Skip Headers
Oracle® Data Provider for .NET Developer's Guide
12c Release 1 (12.1.0.1.0)
E41125-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
Changes in This Release for Oracle Data Provider for .NET
This preface contains:
Changes in Oracle Data Provider for .NET Release 12.1
The following are the changes in Oracle Data Provider for .NET for Release 12.1.
New Features
The following features are new in this release:
  • ODP.NET, Managed Driver
    ODP.NET now includes a fully managed provider version, which is 100% native .NET code. ODP.NET, Managed Driver includes nearly all the features of ODP.NET, Unmanaged Driver and uses the same application programming interface. This makes migrating existing ODP.NET applications to ODP.NET, Managed Driver easier.
    With ODP.NET, Managed Driver, it is easier and faster to deploy ODP.NET. There are fewer assemblies, as few as one to deploy, which also makes patching straightforward, and the install size is smaller at less than 10 MB. Only one ODP.NET, Managed Driver assembly is necessary whether you are using 32-bit or 64-bit .NET Framework. Side-by-side deployment with other ODP.NET versions is simple since there are no unmanaged assemblies to account for. As a fully managed provider, ODP.NET can better integrate with Code Access Security and ClickOnce deployment.
    See also "Installing Oracle Data Provider for .NET, Managed Driver" .
  • Support for Pluggable Database
    Pluggable Databases (PDBs) enable an Oracle database to contain a portable collection of schemas, schema objects, and nonschema objects that appears to ODP.NET as a separate database. ODP.NET can seamlessly use PDBs.
    PDBs allow fast database provisioning, fast database redeployment by unplugging and plugging in existing databases, and quick patching or upgrading many databases at the cost of doing it once or by unplugging a PDB and plugging it into a different container database. A machine can run more database instances in the form of PDBs than as individual, monolithic databases. It is also easier to separate application administrator duties from the Oracle system administrator duties.
  • Support for Auto Increment Identity Column
    Oracle Database 12c Release 1 (12.1) introduces an auto increment identity column. Oracle Data Provider for .NET (ODP.NET) 12.1 and higher releases support interacting with this column data. Identity columns are generally used to uniquely identify rows in a table when there is no other natural primary key constraint.
    An identity column simplifies .NET development for applications with no natural primary key and eases application migration from databases that have an identity column.
  • Support for Character Data Types Extended to 32 KB
    Starting with Oracle Database 12c Release 1 (12.1), Oracle Data Provider for .NET (ODP.NET) now supports the VARCHAR2, NVARCHAR2, and RAW data types up to 32 KB in size. No code changes are required to use the larger data types.
    By being able to store more data, developers can use these data types more frequently, providing programming flexibility. In addition, SQL Server to Oracle Database application migration is easier with these new data type sizes.
  • Boolean Data Type
    Oracle Database 12c Release 1 (12.1) introduces a new PL/SQL Boolean data type, which ODP.NET can store as an OracleBoolean data type. Booleans store TRUE or FALSE values.
    The ODP.NET OracleBoolean data type eases parameter binding and data type mapping setup with Boolean values.
  • Enhanced Implicit REF Cursor Binding
    In Oracle Database 12c Release 1 (12.1), ODP.NET 12c can retrieve the results of a SELECT statement run in PL/SQL without an explicit target nor REF CURSOR data type. ODP.NET retrieves result sets from stored procedures implicitly without declaring a return type. It is no longer necessary to declare REF CURSOR metadata in a .NET configuration file, except when using Entity Framework or user-defined types.
    This capability simplifies using implicit Oracle result sets. In addition, it eases migration to the Oracle database from other vendor databases that use a similar feature.
  • Return Number of Rows Affected from Each Input in Array Binding Operations
    When using array binding to execute multiple DML statements, Oracle Data Provider for .NET (ODP.NET) now provides an array that lists the number of rows affected for each input value from the bound array, rather than just the total number of rows affected. This information provides more detailed feedback for the application developer. To retrieve the row count, ODP.NET can call the OracleCommand.ArrayBindRowsAffected property.
    With more detailed feedback on the array bound DML execution, the developer can better evaluate the query's efficiency and whether the data changes were correctly applied.
  • Support for APPLY Keyword
    Language Integrated Query (LINQ) is a .NET querying language. At runtime, LINQ is translated into native database SQL before it can query the database. In some circumstances, LINQ uses the non-standard APPLY keyword in its SQL translation for retrieving lateral views. Oracle Database and ODP.NET support the APPLY keyword in Oracle Database 12c Release 1 (12.1) to more fully support LINQ.
    This feature allows the occasional LINQ query that uses SQL APPLY to work seamlessly with ODP.NET and Oracle Database for lateral views.
