Oracle Utilities Smart Grid Gateway Database Administrator’s Guide
Database Overview
Privileges to Modify OUAF V4.5.0.1.1 Database
Supported Database Platforms
Supported Platforms Summary Table
Support for Software Patches and Upgrades
Database Maintenance Rules
Permitted Database Changes
Non-Permitted Database Changes
Installing the Database
Installation Overview
Initial Install
Copying and Decompressing Install Media
Creating the Database
Installing the CISADM Schema
Post-installation Tasks
Upgrade Install
Supported Upgrade Paths
Demo Install
Creating the Database and Importing the Dump File
Database Design
Database Object Standards
Categories of Data
Naming Standards
Column Data Type and Constraints
User Defined Code
System Assigned Identifier
Date/Time/Timestamp
Number
Fixed Length/Variable Length Character Columns
Null Column Support
XML Type Support
Cache and Key Validation Flags
Table Classification and Table Volume Flags
Default Value Setting
Foreign Key Constraints
Standard Columns
Owner Flag
Version
Database Implementation Guidelines
Configuration Guidelines
Index
Table Partitioning Recommendations
Transparent Data Encryption Recommendations
Data Compression Recommendations
Database Vault Recommendations
Oracle Fuzzy Search Support
Information Lifecycle Management (ILM) and Data Archiving Support
Storage Recommendations
ILM Enabled Tablespace Requirements
Database Configuration Recommendations
Database Syntax
Database Initialization Parameters
Oracle Database Implementation Guidelines
Oracle Partitioning
Database Statistic
Materialized View
Conversion Tools
Installing the Script
Preparing the Production Database
Preparing the Staging Database
Linux/UNIX:
Information Lifecycle Management and Data Archiving in SGG
ILM Implementation Overview
ILM Implementation Components
ILM Database Administrator’s Tasks
Preparation Phase
Statistics Snapshot
On-going Maintenance Phase
Naming Convention
Sample SQL for Enabling ILM in SGG (Initial Installation)
Maintenance Object: TO DO ENTRY
Parent Table: CI_TD_ENTRY
Child Table: CI_TD_DRLKEY
Child Table: CI_TD_ENTRY_CHA
Child Table: CI_TD_LOG
Child Table: CI_TD_MSG_PARM
Child Table: CI_TD_SRTKEY
Maintenance Object:F1-SYNCREQIN
Parent Table: F1_SYNC_REQ_IN
Child Table: F1_SYNC_REQ_IN_CHAR
Child Table: F1_SYNC_REQ_IN_EXCP
Child Table: F1_SYNC_REQ_IN_EXCP_PARM
Child Table: F1_SYNC_REQ_IN_LOG
Child Table: F1_SYNC_REQ_IN_LOG_PARM
Child Table: F1_SYNC_REQ_IN_REL_OBJ
Maintenance Object: D1-IMD
Parent Table: D1_INIT_MSRMT_DATA
Child Table: D1_INIT_MSRMT_DATA_CHAR
Child Table: D1_INIT_MSRMT_DATA_LOG
Child Table: D1_INIT_MSRMT_DATA_LOG_PARM
Child Table: D1_INIT_MSRMT_DATA_K
Sample SQL for Enabling ILM in SGG (Existing Installation)
Sample SQL for Enabling ILM with Sub Retention in SGG (Existing Installation)
Sample SQL for Periodic Maintenance
Add Partition
Archive Partition
Restore Partition
Partitioning and Compression Recommendations
D1_MSRMT
D1_MSRMT_CHAR
D1_MSRMT_LOG
D1_MSRMT_LOG_PARM
D1_INIT_MSRMT_DATA
Sample SQL Script for Interval Partitioning
Database Changes in Oracle Utilities Smart Grid Gateway
Upgrading from Oracle Utilities Smart Grid Gateway V2.5.0.0.0 to V2.5.0.1.1
New Tables
New Indexes
Dropped Indexes
Columns Added
Updated Columns (Tables)
Upgrading from Oracle Utilities Smart Grid Gateway V2.5.0.1.0 to V2.5.0.1.1
New Columns
Deleted Columns
New Indexes
Deleted Indexes
Upgrades to the Oracle Utilities Application Framework Database
Upgrading from Oracle Utilities Application Framework V4.3.0.1.0 to V4.3.0.4.0
Upgrading from Oracle Utilities Application Framework V4.3.0.2.0 to V4.3.0.4.0
Upgrading from Oracle Utilities Application Framework V4.3.0.3.0 to V4.3.0.4.0
Upgrading from Oracle Utilities Application Framework V4.3.0.4.0 to V4.3.0.5.0
Upgrading from Oracle Utilities Application Framework V4.3.0.5.0 to V4.3.0.6.0
Upgrading from Oracle Utilities Application Framework V4.3.0.6.0 to V4.4.0.0.0
Upgrading from Oracle Utilities Application Framework V4.4.0.0.0 to V4.4.0.2.0
Upgrading from Oracle Utilities Application Framework V4.4.0.2.0 to V4.4.0.3.0
Upgrading from Oracle Utilities Application Framework V4.4.0.3.0 to V4.5.0.0.0
Upgrading from Oracle Utilities Application Framework V4.5.0.0.0 to V4.5.0.1.1
Oracle Application Framework System Table Guide
About the Application Framework System Tables
System Table Standards
Guidelines for System Table Updates
Business Configuration Tables
Development and Implementation System Tables
System Table List
Oracle Utilities Smart Grid Gateway Release 2.5.0.1.1 Database Administrator’s Guide
