4.176 dact-echo
Use this command to halt the echoing of command responses from the user’s terminal to other terminals or printers.
Parameters
trm (optional)
The ID number of the terminal for which the echo is being canceled.
Range:
1 - 16
Default:
Cancels all active echoes
Example
dact-echo
Dependencies
The echo to the same terminal from which the dact-echo command is issued cannot be cancelled.
There must be an active echo (act-echo) to the terminal specified.
Notes
Only the echoing of command output responses can be halted by this command. To halt the printing of alarm and network messages, use the chg-trm command.
Output
dact-echo
    rlghncxa03w 04-01-07 11:11:28 EST  EAGLE 31.3.0
    Command entered at terminal #6.
    Scroll Area Output echo disabled to all terminals.
dact-echo:trm=7
    Command entered at terminal #1.
    Scroll Area Output echo disabled for terminal 7.
