Setting Permissions for Custom Reports
To set permissions for Custom Reports:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Access Control.
- In the right pane, expand User Mode Access, and then complete the following:
- If the reports are at the Program level, expand Programs, expand Reports, expand Custom, and then select
[report name]. - If the reports are at the Project level, expand Projects/Shells, expand Reports, expand Custom, and then select
[report name].
- Select the access for the appropriate user.
- Click OK.
Notes:
- A user with the configure permission to the Custom Report node, can configure custom print templates. There are no separate permissions for performing actions on the custom print templates.
- If you have a User Mode Navigator, you must include the Custom Report in the navigator and redeploy before the user can assign permission through Access Control.
See Also
Configuring and Publishing Oracle Analytics Server Custom Templates (Custom Prints and Reports)
Custom Templates (Custom Prints and Reports) Overview
Assigning Roles and Permissions to Oracle Analytics Server User to Publish and Run Reports
Creating Data Model (.XDM) File
Oracle Analytics Server Report Levels
Sample XML Data for Custom Templates (Custom Prints and Reports)
Creating Oracle Analytics Server Custom Print
Creating Custom Email Template
Publishing Oracle Analytics Server Custom Print
Parameters for External Multiple Custom Print
Creating Oracle Analytics Server Custom Report
Download and Install Oracle Analytics Publisher Desktop for Microsoft Office
Building Report Template (RTF)
Publishing Oracle Analytics Server Custom Report
Making a New Custom Report Appear in Navigation
Uploading a Template for External Data Model Type Custom Report
Downloading Sample XML Data for Designing New Templates
Modifying Existing XDM for Custom Report or Custom Print Configuration
Adding a Dynamic Image in the Custom Print Template
Adding a Dynamic Image in the Custom Report Template
Adding a Dynamic Image in an Oracle Analytics Server Report
Adding Rich Text Data Element in Oracle Analytics Server Report and Custom Print
Last Published Tuesday, April 15, 2025
