Running a Report
To run the Oracle Analytics Server Report in Unifier Essentials:
  1. Sign in to Unifier Essentials.
  2. Go to the shell tab and switch to User mode.
  3. In the left Navigator, select Reports, select Custom, and then select the applicable report node.
  4. On the page for the selected report node, enter the Template and Format, enter the Search Parameters, and click Run Report.
See Also
Configuring and Publishing Oracle Analytics Server Custom Templates (Custom Prints and Reports)
Custom Templates (Custom Prints and Reports) Overview
Assigning Roles and Permissions to Oracle Analytics Server User to Publish and Run Reports
Creating Data Model (.XDM) File
Custom Templates Windows Log
Oracle Analytics Server Report Levels
Sample XML Data for Custom Templates (Custom Prints and Reports)
Creating Oracle Analytics Server Custom Print
Creating Custom Email Template
Publishing Oracle Analytics Server Custom Print
Parameters for External Multiple Custom Print
Creating Oracle Analytics Server Custom Report
Download and Install Oracle Analytics Publisher Desktop for Microsoft Office
Building Report Template (RTF)
Publishing Oracle Analytics Server Custom Report
Making a New Custom Report Appear in Navigation
Setting Permissions for Custom Reports
Uploading a Template for External Data Model Type Custom Report
Downloading Sample XML Data for Designing New Templates
Modifying Existing XDM for Custom Report or Custom Print Configuration
Adding a Dynamic Image in the Custom Print Template
Adding a Dynamic Image in the Custom Report Template
Adding a Dynamic Image in an Oracle Analytics Server Report
Adding Rich Text Data Element in Oracle Analytics Server Report and Custom Print
Connect to the Database
Last Published Tuesday, April 15, 2025
