Reinsurance
Reinsurance Setting
An enrollment product type can have one or more reinsurance settings. A reinsurance setting specifies the percentage that should be paid out to a reinsurer.
Field Description
Enrollment Product Type
The enrollment product type for which the reinsurance setting is applied
Organization
The organization that acts as a reinsurer
Percentage
The percentage of the premium that has to be payed to the reinsurer
Alias Code
The alias code for reinsurance (this is transferred to OHI Claims in the enrollment response if reinsurance is applied)
Start Date
The start date of the reinsurance setting
End Date
The end date of the reinsurance setting
Constraints:
  • It is not allowed to have an overlap in time validity for reinsurance settings with the same enrollment product type, organization and alias code
Reinsurance Exclusion
A reinsurance setting can have one or more reinsurance exclusions. A reinsurance exclusion specifies the premium types, adjustments and surcharges that are excluded from the base amount used for the reinsurance payment calculation.
Field Description
Reinsurance Setting
The reinsurance setting for which the exclusions apply
Premium Schedule Type
The excluded premium schedule type
Schedule Definition
The excluded schedule definition
Note that not all schedule definitions are relevant to reinsurance, for example, schedule definitions that belong to the "Fee" schedule definition type have no relevance within the context of a reinsurance exclusion.
