About this Guide
Refer to the following chapters for the information you need to use the Oracle Retail Xstore Office components:
  • Roles, Users, and Security Access - This chapter provides information about creating user security roles and managing user access to Oracle Retail Xstore Office.
  • System Management - This chapter provides information about the features used to manage the Oracle Retail Xstore Office application, including setting up the system configuration rules and paths for Oracle Retail Xstore Office itself.
  • Profile Management - This chapter provides information about creating and maintaining profile groups and elements for stores, creating and maintaining the personalities that determine the prioritized profile elements for configuration overrides, and creating and maintaining the store landscapes used for machine (register) configurations. After setting up the groups/elements and personalities/landscapes, this chapter explains how to use the information to create Store Personalities for your stores which allows you to easily maintain portions of your configuration paths.
  • Configurator - This chapter provides information about creating, maintaining, and deploying Oracle Retail Xstore Point-of-Service configuration changes selectively, or globally across the entire organization.
  • Data Management - This chapter provides information about creating, maintaining, and deploying Oracle Retail Xstore Point-of-Service data changes selectively, or globally across the entire organization.
  • Deployment Management - This chapter provides information about using Deployment Manager to upload files for deployment and to track the status of all configuration, data, and file deployments.
  • Reports - This chapter provides information about running and viewing any of the Oracle Retail Xstore Point-of-Service reports against the Xcenter (central) database.
  • Support Tools - This chapter provides information about using the Support Tools component to view issues taking place at the store level, to set up email alerts to be sent to the appropriate personnel when any issues occur, and to compile the PosLog data from within Oracle Retail Xstore Office and save it as a file to a specified location or to rebroadcast the PosLog data.
  • Appendix: About Deployments - This appendix explains how deployments are created by Oracle Retail Xstore Office and applied by Oracle Retail Xstore Point of Service and Oracle Retail Xenvironment.
  • Appendix: Personality Maintenance and Config Paths - This appendix explains how the store personalities set up in Oracle Retail Xstore Office are used to create the config path properties.
  • Appendix: User Interface Configurations - This appendix explains how Oracle Retail Xstore Office can be "personalized" by adding a background image, changing the color scheme, and configuring the panel display order and content.
  • Appendix: Enrollment with Cloud Services, - This appendix describes how to enroll Xstore Office On-Premise with cloud services.
  • Glossary - This glossary lists and defines many terms and their definitions used in this guide.