  • Transaction Guard Support
    Transaction Guard in Oracle Database 12c Release 1 (12.1) preserves transaction commit outcomes for ODP.NET 12c applications during planned and unplanned outages, preventing applications from repeatedly submitting the same transaction. Applications use a new logical transaction identifier to determine the last open transaction's outcome in a database session following an outage. With the known outcome, the application can confidently determine whether to resubmit the transaction or not. Without Transaction Guard, applications that retry operations following outages by committing duplicate transactions can cause logical corruptions.
    Transaction Guard preserves the commit outcome for every transaction and makes it available to ODP.NET applications. It allows ODP.NET developers to maintain at-most-once transaction execution.
  • Recoverable Error Detection and Recovery
    After an Oracle Database 12c Release 1 (12.1) failure, ODP.NET 12c can determine if a failed transaction is recoverable or not. ODP.NET returns the OracleException IsRecoverable property indicating whether the transaction is recoverable. If true, the application can retry the transaction.
    This feature makes determining whether failed transactions are recoverable easier, allowing applications to proceed quickly to the next step in the recovery process.
  • Support for Faster and Planned Database Outage
    In Oracle Database 12c Release 1 (12.1), a database being brought offline automatically alerts ODP.NET applications of the impending downtime. ODP.NET will then stop allocating new connections and close connections returned to the pool from that particular instance.
    This feature enables databases to be brought offline more quickly and minimizes potential end user disruptions by disallowing new ODP.NET connections to databases being brought offline.
  • Support for Oracle Notification Service
    Oracle Notification Service (ONS) is a publish and subscribe service for communicating Fast Application Notification (FAN) events. ODP.NET receives fast connection failover and load balancing messages from the database server through ONS. Previously, ODP.NET used Oracle Advanced Queuing (AQ) as its FAN publish and subscribe service.
    Because ONS is a memory-based service, it delivers messages faster than AQ. Using ONS, Oracle consolidates the publish and subscribe service that all Oracle data access drivers use.
  • Support for Global Data Services
    Global Data Services (GDS) is a capability of Oracle Database 12c that extends the concept of services, which previously only was available in Oracle RAC, to a globally distributed configuration that can include a combination of Oracle RAC, Oracle Data Guard, and Oracle GoldenGate. This allows services to be deployed anywhere within this globally distributed configuration, supporting load balancing, high availability, database affinity, and so on with ODP.NET.
    ODP.NET applications can now more efficiently use database resources on a global basis to improve performance and availability. Applications that utilize the Oracle RAC concept of services can now extend the same benefits of automatic workload management to their Oracle Data Guard and Oracle GoldenGate configurations. Similarly, Oracle Data Guard and Oracle GoldenGate customers can now fully utilize the benefits of services and automatic workload management for their replicated configurations.
  • Transaction and Connection Association
    Connections associate with System.Transactions transactions when they enlist either implicitly through enlist=true connection string attribute, or explicitly through OracleConnection.EnlistTransaction() method. A connection in ODP.NET now, by default, detaches from a transaction only when the connection object is closed or when the transaction object is disposed.
    In earlier ODP.NET releases, the connection would get detached from a transaction under the conditions mentioned earlier and when the transaction was complete (committed, aborted, or timed out). When the transaction timeout elapses before the transaction completes, the connection unbinds itself from the transaction and all subsequent operations on this connection execute in AutoCommit mode. Any operations prior to the timeout roll back, but operations performed after the timeout commit. The new transaction unbinding default behavior also alerts users with an exception if transactions time out and subsequent operations execute on this connection before the transaction is disposed. This new behavior provides a consistent transactional experience for the end user, even when a timeout occurs.
    See also "LegacyTransactionBindingBehavior" for more information.
Changes in Oracle Data Provider for .NET Release 11.2.0.3.20
The following are changes in Oracle Data Provider for .NET for Release 11.2.0.3.20.
New Features
The following feature is new in this release:
  • .NET Framework 4.5 and Entity Framework 5 Support
    Oracle Data Provider for .NET supports .NET Framework 4.5 and Entity Framework 5.
    See also "System Requirements" for more information.
New Features
  • ADO.NET Entity Framework and LINQ to Entities Support
    ODP.NET now includes support for the ADO.NET Entity Framework and LINQ to Entities. Entity Framework is a framework for providing object-relational mapping service on data models. Entity Framework addresses the impedance mismatch between the relational database format and the client's preferred object format. Language Integrated Query (LINQ) defines a set of operators that can be used to query, project, and filter data in arrays, enumerable classes, XML, relational databases, and other data sources. One form of LINQ, LINQ to Entities, allows querying of Entity Framework data sources. ODP.NET supports Entity Framework such that the Oracle database can participate in object-relational modeling and LINQ to Entities queries.
