Overview of monitoring and editing synchronization connections
CIS Administration enables you to monitor the status of synchronization connections, to view detailed information about individual synchronization jobs, and to edit the transactions that are saved to the CIS database. You monitor synchronization connections from the Sync Connections tab of the CIS Synchronization Adapter page. From this tab, you can view a list of synchronization connections defined for your environment, and you can select specific synchronization connections to monitor and manage.
From the Sync Connections tab, you can:
- View a summary of synchronization connection transactions and the status of synchronization connection jobs.
- View details about transactions for a specific synchronization connection job.
- View a history of all jobs for a specific synchronization connection.
- View error details for the last failed synchronization job.
- View error details for previously failed synchronization jobs.
- View and edit transaction XML for a synchronization job.
- Edit New Mapping options.
- View general information about a synchronization connection.
- View and change settings for a synchronization connection.
For additional assistance in monitoring synchronization status, CIS Administration includes a notification feature. When you set up email notifications, you can specify the addressees who should receive email notification when a synchronization fails or a synchronization processor goes offline. For more information, see Managing email notifications.
