1.3 Oracle's Recovery Appliance Solution
Recovery Appliance is a cloud-scale Engineered System designed to protect all Oracle databases across the enterprise. Most database backup and restore processing is performed by the centralized Recovery Appliance, making storage utilization, performance, and manageability of backups more efficient.
The Recovery Appliance stores and manages backups of multiple Oracle databases in a unified disk pool, using an RMAN incremental-forever strategy. The Recovery Appliance continually compresses, deduplicates, and validates backups at the database block level, while creating virtual full backup on demand.
A virtual full backup is a complete database image as of one distinct point in time, maintained efficiently through Recovery Appliance indexing of incremental backups from protected databases. A virtual full backup can correspond to any incremental backup that was received.
Figure 1-5 shows an overview of a sample Recovery Appliance environment.
Figure 1-5 Recovery Appliance Environment
Description of Figure 1-5 follows
Description of "Figure 1-5 Recovery Appliance Environment"
As shown in Figure 1-5, a protected database is a client database that backs up data to a Recovery Appliance. Each protected database uses the Zero Data Loss Recovery Appliance Backup Module (Recovery Appliance Backup Module) for its backups. This module is an Oracle-supplied SBT library that RMAN uses to transfer backup data over the network to the Recovery Appliance.
The Recovery Appliance metadata database, which resides on each Recovery Appliance, manages metadata stored in the RMAN recovery catalog, and backups located in the Recovery Appliance storage location. The catalog is required to be used by all protected databases that send backups to Recovery Appliance.
Databases may use Recovery Appliance as their recovery catalog without also using it as a backup repository.
Administrators use Oracle Enterprise Manager Cloud Control (Cloud Control) to manage and monitor the environment. Cloud Control provides a "single pane of glass" view of the entire backup lifecycle for each database, whether backups reside on disk, tape, or another Recovery Appliance.
Recovery Appliance provides the following benefits:
Oracle Secure Backup (OSB) 19.1 desupport was announced on May 1, 2026 with premier support end date on September 30, 2027. See My Oracle Support note PNEWS3035 for more information. Please refer to Lifetime Support Policy: Oracle Technology Products for updated support timeframes.
Oracle recommends that database backups to cloud take advantage of Oracle Database Zero Data Loss Cloud Protect, which uses Oracle Zero Data Loss Autonomous Recovery Service in OCI. Cloud Protect offers an efficient incremental forever backup strategy, real-time transaction protection, logically air-gapped immutable backups, and fast, point-in-time recovery.
For customers who require database backups to Amazon S3, Oracle Database Cloud Backup for Amazon S3 may be used. This offering is similar to Oracle Secure Backup Cloud Module in that it is fully integrated with Recovery Manager (RMAN) and enables you to back up your Oracle database to Amazon S3. You can exchange your Oracle Secure Backup license for an Oracle Database Cloud Backup for Amazon S3 license on a 1:1 basis. See Oracle Database Cloud Backup for Amazon S3 for more information.
As with Oracle Secure Backup Cloud Module, Oracle Database Cloud Backup for Amazon S3 can be used free of charge on Oracle Zero Data Loss Recovery Appliance (ZDLRA) for the sole purpose of backing up data to and restoring data from S3-compatible storage devices that are in the same campus as ZDLRA.
1.3.1 Elimination of Data Loss
The Recovery Appliance uses various mechanisms to protect against different types of data loss, including physical block corruption. This section contains the following topics:
1.3.1.1 Protection of Ongoing Transactions
In traditional backup approaches, if the online redo log is lost, then media recovery loses all changes after the most recent available archived redo log file or incremental backup. A recovery point objective (RPO) of a day or more that might result from a traditional approach may be unacceptable.
Recovery Appliance solves the RPO problem through a continuous transfer of redo changes to the appliance from a protected database. This operation is known as real-time redo transport. Using delta push, the Recovery Appliance is a remote destination for asynchronous redo transport services from Oracle Database 11g and Oracle Database 12c databases.
