If you do not want to use docker-ostk, you can install the Python OpenStack CLI clients manually on a host.
To install and run the Python OpenStack CLI clients requires Python 2, version 2.7 or later. Python 3 is not currently supported by the OpenStack CLI clients. To check which version of Python you have installed, use:
# python --version
Python 2.7.5You can install the packages needed to install the Python OpenStack CLI clients, either by using the Oracle OpenStack Extras Repository (Oracle Linux 7 only) or by using Software Collections (Oracle Linux 6 and 7). Use Software Collections if the host does not meet the Python 2 requirements.
This method for installing the OpenStack CLI clients is only for Oracle Linux 7 hosts.
Enable the required ULN channels or Yum repositories.
If you are installing the OpenStack CLI clients on an OpenStack target node, the required channels or repositories are enabled when you prepared the system, as described in Section 3.5, “Preparing Oracle Linux Nodes”.
If the system is registered with Unbreakable Linux Network (ULN), ensure the system is subscribed to the following channels:
ol7_x86_64_latest- Oracle Linux 7 Latest (x86_64)ol7_x86_64_openstack_extras- Extra development packages for Oracle OpenStack 3.0 on Oracle Linux 7 (x86_64)
If you are using Oracle Linux Yum Server:
Download the latest Oracle Linux Release 7 Yum Server repository file.
# curl -L -o /etc/yum.repos.d/public-yum-ol7.repo \ http://yum.oracle.com/public-yum-ol7.repo
Edit the
/etc/yum.repos.d/public-yum-ol7.repofile and enable the following repositories by settingenabled=1in the following sections:[ol7_latest][ol7_openstack_extras]
Install the packages to enable you to install the OpenStack CLI client packages.
# yum install gcc python-devel python-pip
Install the OpenStack CLI client using pip.
# pip install python-openstackclient
The OpenStack client is a common command-line client that enables you to run commands for various OpenStack project APIs using a single command and it is intended to replace the individual OpenStack project clients.
If the OpenStack client does not provide a command that you need, you can install the client for an individual OpenStack project:
projectclientThe available OpenStack project clients are:
ceilometer
cinder
glance
heat
ironic
magnum
murano
neutron
nova
swift
For example:
# pip install python-novaclient
CautionDo not install the keystone client, it does not support version 3 of the Keystone API. Use the OpenStack Client instead.
This method for installing the OpenStack CLI clients can be used with Oracle Linux 6 and 7.
For Oracle Linux 7, the
ol7_x86_64_latest,ol7_x86_64_optional_latestandol7_x86_64_SoftwareCollectionschannels.For Oracle Linux 6, the
ol6_x86_64_latestandol6_x86_64_SoftwareCollectionschannels.
Download the latest Oracle Linux Yum Server repository file.
For Oracle Linux 7:
For Oracle Linux 6:
# curl -L -o /etc/yum.repos.d/public-yum-ol6.repo \ http://yum.oracle.com/public-yum-ol6.repo
Edit the yum repository file and enable the following repositories by setting
enabled=1in the following sections:For Oracle Linux 7:
[ol7_latest][ol7_optional_latest][ol7_software_collections]
For Oracle Linux 6:
[ol6_latest][ol6_software_collections]
Install the
gccpackage and thepython27software collection.# yum install gcc python27
Start a bash shell with the
python27software collection enabled.# scl enable python27 bash
ceilometer
cinder
glance
heat
ironic
magnum
murano
neutron
nova
swift
For example:
Before you use OpenStack CLI clients, you usually need to set OpenStack environment variables to enable you to authenticate to Keystone. See Section 7.3, “Setting Environment Variables for OpenStack CLI Clients” for details.
If you are used Software Collections to install the OpenStack
CLI clients, you need to start a bash shell with the
python27 software collection enabled before
using a client:
To use an OpenStack client, use the syntax:
$openstack_clientopenstack_client_argument[ -h | --help ]
openstack_client An OpenStack CLI client, for example,
openstackornova.-
openstack_client_argument The argument for the OpenStack CLI client command, for example,
list.-
-h,--help Display syntax help.
For example:
$ nova list
For information about using OpenStack CLI clients, see http://docs.openstack.org/user-guide/cli.html.
To upgrade a client, include the
--upgrade option to the pip
install command:
# pip install --upgrade python-projectclient
