Examples of Initiative Criteria
The following is an example of how to set up initiative criteria.
Initiative: Smart Rate Program For Residential Customers
The program targets summertime pricing for residential customers. Customers are required to reduce energy use between 2 PM and 7 PM for no more than 15 summer days, which are referred to as smart days. A higher rate is charged during this time period. A discounted rate is applied for all other times during the season.
Initiative Eligibility Criteria
To be eligible for this initiative, the account must be a residential account with an average daily usage that is more than 10 kWh, not currently on a smart rate program, and is on either the ERES1 or ERES2 rate schedule. The account must also not have any active credit and collection process.
Sequence Description Criteria Field Algorithm Operator Comparison Value If True If False If Insufficient Data Criteria Execution Point
10 Residential customers Retrieve Customer Class (Define an algorithm instance for base algorithm type C1-ICGETACEL, Retrieve account attribute) = R Check next condition Not Eligible Not Eligible Both (lead generation and enrollment)
20 Average daily usage > 10 kWh Retrieve average daily kWh usage (Define an algorithm for base algorithm type C1-ICGETAVSQ, Retrieve average service quantity) > 10 Check next condition Not Eligible Not Eligible Both (lead generation and enrollment)
30 Not on a smart rate program Retrieve all contract options (Use base algorithm C1-ICGETCOPT) = 295076574659 (Contract option for smart day events) Not Eligible Check next condition Not Eligible Both (lead generation and enrollment)
40 Account is current Check if Account Is Current (Use base algorithm C1-ICCHKACCU) = true Check next condition Not Eligible Not Eligible Both (lead generation and enrollment)
50 Active service on eligible rate Retrieve all active rates (Use base algorithm C1-GETACTVRT) IN ERES1, ERES2 Eligible Not Eligible Not Eligible Both (lead generation and enrollment)
Related Object Criteria
If the account is eligible, the premise(s) associated with the account’s active and pending start service agreement’s service points of type E-RES will be linked to the lead as related object(s).
10 Premises with E-RES (electric residential) service points Retrieve Premise SP Types (Base algorithm C1-ICPRMSPTY) = E-RES Eligible Not Eligible Not Eligible