This technology is based on the real-time redo transport algorithms of Oracle Data Guard. To avoid degrading the performance of the protected database, protected databases transfer redo asynchronously to the Recovery Appliance. If a protected database is lost, zero to subsecond data loss is expected in most cases.
See Also:
1.3.1.2 Secure Replication
To protect against server or site outage, one Recovery Appliance can replicate backups to a different Recovery Appliance. Figure 1-6 shows the simplest form of replication, called one-way Recovery Appliance replication, in which an upstream Recovery Appliance (backup sender) transfers backups to a downstream Recovery Appliance (backup receiver).
In Figure 1-6, a protected database sends an incremental backup to the Recovery Appliance, which then queues it for replicating to the downstream Recovery Appliance. When the upstream Recovery Appliance sends the incremental backup to the downstream Recovery Appliance, it creates a virtual full backup as normal. The downstream Recovery Appliance creates backup records in its recovery catalog. When the upstream Recovery Appliance requests the records, the downstream Recovery Appliance propagates the records back.
If the local Recovery Appliance cannot satisfy virtual full backup requests, then it automatically forwards them to the downstream Recovery Appliance, which sends virtual full backups to the protected database. DBAs use RMAN as normal, without needing to understand where or how the backup sets are stored.
1.3.1.3 Autonomous Tape Archival
A robust backup strategy protects data against intentional attacks, unintentional user errors (such as file deletions), and software or hardware malfunctions. Tape libraries provide effective protection against these possibilities.
Figure 1-7 show the traditional technique for tape backups, with a media manager installed on each host.
Figure 1-7 Backups to Tape Without Using Recovery Appliance
Description of Figure 1-7 follows
Description of "Figure 1-7 Backups to Tape Without Using Recovery Appliance"
Figure 1-8 shows the Recovery Appliance technique for tape backups. The fundamental difference in the two approaches is that the Recovery Appliance backs up to tape, not the protected databases. The Recovery Appliance comes with preinstalled Oracle Secure Backup software, and supports optional Fibre Channel cards. Thus, installation of a media manager is not necessary on the protected database hosts.
Figure 1-8 Backups to Tape Using Recovery Appliance
Description of Figure 1-8 follows
Description of "Figure 1-8 Backups to Tape Using Recovery Appliance"
When Recovery Appliance executes a copy-to-tape job for a virtual full backup, it constructs the physical backup sets, and copies them to tape, and then writes the metadata to the recovery catalog. If desired, the Recovery Appliance can also copy successive incremental backups and archived redo log file backups to tape. Whereas the backup on the Recovery Appliance is virtual, the backup on tape is a non-virtual, full physical backup. The Recovery Appliance automatically handles requests to restore backups from tape, with no need for administrator intervention.
The advantages of the Recovery Appliance tape solution are as follows:
  • The Recovery Appliance performs all tape copy operations automatically, with no performance load on the protected database host.
  • Tape backups are optimized. Recovery Appliance intelligently gathers the necessary blocks to create a non-virtual, full backup for tape.
  • Oracle Secure Backup is preinstalled, eliminating the need for costly third-party media managers.
    You may deploy tape backup agents from third-party vendors on the Recovery Appliance for integration with existing tape backup software and processes. In this configuration, the agents must connect to their specialized media servers, which must be deployed externally to the Recovery Appliance.
  • Tape drives and tape libraries function more efficiently because Recovery Appliance is a single large centralized system with complete control over them. In other tape solutions, hundreds or thousands of databases can contend for tape resources in an uncoordinated manner.
1.3.1.4 End-to-End Data Validation
A basic principle of backup and recovery is to ensure that backups can be restored successfully. To ensure that there are no physical corruptions within the backed-up data blocks, backups require regular validation. Validation typically involves running an RMAN RESTORE VALIDATE job regularly, along with running periodic full restore and recovery operations to a separate machine.
Recovery Appliance provides end-to-end block validation, which occurs in the following stages of the workflow:
  • Recovery Appliance validation
    The Recovery Appliance automatically validates the backup stream during the backup ingest phase, before writing the backups to disk. The Recovery Appliance also validates the backup before sending it back to the original or alternate database server during the restore phase. Therefore, no manual RESTORE VALIDATE step is required.
