Go to primary content
Oracle® Communications EAGLE Application Processor Alarms and Maintenance Guide
Release 16.3
E96331
Contents
Previous
Next
4000000000000001 - Mate EPAP Unavailable
One EPAP has reported that the other EPAP is unreachable.
Recovery
Log in to the EPAP
GUI
(see
Accessing the EPAP GUI
View the EPAP status on the banner.
If the mate EPAP status is
DOWN
, go to
3
ACTIVE
or
STANDBY
, go to
4
Select the
Select Mate
menu item to change to the mate EPAP.
Select
Process Control > Start Software
to start the mate EPAP software.
ACTIVE
or
STANDBY
, the problem is resolved.
If the mate EPAP status is still
DOWN
, continue with
6
Select the
Select Mate
menu item to change back to the side that reported the alarm.
Stop and start the software on the side that is reporting the alarm (see
Restarting the EPAP Software
If the problem persists, run
savelogs
to gather system information for further troubleshooting (see
Saving Logs Using the EPAP GUI
), and contact
My Oracle Support (MOS)
