Givex Processor
The Generic Stored Value Card (SVC) Processor is an extension to the XProcessor Extension Application. It provides access to any gift card vendor that supports the Oracle MICROS SVC Host Message Specification. The processor communicates with a vendor host adapter, which then communicates with the vendor's host system using a vendor-specific protocol. Givex is currently the only vendor that uses this specification.
Figure 49-5 Generic SVC/Givex Processor Data Flow
Setting up the Givex Processor consists of downloading and installing
a vendor host adapter/driver to a workstation, and adding or modifying
records in the following EMC modules:
Content
Discounts
Page Design
Service Charges
Tender/Media
If you are an existing Givex customer, you can continue using your Givex Processor configuration, but you must be using the latest release package, which is Version 2.2.5.122.
- Configuring the Givex Tender/Media Record
- Configuring the Givex Service Charge Record
- Configuring the Givex Processor and Content Files
- Configuring the Givex Processor Address and Port
- Creating Givex Processor Operations Buttons
- Givex Host Adaptor
- Configuring the Givex Host Adaptor
Parent topic: XProcessor Gift Cards and Plug-ins
