Recipe Details
Table 13-1 Recipe Details Fields
Field Description
Name (Required) Enter the name of the recipe (up to 100 characters).
Recipe Type (Required)
Select the Recipe Type.
If you select Production Recipe, COGS and Asset accounts must be defined. These accounts default from the selected Recipe Group but can be changed if needed.
Recipe Group (Required)
Select the Recipe Group.
Click the Add button to add a new Recipe Group.
COGS Account If you selected Production Recipe, the COGS Account is required. By default, this information is based on the selected Recipe Group. You can change this information if needed.
Asset Account If you selected Production Recipe, the Asset Account is required. By default, this information is based on the selected Recipe Group. You can change this information if needed.
Subsidiary (Required)
Select the subsidiaries allowed to access and use this recipe. The selection affects the list of ingredients.
Include Children
Select this option to make the recipe available for child records of the selected subsidiary above. The selection affects the list of ingredients.
Available for All Locations Select this option to make the recipe available for all locations within the selected subsidiary above.
Restrict to Locations Select the locations allowed to access and use this recipe, if not available for all locations. The selection affects the list of ingredients.
Yield Quantity
Enter the total yield quantity.
See Yield Calculation and Portions below for an example using the yield calculation.
Yield Unit
Select the unit for the entered quantity. The available units are Kilogram, Liter, and Each. This selection determines which units are available for the Portion UOM.
Portion Size
Enter the size of one portion.
Portion UOM
Select the unit of a portion. The available units depend on the previously selected Yield Unit:
  • Yield Unit: Each > Portion UOM: Each (locked)
  • Yield Unit: Kilogram > Portion UOM: All units associated with Kilogram
  • Yield Unit: Liter > Portion UOM: All units associated with Liter
Number of Portions
This number is auto-calculated based on the numbers entered previously.
Consider the following rules:
  • Recipe Yield / Portion Size = Number of Portions
  • Number of Portions × Portion Size = Recipe Yield
Cost of Sales The accumulated cost of sales based on the recipe ingredients is displayed here.
Recipe Image Click the Add button and select an image file to attach to this recipe. This function also allows you to upload image files to the file cabinet.
Recipe Description Enter the recipe description (up to 500 characters).
Yield information is displayed in the Recipe Details section. Yield calculation is important when creating recipes for a larger number of portions and using a single portion in other recipes.
For example, a recipe is created for 20 marinated steaks, with each portion/steak weighing 250 g after preparation.
  1. Create a sub-recipe for the marinade required for the 20 steaks and add it to the main recipe.
  2. Add the meat required for the 20 steaks to the recipe (for example: 20 × 250 g = 5 kg).
  3. Since the marinade is not included in the final weight, the values should be defined as follows:
    • Yield Quantity: 5,000
    • Portion Size: 250
    • Portion UOM: Gram
    • Number of Portions: 20 (automatically calculated based on the values entered above)
