Explainer
The Explainer module tells the customer what data is used to calculate the Normative Comparisons and provides ways to improve or correct the data used in the module by completing or updating the Digital Self Service - Energy Management Home Energy Analysis. The module includes a brief explanation of how the comparison is calculated, as well as URL and QR code options to go from their paper report to the Home Energy Analysis. The goal of this module is to reduce negative customer sentiment by providing transparency around the similar home comparison and offering a simple and quick way for customers to update their information if it is not accurate.
Appears in: Progress Report, Limited Income Report, Time of Use Report, Solar Report, Electric Vehicle Report, Peak Focused Report
Requirements
Utility Requirements
Category Description
Required Cloud Service Oracle Utilities Opower Energy Efficiency Cloud Service
Scale Not applicable.
Customer Requirements
Billing Frequency Monthly, bi-monthly, or quarterly
Data Delivery Frequency Daily, monthly, bi-monthly, or quarterly.
Data Requirements A minimum of one historical bill.
Data History A minimum of one historic bill.
Data Coverage All billing and data delivery frequencies are supported.
Supported Fuels Progress Report, Limited Income Report, and Time of Use Report: Electric-only, gas-only, dual fuel. Solar Report, Electric Vehicle Report: Electric-only, dual fuel. Peak Focused Report: Electric-only.
Limitations
  • Module replacement: To ensure clear messaging, an additional promotion module should not be run in place of this module.
User Experience
This section describes the user experience for each report type.
Progress Report, Limited Income Report, Time of Use Report, and Peak Focused Report
This section describes the user experience of the Explainer module for the Progress Report, Limited Income Report, Time of Use Report, and Peak Focused Report.
Image of Explainer module's design for the Progress Report, Limited Income Report, and Time of Use Report
Header: Informs the customer either that they can learn more about how their comparison is calculated or that their comparison is accurate based on their completed Home Energy Analysis.
Body Text: Explains that the customer's home profile is used to identify similar homes with comparable square footage and heating fuel type within a defined distance. Details such as the number of homes, home type, location radius, and heating source are dynamic and vary by customer. Utilities may choose to show fewer criteria, but at least one must be included.
Call to Action: Provides two ways for customers to update their home profile:
Link: Directs customers to the Digital Self Service Energy Management web portal, where they can sign in and complete the Home Energy Analysis.
QR Code: Encourages customers to take a short home energy survey. By scanning their unique code, they can quickly move from their paper report to either an authenticated or unauthenticated landing page, depending on the utility's setup.
Solar Report
The Solar Welcome Report includes a net explainer version of the Explainer module. The goal of the module is to educate customers about net energy, while reinforcing the insights shown in the neighbor comparison graph.
Welcome Progress Report
This section describes the user experience of the Explainer module for a customer with dual fuel and a positive comparison state in the Solar Welcome Report.
Image of Net Explainer module for a Solar Report of a customer with dual fuel and a positive comparison state
Header: The header defines net energy.
Explainer :The explainer reinforce the insights shown in the report's three-bar neighbor comparison. The text varies based on the customer's comparison state and fuel type.
Image: The left image matches the customer's current net negative or net positive state. The right image of the opposite state. The image is designed to reinforce the explainer definition state. For example, a house with a red door is paired with the positive next energy positive explainer to indicate that more energy is used than the solar panels produced. An image of sun shining over a house with a green door and roof line is paired with the negative net energy explainer to reinforce that in a negative net energy state the solar panels produce more energy than the customer used.
Solar Progress Report
This section describes the user experience of the Explainer module for the Solar Report of a customer with an incomplete Home Energy Analysis.
Image of Explainer module for the Solar Progress Report of a customer with an incomplete home energy analysis
Header: The header is intended to either notify the customer that they can learn more about how their comparison is determined or notify them that their comparison is accurate as a result of their completing the Home Energy Analysis.
Body Text: The body text explains that the customer's home profile is used to identify similar solar homes of roughly the same square footage and with the same heating fuel type within a set distance. The number of homes, home type, location radius, and heating source information is all dynamic and varies by customer.
Image: The image reinforces that the customer's insights take into account their solar energy use.
Call to Action: Customers are provided with two convenient ways to update the home profile:
  • Link: A link located below the body text that redirects the user to the Digital Self Service - Energy Management web portal, where they can sign in and complete the Home Energy Analysis.
  • QR Code: The QR code prompt encourages customers to take a five-minute home energy survey. Customers can scan their unique code with their phone and immediately transition from their paper report to either the authenticated or unauthenticated landing page, depending on which one is set up for the utility.
The Electric Vehicle Report explainer module is designed to help educate the customer about how their home energy use and home characteristics contribute to their comparison. The module header, body text, and call to action vary depending on whether or not the customer has completed their Home Energy Analysis.
This section describes the user experience of the Explainer module for the Electric Vehicle Report of a customer who has not yet completed their Home Energy Analysis.
Image of Electric Vehicle report of a customer who has not yet completed their home energy analysis
Header: The header notifies the customer that they can learn more about how their report works.
Body Text: The body text explains that the report uses the customer's energy use patterns and home characteristics to generate insights, and encourages them to complete the Home Energy Analysis for more a more accurate comparison.
Image: The image of an electric vehicle charging at home is used to visually reinforce that the customer's electric vehicle charging is taken into account in the report comparison and insights.
User Experience Variations
The user experience varies for customers depending upon their service types, available data, costs, and locale. Note that the following list indicates the primary user experience variations, not all possible variations.
Home Energy Analysis Completion
The Explainer module and QR code text for the Progress Report, Limited Income Progress Report, Time of Use Progress Report, Solar Progress Report, and Electric Vehicle Report vary depending on the customer's Home Energy Analysis completion.
  • If the customer recently completed the Home Energy Analysis: The body text confirms what is known about their home that goes into the calculation, and then prompts them to go online in order to see their energy use breakdown.
  • If the customer has not completed the Home Energy Analysis: The body text tells the customer that the report and insights are based on their energy use patterns and home characteristics, and encourages them to take the Home Energy Survey to get personalized energy-saving tips and a more accurate home comparison.
  • If the customer already received the "Home Energy Analysis Recently Completed" copy state: Each subsequent report confirms what is known about their home that goes into the calculation, and then prompts them to go online in order to see their energy use breakdown.
