Technical Implementation Of Printing Statements In Batch
The batch process that extracts statement information (known by the batch control ID of STMDWLD ) reads all statements in a given run number that are marked with its batch control ID. For each statement, it creates numerous records on a flat file. These records contain the information that is merged onto your statements.
The base package example of this process (known by the batch control ID of STMDWLD) simply calls the extract algorithm on the statement route type to format the information placed onto the flat file. Refer to Statement Route Types Control The Information On Statements for more information.
If your software doesn't support online statement images. The algorithm that formats statement extract records that's plugged
in on statement route type serves two purposes: 1) it formats the
records used to construct online images of a statement, and 2) it
formats the records downloaded to your statement print software in
batch. If your statement print software does not support the rendering
of statement images real time, there is no need to create an extract
algorithm. Rather, you should simply develop your own download process
that both formats the extract records and downloads them (and then
specify this batch process on your statement route type).