    Entity Framework and LINQ provides productivity benefits for the .NET developer. It abstracts the database's data model from the application's data model. Working with object-relational data becomes easier with Entity Framework's tools. Oracle's integration with Entity Framework and LINQ enables Oracle .NET developers to take advantage of all these productivity benefits.
    See "ADO.NET Entity Framework and LINQ to Entities" for more information on ODP.NET support for the ADO.NET Entity Framework and LINQ to Entities.
  • WCF Data Services and OData
    Windows Communication Foundation (WCF) Data Services enable developers to create services that use the Open Data Protocol (OData) to expose and consume data over the internet by using the semantics of representational state transfer (REST). OData exposes data as resources that are addressable by URIs. OData uses Entity Data Model conventions to expose resources as sets of entities that are related by associations. ODP.NET supports Entity Framework, and can expose its data through OData and WCF Data Services.
    WCF Data Services and OData facilitate creating flexible data services from any data source and naturally integrating them with the Web. All data sources, including Oracle databases, can be used by the same data sharing standard making data exchange more interoperable.
  • Implicit REF CURSOR Parameter Binding
    ODP.NET can bind REF CURSOR parameters for stored procedures without binding them explicitly. To do so, the application must provide the REF CURSOR metadata as part of the .NET configuration file. This feature allows Entity Framework Function Import to call Oracle stored procedures and return REF CURSOR result sets. ODP.NET can also update the database's data with a DataSet or DataTable obtained through a REF CURSOR.
    In Entity Framework, result set parameters are generally not declared. By supporting the implicit REF CURSOR parameter, ODP.NET more closely integrates with typical Entity Framework usage scenarios.
    See "Implicit REF CURSOR Binding" for detailed information on implicit REF CURSOR parameter binding.
Changes in Oracle Data Provider for .NET Release 11.2.0.2
The following are changes in Oracle Data Provider for .NET for Release 11.2.0.2.
New Features
  • 64-bit ODP.NET XCopy for Windows x64
    Now available for Windows x64 systems, ODP.NET XCopy provides system administrators with a smaller client install size than the standard ODP.NET client, and is easier to configure. ODP.NET XCopy simplifies embedding ODP.NET in customized deployment packages.
  • TimesTen In-Memory Database Support
    Oracle Data Provider for .NET enables fast data access for any .NET application, such as C# .NET, Visual Basic .NET, and ASP.NET, to TimesTen In-memory databases. ODP.NET support for TimesTen includes the classes, enumerations, interfaces, delegates and structures of the Oracle.DataAccess.Client and Oracle.DataAccess.Types namespaces. ODP.NET supports TimesTen Release 11.2.1.6.1 or later on Microsoft Windows 32-bit and 64-bit platforms. TimesTen can be used with .NET Framework 2.0, 3.0, 3.5, and 4 with Microsoft Visual Studio 2005 or later.
    See Also:
    The latest TimesTen In-Memory Database documentation and resources can be accessed from:
    http://www.oracle.com/technetwork/database/timesten/index.html
Changes in Oracle Data Provider for .NET Release 11.2.0.1.2
The following are changes in Oracle Data Provider for .NET for Release 11.2.0.1.2.
New Features
  • Support for Microsoft .NET Framework 4
    ODP.NET for .NET Framework 4 supports .NET Framework 4 and the .NET Framework 4 Client Profile.
New Features
  • End-to-End Tracing: ClientInfo Property
    ODP.NET now supports the ClientInfo write-only property, in addition to the ActionName, ClientId, and ModuleName properties, on the OracleConnection object. This property specifies the client information for the connection.
    The ClientInfo property is an end-to-end tracing attribute that can be set on the client or middle tier. This attribute is propagated to the database server whenever the next server round-trip happens. This reduces the added overhead associated with an independent database round trip. Using the ClientInfo property is helpful in tracking database user activities and debugging applications.
  • Edition-Based Redefinition
    Edition-based redefinition enables you to upgrade the database component of an application even while the .NET application is being used. This minimizes or eliminates downtime for the application.
Changes in Oracle Data Provider for .NET Release 11.1.0.7.20
The following are changes in Oracle Data Provider for .NET for Release 11.1.0.7.20.
New Features
  • Self-Tuning for Applications
    Based on run-time sampling, ODP.NET dynamically adjusts statement cache size to provide better application performance. Self-tuning also takes into account memory usage on the client machine in order to prevent excessive memory usage. Self-tuning improves ODP.NET performance, reduces network usage, and decreases server CPU and client CPU activity.
