Prerequisites
To setup the offset request feature, you need to do the following:
Define the required offset adjustment types where the A/P Request Type Code field is not set to REFUND.
Define a default offset amount algorithm using the C1-OFST-AMT algorithm type.
Assign the C1-OFSRQ To Do type to a To Do role whose users must receive a To Do while submitting an offset request for approval.
Assign the C1-OFSSB To Do type to a To Do role whose users must not approve an offset request.
Define the required offset request types in the system.
Define the required characteristic types where the characteristic entity is set to Offset Request Type.
Define the required characteristic types where the characteristic entity is set to Offset Request.
Define the values for the CAN_RSN_CD_FLG lookup field.
Set the parameters of the C1-UPD-FUND, C1-DFRUNAPLY, C1-WTBS-CRBL, and C1-OFST-DIST algorithms.
Define the status reasons for the Rejected and Unapplied Offset statuses of the C1-OffsetRequest business object in the Status Reason screen.
Set the Allow Offsetting Across Persons option type of the C1-OFFSETREQ feature configuration.
Define the required exchange rates in the system.
Define a currency conversion algorithm for bill segments using the C1_CURALGBS or C1_EXCRTBS algorithm type.
Attach a currency conversion algorithm to the Currency Conversion For Bill Segments algorithm spot of the required divisions.
Define a currency conversion algorithm for adjustments using the C1_CURALGAD or C1_EXCRTAD algorithm type.
Attach a currency conversion algorithm to the Currency Conversion For Adjustments algorithm spot of the required divisions.
Set the batch control type of the Offset Request Periodic Monitor (C1-OFSRQ) batch to Timed and define the following attributes:
Time Interval
Timer Active
User ID
Batch Language
Email Address
For more information about the Offset Request Periodic Monitor (C1-OFSRQ) batch, see Oracle Revenue Management and Billing Batch Guide.
Related Topics
| For more information on... | See... |
| How to setup the C1-OFFSETREQ feature configuration | Setting the C1-OFFSETREQ Feature Configuration |
| C1-OFST-AMT algorithm | C1-OFST-AMT |
| C1-UPD-FUND algorithm | C1-UPD-FUND |
| C1-DFRUNAPLY algorithm | C1-DFRUNAPLY |
| C1-WTBS-CRBL algorithm | C1-WTBS-CRBL |
| C1-OFST-DIST algorithm | C1-OFST-DIST |
| C1_CURALGBS algorithm | C1_CURALGBS |
| C1_EXCRTBS algorithm | C1_EXCRTBS |
| C1_CURALGAD algorithm | C1_CURALGAD |
| C1_EXCRTAD algorithm | C1_EXCRTAD |
