Oracle Utilities Digital Asset Management Installation Guide
Overview
Application Architecture Overview
Tier 1: Desktop/Client, or Presentation Tier
Tier 2: Web Application/Business Application Server, or Business Logic Tier
Tier 3: Database or Persistence Tier
Supported Platforms and Hardware Requirements
Software and Hardware Considerations
Requirements by Tier
Tier 1, Desktop: Software and Hardware Requirements
Tier 2, Web/Business Application Server: Software and Hardware Requirements
Tier 3, Database Server: Software and Hardware Requirements
Supported Platforms
Operating Systems and Application Servers
Support for Software Patches and Upgrades
Planning the Installation
Installation and Configuration Overview
Before You Install
WebLogic Native Installation
Application Server Clustering
Directory Names
Installation Checklist
Installation Menu Functionality Overview
Installation Menu Functionality Details
Installation and Configuration Worksheets
Menu Block 1: Environment ID, Roles, Third Party Software Configuration
Menu Block 2: Keystore Options
Menu Block 50: Environment Installation Options
Menu Block 1: Environment Description
Menu Block 2: [WebLogic] Business Application Server Configuration
Menu Block 3: [WebLogic] Web Application Server Configuration
Menu Block 4 - Database Configuration
Menu Block 5 - General Configuration Options
Menu Block 6 - OUAF TrustStore Options
Menu Block 8 - OSB Configuration
Menu Block 9 - SOA Configuration
Menu Block 10 - SOA Configuration Plan (MDM)
Menu Block 11 - Configuration for DataRaker Integration
Menu Block 16 - SOA Configuration Plan (LG)
Menu Block 17 - SOA Configuration Plan (NES)
Menu Block 18 - SOA Configuration Plan (Sensus)
Menu Block 19 - SOA Configuration Plan (SSN)
Menu Block 20 - SSN JMS Source Destination Bridge Configuration
Menu Block 21 - DG Reference Implementation SOA Configuration
Menu Block 22 - SOA Configuration Plan (Itron Openway)
Advanced Menu Options
Installing Application Server Prerequisite Software
AIX Application Server
Supported Application Servers
Web/Application Server Tier
Oracle Linux 8.x and Red Hat Linux 8.x Application Server
Solaris 11.4+ Application Server
Windows 2012 Application Server
Additional Prerequisite Software Information
Setting Up and Using the Additional JAR Directory
Special Note to Upgrade from a WebLogic 12.1.3.x Environment
Installing the Application Server Component of Oracle Utilities Application Framework
Installation Overview
Pre-Installation Tasks
Hardware and Software Version Prerequisites
Database Installation
Installation Prerequisites
System Architecture Overview
Copying and Decompressing Install Media
Set Permissions for the cistab File in UNIX
Installing Oracle Utilities Application Framework
Installation Process (Brief Description)
Installation Process (Detailed Description)
Detailed Description for Configuring the OUAF Keystore
Installing Oracle Utilities Digital Asset Management
Prerequisites
Installing Oracle Utilities Digital Asset Management Components
Installing Oracle Utilities Application Framework V4.5.0.1.3 Prerequisite Single Fixes
Installing Oracle Utilities Customer Care and Billing V2.9.0.1.3
Installing Oracle Utilities Customer Care and Billing V2.9.0.1.3 Post-release Patches
Installing Oracle Utilities Meter Data Management V2.5.0.1.3
Installing Oracle Utilities Meter Data Management V2.5.0.1.3 Post-release Patches
Installing Oracle Utilities Operational Device Management V2.4.0.1.3
Installing Oracle Utilities Work and Asset Management V2.4.0.1.3 Post-release Patches
Installing Oracle Utilities Digital Asset Management V2.0.0.1.3
Installing Oracle Utilities Digital Asset Management V2.0.0.1.3 Post-release Patches
Additional Tasks
Importing Self-Signed Certificates
Customizing Configuration Files
Centralized Properties Customization
Integrating Existing Customer Modifications
Building Javadocs Indexes
Configuring the Environment for Batch Processing
Customizing the Logo
Implementing Cloud Database (ADB) Connection
Upgrading Oracle Utilities Digital Asset Management
Upgrade Paths
Before You Upgrade
Copying and Decompressing Install Media for the Oracle Utilities Digital Asset Management Database and Application Components
Setting Permissions for the cistab file in UNIX for the Oracle Utilities Digital Asset Management Application Component
Upgrade Procedure
Upgrading the Database Component
Upgrading the Application Component
Post-Upgrade Verifications
Installing Service Packs and Patches
Application Framework Prerequisite Patches
Oracle Utilities Digital Asset Management Fixes
Oracle Utilities Digital Asset Management 2.0.0.1.3 Installation Guide
