Pages Used in the PeopleSoft Classic General Ledger WorkCenter - My Work Pagelet
GL_WORKCENTER
The PeopleSoft Classic General Ledger WorkCenter hub provides the frame within which all selected content components and pagelets are accessed and displayed for use. From here, you can view and edit your most commonly-used components and be alerted to those items that require your attention.
WorkCenter Journal Entries Page
GL_WC_JRNLS
Designed like the Journal Entry component, use this page to manage journals from within your WorkCenter transaction pane, according to security setup.
WorkCenter Budget Journal Exceptions Page
GL_WC_BJRN_EXCPT
Designed like the budget journal exceptions components, use this page to manage control budget exceptions from within your WorkCenter transaction pane, according to security setup.
WorkCenter Journals Pending My Approval Page
GL_WC_JRNL_APPR_M
Designed like the Manage GL Journal Approval component, use this page to manage journal approvals from within your WorkCenter transaction pane, according to security setup.
WorkCenter ChartField Requests Pending My Approval Page
GL_WC_FLD_REQ_APPR
Designed like the Manage Business Request Approval component, use this page to manage field request and approval from within your WorkCenter transaction pane, according to security setup.
WorkCenter Reconciliations Pending My Approval
GL_WC_GLRN_WB
Designed like the Reconciliation Workbench component, use this page to manage reconciliations that are pending your approval from within your WorkCenter transaction pane, according to security setup.
