Setting Up Data for the Store Connect Module
Purpose: Follow the steps below at Order Broker screens when completing data setup for the Store Connect module as part of Order Broker configuration.
Routing Engine setup required first: Complete the steps below after you have completed Setting Up Data for the Routing Engine Module.
Store Connect does not support partial status updates based on the Allow Partial Updates setting at the Preferences screen.Before you start: When setting up data, you typically log into Order Broker as the default admin user. If you are setting up data for an additional organization in Order Broker and are not using the default admin user login, you need full authority to all secured features based on the roles assigned to the user profile. See the Role Wizard and the User Profile Configuration screen for background.
In this topic:
| Step | Procedure |
| Create the Store Connect
Default System. Identify the system for Store Connect locations. Required? This step is required if your Store Connect system is different from a POS system that you set up through Setting Up Data for the Routing Engine Module. Important: You need to use the Store Connect Preferences screen to confirm your settings after setting up the Store Connect system. See Set up Store Connect preferences for your organization. |
Inventory Export: You can also set up and use the Fulfilled Inventory Export at the Schedule Jobs screen. |
| Create a location
type for Store Connect locations. About location types: Types must be 1 of 3 categories (store, vendor, or warehouse) and further identify a group of locations based on the system to which they belong, such as Store Connect. Required? This step is required if your Store Connect location type is different from the POS location type that you set up through Setting Up Data for the Routing Engine Module. |
Create Store Connect locations. Required? This step is required if your Store Connect locations are different from the POS locations that you set up through Setting Up Data for the Routing Engine Module. |
Set up preferences for Store Connect locations. This step is required. |
Preferences: After creating Store Connect locations, you need to use the Preferences screen to apply preference settings to the new locations, including the types of orders that they support. A Store Connect location must be flagged to support at least one type of order (delivery or pickup), or there must be at least one open order for the store, in order for store associates to be able to log into the store location. See the Fulfillment Tab for more information. |
preferences for your organization. About Store Connect preferences: Use the Store Connect Preferences screen to set up information, such as specifying:
| Specify the logo to display in Store Connect. |
users. About Store Connect users: A Store Connect user has authority only to Store Connect screens. |
Use the Identity Cloud User Synchronization job to import users from IDCS or OCI IAM. Store Connect users need to have the OBCS_Store_User role assigned in IDCS or OCI IAM. See the Identity Cloud User Synchronization for more information. Assign locations: You can assign a store associate to locations at the Edit Store Associate User Profile, or use this screen to edit other information about the store associate. A store associate must be assigned to at least one location in order to use Store Connect. Note: When you make any changes in IDCS or OCI IAM to an existing store associate’s user role, the changes do not take effect until the user logs in. For example, if the associate is currently logged into Store Connect and you remove the OBCS_Store_User role, the associate can continue working in the current, open session. |
| Create reason codes. About reason codes: You can set up reason codes that the associate uses:
| Create boxes. About boxes: Create one or more boxes to define the dimensions of a box used to ship one or more items using an automated shipping system. If the store associate confirms shipment of items on delivery orders through integration with an automated shipping system, the system requires you to select the box size on the Estimated Weight and Dimensions window. The store associate can select one of the predefined box sizes or manually define the length, width, and height of the box. |
| Set up carriers. |
