Publishing Oracle Analytics Server Custom Print
You must publish the Oracle Analytics Server Custom Prints in the Oracle Analytics Server.
To publish a Custom Print:
  1. Prepare the custom print.
  2. Click Status.
    The status of an Oracle Analytics Server Custom Print template is either set as Draft, or the status is set as Published. For either case, to print the Custom Print template, you must select Publish.
    You can delete a Custom Print template regardless of the Custom Print template status.
  3. Select Publish.
    After you publish, the system performs validation and if there are no errors the system publishes the Custom Print template and assigns the new Published Date in the log.
    Notes:
    • If you remove the data elements from the design of the data source that has been used in the Oracle Analytics Server Custom Print template, you must republish the Custom Print template to the Oracle Analytics Server.
    • If you add new data elements to the upper form, or detail form, of the BP Design, you must re-publish the Custom Print template and download a new copy of data schema to be able to see and use these new elements (of data schema) in the template.
    • You can update the Custom Print template layout by regenerating the sample data.
    • When the status of a Custom Print changes from "Draft" to "Published," the system generates the data model with respect to the current BP Design. As a result, if the BP design has changed between the time of first download of the Sample Data and the publishing of the Custom Print, the developed report Template must be tested again with the new Data XML.
See Also
Configuring and Publishing Oracle Analytics Server Custom Templates (Custom Prints and Reports)
Custom Templates (Custom Prints and Reports) Overview
Assigning Roles and Permissions to Oracle Analytics Server User to Publish and Run Reports
Creating Data Model (.XDM) File
Custom Templates Windows Log
Oracle Analytics Server Report Levels
Sample XML Data for Custom Templates (Custom Prints and Reports)
Creating Oracle Analytics Server Custom Print
Creating Custom Email Template
Parameters for External Multiple Custom Print
Creating Oracle Analytics Server Custom Report
Download and Install Oracle Analytics Publisher Desktop for Microsoft Office
Building Report Template (RTF)
Publishing Oracle Analytics Server Custom Report
Making a New Custom Report Appear in Navigation
Setting Permissions for Custom Reports
Running a Report
Uploading a Template for External Data Model Type Custom Report
Downloading Sample XML Data for Designing New Templates
Modifying Existing XDM for Custom Report or Custom Print Configuration
Adding a Dynamic Image in the Custom Print Template
Adding a Dynamic Image in the Custom Report Template
Adding a Dynamic Image in an Oracle Analytics Server Report
Adding Rich Text Data Element in Oracle Analytics Server Report and Custom Print
Connect to the Database
Last Published Tuesday, April 15, 2025
