Making a New Custom Report Appear in Navigation
If you must change the location of Oracle Analytics Server custom reports, follow these steps to make newly defined reports appear:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Configuration, and then select User Mode Navigator.
Note: If the company uses the default User Mode Navigator (that is, the company has not defined a custom User Mode Navigator), you will be able to see the report name under Access Control of the project.
- Open the project or shell User Mode Navigator.
- In the dialog box, find the newly created Oracle Analytics Server reports on the right side and move them to a desired location in the left Navigator.
- Save the changes and close the window.
- Select the project or shell User Mode Navigator and click the Deploy button to ensure the changes take effect.
- After deploying the navigator, sign out and then sign in, go to Access Control, and assign permissions for the new custom report.
Note: Oracle Analytics Server User Group requirement: To be able to create reports, users must be added to the Oracle Analytics Server Author user group in Primavera Administration.
See Also
Configuring and Publishing Oracle Analytics Server Custom Templates (Custom Prints and Reports)
Custom Templates (Custom Prints and Reports) Overview
Assigning Roles and Permissions to Oracle Analytics Server User to Publish and Run Reports
Creating Data Model (.XDM) File
Oracle Analytics Server Report Levels
Sample XML Data for Custom Templates (Custom Prints and Reports)
Creating Oracle Analytics Server Custom Print
Creating Custom Email Template
Publishing Oracle Analytics Server Custom Print
Parameters for External Multiple Custom Print
Creating Oracle Analytics Server Custom Report
Download and Install Oracle Analytics Publisher Desktop for Microsoft Office
Building Report Template (RTF)
Publishing Oracle Analytics Server Custom Report
Setting Permissions for Custom Reports
Uploading a Template for External Data Model Type Custom Report
Downloading Sample XML Data for Designing New Templates
Modifying Existing XDM for Custom Report or Custom Print Configuration
Adding a Dynamic Image in the Custom Print Template
Adding a Dynamic Image in the Custom Report Template
Adding a Dynamic Image in an Oracle Analytics Server Report
Adding Rich Text Data Element in Oracle Analytics Server Report and Custom Print
Last Published Tuesday, April 15, 2025