    In addition, a background task running on the Recovery Appliance periodically validates the integrity of the virtual full backups in the delta pools (see "Delta Pools"). The goal of this task is to check each block of each virtual full backup of each protected database and to work behind the scenes when minimal activity is occurring. By default, the validation task runs every 14 days following the last completed validation of a database’s current set of backups on disk.
    Just as with data file backups, the Recovery Appliance validates the integrity of redo log blocks during every operation, including receiving redo from the protected database, and storing it in compressed archived log backup sets.
  • Oracle Automatic Storage Management (ASM)
    Oracle ASM stores the backup and redo data for the Recovery Appliance. Oracle ASM mirrored copies provide redundancy (see "Recovery Appliance Storage Locations").
    If a corrupted block is read on the primary mirror, the Recovery Appliance automatically repairs the block from the mirrored copy. This mechanism resolves most isolated block corruption cases.
  • Tape library
    Recovery Appliance validates blocks when it copies them to tape, and also when it restores them from tape (see "Tape Archival").
  • Downstream Recovery Appliance in a replication configuration
    If you configure replication, then the downstream Recovery Appliance validates data during the backup ingest and restore phases (see "How a Downstream Recovery Appliance Processes Backups").
None of the preceding backup validation processes occur on the production database hosts, thus freeing production resources for more critical operational workloads.
Oracle Maximum Availability Architecture best practices recommend that you still perform periodic full database recovery tests to verify operational practices and to detect issues that might occur only during media recovery.
See Also:
  • "CONFIG" for information about the validate_db_days configuration parameter
  • "RA_DATABASE" for information about the RA_DATABASE.LAST_VALIDATE column
1.3.2 Minimal Backup Overhead
In traditional database backup techniques, the Oracle database host performs the brunt of the processing. Agents for disk backup, tape backup, and deduplication may all be running on the host. Furthermore, all backup operations—compression, validation, deletion, merging, and so on—occur on the database host. This overhead can greatly degrade database performance.
Recovery Appliance removes almost the entire load from the protected databases. The only backup operations required on the hosts, which could be primary database or standby database hosts, are sending incremental backups to the Recovery Appliance. The incremental-forever strategy reduces the backup window on the database hosts significantly. Recovery Appliance handles backup processing, tape operations, data integrity checks, and routine maintenance.
Recovery Appliance only supports backups of Oracle databases, not file system data or non-Oracle databases.
Recovery Appliance optimizes management of database changes using delta push and delta store, shown in Figure 1-9. The net result of delta push and delta store is that the problem of lengthening backup windows is eliminated. The DBA performs only fast incremental backups, and lets the Recovery Appliance manage the backup blocks.
Figure 1-9 Delta Push and Delta Store
Description of Figure 1-9 follows
Description of "Figure 1-9 Delta Push and Delta Store"
1.3.2.1 Delta Push
This solution consists of two operations that run on each protected database: the incremental-forever backup strategy, and real-time redo transport. Both operations involve protected databases pushing changes to the Recovery Appliance.
In an incremental-forever strategy, only one incremental level 0 backup to the Recovery Appliance is required in the lifetime of each protected file. The initial level 0 backup does not contain committed undo blocks or currently unused blocks.
The elimination of committed undo and currently unused blocks is only supported for SBT full backups to the Recovery Appliance or Oracle Secure Backup. It is not available for SBT backups to other backup products.
In normal operation, the Recovery Appliance automatically performs the following steps for each incremental level 1 backup:
  1. Receives a scheduled incremental level 1 backup from each protected database
  2. Validates the incoming backup to protect against physical block corruptions
  3. Compresses the backup using specialized block-level algorithms
  4. Writes the backup to a delta store in a Recovery Appliance storage location
The incremental-forever strategy greatly reduces the backup window and overhead because no full backups are ever required after the initial incremental level 0 backup. If the strategy includes real-time redo transport, then backup windows are further reduced because traditional archived log backups are not necessary. Also, Recovery Appliance takes on the burden of validation, deduplication, and compression.