    See Also:
    "Self-Tuning"
  • Faster Data Retrieval and Less Memory Usage
    Retrieving data using OracleDataReader or populating a DataSet from an OracleDataAdapter is now faster.
    ODP.NET reuses the same fetch array buffer for statements executed non-concurrently, saving on memory usage. The fetch array buffer stores data retrieved from the database.
    No code changes are necessary to use these features. These features provide better performance and scalability for ODP.NET applications.
  • Oracle Streams Advanced Queuing Support
    ODP.NET supports access to Oracle Streams Advanced Queuing (AQ). AQ provides database-integrated message queuing functionality to store messages persistently, propagate messages between queues on different machines and databases, and transmit messages using Oracle NET services, HTTP, HTTPS and SMTP.
    ODP.NET can access all the operational features of AQ, such as enqueue, dequeue, listen and notification. Oracle Developer Tools for Visual Studio can administer and manage AQ resources.
  • Promotable Local Transaction Support
    Distributed transactions require the orchestration of application, transaction coordinator, and multiple databases. Local transactions only require an application and a single resource manager, or database. Local transactions have less of an overhead when compared to distributed transactions.
    It may be difficult to determine whether a transaction will be local or distributed at design time. Developers are forced to design applications for distributed transactions, even if local transactions are used most of the time. This situation leads to more resource usage than necessary at run time.
    Promotable local transactions allow all transactions to remain local until more than one database is brought into the transaction. At this point, the transaction is promoted to a distributed transaction so that it can be managed by the transaction coordinator. This provides a better utilization of system resources. This feature is supported with Oracle Database 11g release 1 (11.1.0.7) and higher.
  • ODP.NET Security Enhancements
    ODP.NET makes use of the OraclePermission class to enforce imperative security. This helps ensure that a user or application has a security level adequate for accessing data.
  • Callbacks for HA Event Notifications
    ODP.NET can register for Oracle High Availability (HA) events when "ha events=true" is specified in the connection string. ODP.NET is then able to receive notifications on which database, service, host, or instance has gone down or come up. .NET developers can register a callback with ODP.NET to notify the application when one of these events occurs and subsequently execute an event handler, as needed.
  • Database Startup and Shutdown Operations
    Users with database administrator privileges can use the OracleDatabase class to startup or shutdown a database instance.
Changes in Oracle Data Provider for .NET Release 11.1.0.6.20
The following are changes in Oracle Data Provider for .NET for Release 11.1.0.6.20.
New Features
  • 32-bit ODP.NET XCopy
    Oracle XCopy provides system administrators with an ODP.NET client that is smaller in disk size than the standard ODP.NET client and is easily configurable. Oracle XCopy makes embedding ODP.NET in customized deployment packages much simpler.
    See Also:
    "XCopy"
  • Support for Oracle User-Defined Types
    ODP.NET has the ability to represent Oracle UDTs defined in the database as custom types in .NET applications.
  • Bulk Copy Operations
    ODP.NET supports the Bulk Copy operations to load a large amount of data efficiently.
  • Additional Connection Pool Optimizations for Oracle Real Application Clusters (Oracle RAC) and Oracle Data Guard
    ODP.NET now cleans up the connection pool when the database down event is received from Oracle RAC or Oracle Data Guard. This is in addition to the events that ODP.NET already cleaned up the connection pool for: node down, service member down, and service down events.
  • Windows-Authenticated User Connection Pooling
    Operating system-authenticated connections can now be managed as part of ODP.NET connection pools
  • Connection Pool Performance Counters
    ODP.NET publishes performance counters for connection pooling, which can be viewed using the Windows Performance Monitor.
  • End-to-End Tracing Attribute Support
    ODP.NET supports the ActionName, ClientId, ClientInfo, and ModuleName write-only properties on the OracleConnection object. These properties correspond to end-to-end tracing attributes that can be set on the client or middle-tier, and propagated to the database server whenever the next server round-trip happens. This reduces the added overhead associated with an independent database round trip. Using these attributes is helpful in tracking database user activities and debugging applications.
New Features
  • Performance Enhancements
    The following performance enhancements have been made:
    • Improved Parameter Context Caching
      This release enhances the existing caching infrastructure to cache ODP.NET parameter contexts. This enhancement is independent of database version and it is available for all the supported database versions. This feature provides significant performance improvement for the applications that execute the same statement repeatedly.
      This enhancement is transparent to the developer. No code changes are needed to use this feature.
    • Efficient LOB Retrieval with LOBS or SecureFiles
      When using LOBS or SecureFiles, this release improves the performance of small-sized LOB retrieval by reducing the number of round-trips to the database. SecureFiles is available with Oracle 11g release 1 or later database versions.
