Network Management System Advanced Distribution Management System Implementation Guide
Glossary
OMS Modules
Data Model
SCADA Adapters
Trouble Management & Events
ADMS Modeling
Sources of Data
Default Data
Data Categories
Sources
Loads
Load Profile Data
Transformers (and Voltage Regulators)
Capacitors (and Reactors)
Distributed Energy Resources (DERs)
Distributed Energy Resource Profiles
Switches and Fuses
Conductors
Split Model
Phasing Information
Nominal Voltages
DER and Weather Zone Forecasts
Weather Zones
Large Scale Utility DERs
Demand Response Groups
Seasonal and Temperature Based Limits
Seasonal Based Limits
ADMS Applications Overview
Configuration
Configuration Assistant
Event Management Rules
Power Flow & Feeder Load Management (FLM)
Power Flow and Other Applications
Viewer
Look Ahead
Web Switching
Configuration
Power Flow Mode (PF Mode)
Performance
Model Validation
Sanity Checking
Solution Details
Upstream Impedance Trace
Conductor Mismatch Tool
Data Requirements
Model
SCADA
Fault Location, Isolation and Service Restoration (FLISR)
Configuration
FLISR Mode
Performance
Data Requirements
Model
SCADA
Fault Location Analysis (FLA)
Configuration
Performance
Data Requirements
Model
SCADA
Optimization (formerly VVO)
Configuration
Feeder Type
Optimization Mode
Optimization Objective
Performance
Data Requirements
Model
SCADA
Bellwether Meters
Suggested Switching
Configuration
Data Requirements
Model
SCADA
Oracle Utilities Network Management System Advanced Distribution Management System Implementation Guide, Release 2.6.0.0.2