Blocks compressed using table or Hybrid Columnar Compression remain compressed in the RMAN backup and during the Recovery Appliance ingest phase.
1.3.2.2 Delta Store
The delta store is the key processing engine for Recovery Appliance. A protected database sends only one incremental level 0 backup of each data file to the Recovery Appliance. Following the initial full backup, all backups are highly efficient cumulative incremental backups.
As Recovery Appliance receives incremental backups, it indexes them and stores them in delta pools. Each separate data file backed up to the Recovery Appliance has its own separate delta pool (set of backup blocks). Recovery Appliance automatically manages the delta pools so that it can provide many virtual full backups.
1.3.2.2.1 Creation of Virtual Full Backups
To create a virtual full backup, Recovery Appliance converts an incoming incremental level 1 backup into a virtual representation of an incremental level 0 backup. A virtual full backup appears as an incremental level 0 backup in the recovery catalog. From the user's perspective, a virtual full backup is indistinguishable from a non-virtual full backup. Using virtual backups, Recovery Appliance provides the protection of frequent level 0 backups with only the cost of frequent level 1 backups.
Recovery Appliance provides storage services, but not virtual full backups, for RMAN-encrypted backups (see "Archival and Encrypted Backups"). These backups are stored in their original encrypted format. Recovery Appliance can store, archive, and retrieve them just as it can for unencrypted RMAN backup sets.
1.3.2.2.2 Rapid Recovery Using Virtual Full Backups
Recovery Appliance uses virtual full backups to provide rapid recovery to any point in time, regardless of the amount of data being recovered. The on-disk recovery strategy of Recovery Appliance has the advantage that RMAN can recover virtual full backups to any point in time without applying incremental backups.
When a database is protected by the Recovery Appliance, RMAN must only restore a single level 0 backup for the day of the RPO, and then recover up to the last second using redo log files sent using the real-time redo transport feature. For example, if the recovery window is 7 days, and if the RPO is 5 days ago, then RMAN can restore a single virtual full (level 0) backup that is current to 5 days ago, and then recover it using redo—not level 1 incremental backups.
See Also:
1.3.3 Improved End-to-End Data Protection Visibility
In traditional database backup techniques, management of the database, media server, and tape drives are often separated. For example, a DBA group may manage the databases, while a separate backup administrator group manages the backups, and a storage group manages the disk and tape devices. The overall process lacks visibility, which makes it difficult to manage backups for thousands of databases, each with different recovery requirements.
Cloud Control provides a complete, end-to-end view into the backup lifecycle managed by the Recovery Appliance, from the time the RMAN backup is initiated on the database, to when it is stored on disk, tape, or replicated to a downstream Recovery Appliance. Recovery Appliance monitoring and administration are enabled through installation of the Enterprise Manager for Zero Data Loss Recovery Appliance plug-in (Recovery Appliance plug-in).
Using Cloud Control to manage a Recovery Appliance provides the following benefits:
  • Standard metrics such as overall backup performance, and aggregate or per-database space consumption
  • Immediate alerts about any backup or Recovery Appliance issues
    For example, Cloud Control may alert the administrator if no backup is available to meet the defined RPO, or if corrupt backups are discovered.
  • Status reports, enabled by BI Publisher, are useful for capacity planning and to identify protected databases that are not meeting recovery window goals
    For example, Recovery Appliance administrators can receive reports on historical space and network usage to identify backup volume and throughput trends. These trends may necessitate adding storage servers to an existing rack or connecting additional racks.
Although Cloud Control is the recommended user interface for Recovery Appliance administration, Oracle supplies the DBMS_RA PL/SQL package as a command-line alternative. Most tasks in this manual provide both Cloud Control and DBMS_RA techniques. For command-line monitoring and reporting, you can query the Recovery Appliance catalog views.
