Defining Event Settlement Calculation Groups
You use the Event Settlement Calculation Group portal to display and maintain event settlement calculation groups.
Refer to Understanding Event Settlement Calculation Groups for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Event Settlement Calculation Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Event Settlement Calculation Group: This zone displays basic information about event settlement calculation group.
Event Settlement Calculation Rules List: This zone lists the event settlement calculation rules belonging to the group.
