Menu Option | Description |
Assign | Assigns the crew selected in the Viewer to the event currently selected in Work Agenda. See “Assigning a Crew to an Event” for more information. |
En Route | Puts the crew selected in the Viewer en route to the event currently selected in Work Agenda. This is enabled only if the selected crew is an on-shift, available, non-mobile crew that is not currently en route or onsite. See “Placing a Crew En Route” for more information. |
Release Crew | Releases the crew selected in the Viewer from the en route/onsite event selected in the Work Agenda. See “Releasing Crews from an Event” for more information. |
Update Availability... | Opens the Update Crew Availability dialog box for the selected crew. See “Changing Crew Availability” for more information. |
Crew Info... | Opens the Crew Info dialog box for the selected crew. See “Using Crew Info” for more information. |
Event Details... | Opens the Event Details window for the event. See “Understanding Event Details”. |
Trouble Info... | Opens the Event Details Trouble Info tab for the event. See “Using the Trouble Info Tab”. |
Event Log... | Opens the Event Details Event Log tab for the event. See “Using the Event Log Tab”. |
Damage Assessments... | Opens the Event Details Damage Assessments tab. See “Using the Damage Assessments Tab”. |
Crew Info... | Opens the Crew Info window for the crew assigned to the selected event. See “Using Crew Info”. |
Show En Route Location... | Shows the AVL location of the crew that is currently en route to the selected event. This option is only enabled when one crew is assigned to the event. |
Release Crews... | Opens the Release Crews dialog box. Enabled when one or more crew is assigned to the event. See “Releasing a Crew from the Crew Symbol in the Viewer”. |
Make Predicted Stable | Makes currently selected predicted outage stable. Visible only when currently selected predicted outage can be made stable. See the “Working with Stable Predictions” for more details. |
Remove Predicted Stable | Removes stable flag from the currently selected predicted stable outage. Visible only when a predicted stable outage is selected. See the “Working with Stable Predictions” for more details. |
Move | Moves a condition to a new location. If there are multiple conditions at a location, only the condition closest to the device can be moved. |
Show Leader Line | Shows the leader line for the asset. |
Hide Leader Line | Hides the leader line. |
Reset Location | Resets the condition position to the default location. |
Rotate Clockwise | Rotates the symbol clockwise (only available for measurements). |
Rotate Counterclockwise | Rotates the symbol counterclockwise (only available for measurements). |
Resize Bigger | Increases the symbol size (only available for measurements). |
Resize Smaller | Reduces the symbol size (only available for measurements). |
Control Tool... | Opens the Control Tool for the selected asset. See “Using the Control Tool”. |
Asset Details... | Displays the Asset Details balloon above the selected asset. See “Displaying Asset Details”. |
Attributes... | Opens the Attributes window, which displays information about the selected asset. See “Viewing Asset Attribute Information from the Viewer”. |
Open... | Initiates the Control Tool's Open command. See “Control Tool Actions”. |
Close... | Initiates the Control Tool's Open command, if applicable. See “Control Tool Actions”. |
Customer List... | Displays the Event Details Trouble Info tab's Customers List view. See “Using the Trouble Info Customers View” for more information. |
Damage Assessments... | Opens the Event Details Damage Assessments tab, which displays a list of damage assessments associated with the asset and allows you to add new damage assessments. See “Using the Damage Assessments Tab”. |
Quarantine | |
Start Patrolling | |
Remove Assessment | Remove the assessment condition. See |
Generate Tag Steps | Allows you to generate a set of steps in the active switch sheet to tag devices upstream from the selected asset. These will appear in a new Place Tags steps block. |
Toggle Call Display | Toggles call display on or off. When enabled, a symbol is displayed in the Viewer window for any assets that have calls associated with an event. Events with calls and clues will show the call symbol and clue symbol. |
Trace... | Opens the Trace tool, which allows you to display the path from a selected asset to other assets based on specific criteria. See “Executing Traces”. |