1.3.4 Cloud-Scale Protection
Recovery Appliance scales at a cloud level, supporting tens to hundreds to thousands of databases across a data center. Essentially, Recovery Appliance enables you to create a private data protection cloud within the enterprise. The following technology components within Recovery Appliance make this possible:
1.3.4.1 Policy-Based Data Protection Management
Recovery Appliance simplifies management through the protection policy. Benefits include the following:
  • A protection policy defines recovery window goals that are enforced for each database for backups to the Recovery Appliance or a tape device.
    Using protection policies, you can group databases by recovery service tier. For example, databases protected by the Platinum policy require backups to be kept for 45 days on the Recovery Appliance and 90 days on tape, which means that backups aged 45 days or less exist on disk and tape, but backups older than 45 days are only on tape. Databases protected by the Gold policy require 35 days on the local Recovery Appliance and 90 days on tape. Optionally, you can define a maximum retention time within each policy to limit the space consumed, and to comply with service level agreements dictating that backups cannot be maintained for longer than a specified period.
  • Protection policies are means of grouping databases, improving manageability.
    For example, you can configure Recovery Appliance replication or copy-to-tape for a specific protection policy, which means that the configuration applies to all databases associated with this policy. If you add a database to the policy, then the database automatically inherits the configurations and scheduling of the policy.
1.3.4.2 Database-Aware Space Management
Using protection policies, the Recovery Appliance manages backup storage space according to the recovery window goal for each protected database. This granular, database-oriented space management approach eliminates the need to manage space at the storage-volume level, as third-party appliances do.
If space is available, then the Recovery Appliance may retain backups older than the recovery window goal, effectively extending the point-in-time recovery period. When space pressure exists, the Recovery Appliance uses predefined thresholds to purge backups. The Recovery Appliance automatically provisions space so that the recovery window goal for each database is met.
The Oracle Zero Data Loss Recovery Appliance with Release 21.1 supports immutable backups, which are a requirement of various government regulations such as SEC 17(a)-4f and others from FINRA, CFTC, MiFID II, which specify rules for compliance retention and legal holds.
The "Recovery Window Compliance" is a range of time that the Recovery Appliance will ensure databases can be recovered from their backups. When defined in the protection policy, newly created backups of that policy are held on the Recovery Appliance for that period of time. Recovery window compliance is different and more restrictive than the recover window goal.
If compliance features are not enabled, the protection policy can make use of "autotuned reserved space", which has the Recovery Appliance automatically define and update the storage space.
1.3.4.3 Scalable Architecture
The approaches in "Traditional Database Backup Techniques" are prone to performance bottlenecks and multiplying points of failure. As the number of databases increases, so does the number of media servers, disk arrays, tape devices, and third-party appliances, and thus so does the overall complexity. The "add more devices" approach is not scalable. In contrast, Recovery Appliance can scale to accommodate increases in backup traffic, storage usage, and the number of databases by adding compute and storage resources in a simple, modular fashion.
See Also:
Zero Data Loss Recovery Appliance Owner's Guide for information about adding storage servers
1.3.5 Maximum Availability: Recovery Appliance with Oracle Data Guard
Oracle Data Guard is a component of a high availability (HA) and disaster recovery solution that can be integrated with Recovery Appliance to provide maximum data protection. Oracle Data Guard minimizes service interruption and resulting data loss by maintaining a synchronized standby database for the protected database. When the primary system is unavailable, the standby immediately assumes the normal operations of the primary after a Data Guard failover operation, including backups to the local Recovery Appliance. Figure 1-10 shows an example of an environment with Recovery Appliance and Oracle Data Guard.
Figure 1-10 Recovery Appliance with Oracle Data Guard
Description of Figure 1-10 follows
Description of "Figure 1-10 Recovery Appliance with Oracle Data Guard"
In Figure 1-10, the primary and standby databases each send incremental backups to their local Recovery Appliance. The primary database sends real-time redo changes to both the local Recovery Appliance and the physical standby, and the standby cascades the redo changes to the remote Recovery Appliance. Each Recovery Appliance has backups and redo information for the same database, therefore either appliance can be used for RMAN restore and recovery operations.
See Also:
