descriptors that refer to this door drops to one. In order to trigger this condition, more than one descriptor must have referred to this door at some time. DOOR_UNREF_DATA designates an unreferenced invocation, as the argp argument passed to server_procedure. In the case of an unreferenced invocation, the values for arg_size, dp and n_desc are 0. Only one unreferenced invocation is delivered on behalf of a door.
Similar to DOOR_UNREF, except multiple unreferenced invocations can be delivered on the same door if the number of descriptors referring to the door drops to one more than once. Since an additional reference may have been passed by the time an unreferenced invocation arrives, the DOOR_IS_UNREF attribute returned by the door_info(3C) call can be used to determine if the door is still unreferenced.
Maintains a separate pool of server threads on behalf of the door. Server threads are associated with a door's private server pool using door_bind(3C).
Any attempt to call door_call(3C) on this door with argument descriptors will fail with ENOTSUP. When this flag is set, the door's server procedure will always be invoked with an n_desc argument of 0.
Clients which abort calls to door_call() on this door will not cause the cancellation of the server thread handling the request. See cancellation(7).
The descriptor returned from door_create() will be marked as close on exec (FD_CLOEXEC). Information about a door is available for all clients of a door using door_info(). Applications concerned with security should not place secure information in door data that is accessible by door_info(). In particular, secure data should not be stored in the data item cookie.
By default, additional threads are created as needed to handle concurrent door_call() invocations. See door_server_create(3C) for information on how to change this behavior.
A process can advertise a door in the file system name space using fattach(3C).
After creation, door_setparam(3C) can be used to set limits on the amount of data and descriptors clients can send over the door.
Upon successful completion, door_create() returns a non-negative value. Otherwise, door_create returns −1 and sets errno to indicate the error.
The door_create() function will fail if:
Invalid attributes are passed.
The process has too many open descriptors.
The following example creates a door and uses fattach() to advertise the door in the file system namespace.
void
server(void *cookie, char *argp, size_t arg_size, door_desc_t *dp,
uint_t n_desc)
door_return(NULL, 0, NULL, 0);
/* NOTREACHED */
int
main(int argc, char *argv[])
int did;
struct stat buf;
if ((did = door_create(server, 0, 0)) < 0) {
perror("door_create");
exit(1);
/* make sure file system location exists */
if (stat("/tmp/door", &buf) < 0) {
int newfd;
if ((newfd = creat("/tmp/door", 0444)) < 0) {
perror("creat");
exit(1);
(void) close(newfd);
/* make sure nothing else is attached */
(void) fdetach("/tmp/door");
/* attach to file system */
if (fattach(did, "/tmp/door") < 0) {
perror("fattach");
exit(2);
See attributes(7) for descriptions of the following attributes:
door_revoke(3C), door_bind(3C), door_call(3C), door_info(3C), door_server_create(3C), door_setparam(3C), fattach(3C), libdoor(3LIB), attributes(7), cancellation(7)
