If your application uses the Fusion technology stack, you can use data controls to create charts. For more information, see "Creating Databound Charts" in Developing Fusion Web Applications with Oracle Application Development Framework.
This chapter includes the following sections:
The ADF DVT chart components are a set of visualizations for evaluating data points on multiple axes. They present a variety of forms that are useful in many ways, such as comparing results from two or more groups, showing stock information and presenting a pie chart comparison.
Charts display series and groups of data. Series and groups are analogous to the rows and columns of a grid of data. Typically, the rows in the grid appear as a series in a chart, and the columns in the grid appear as groups.
For most charts, a series appears as a set of markers that are the same color. Typically, the chart legend shows the identification and associated color of each series. For example, in a bar chart, the yellow bars might represent the sales of shoes and the green bars might represent the sales of boots.
Groups appear differently in different chart types. For example, in a stacked bar chart, each stack is a group. A group might represent time periods, such as years. A group might also represent geographical locations such as regions.
Depending on the data requirements for a chart type, a single data item might require one or more data values. For example, a scatter chart requires two values for each data marker. The first value determines where the marker appears along the x-axis while the second value determines where the marker appears along the y-axis.
The chart components include ten types of charts with one or more variations that you can use to display data. JDeveloper provides a Components window that displays available chart categories. Figure 23-1 shows the Components window for area, bar, bubble, combination, funnel, line, pie, scatter, spark and stock charts.
Figure 23-1 Components Window for Charts
When you select a chart category in the Components window, JDeveloper displays a dialog with descriptions about the available chart types to provide visual assistance when you are creating charts. Figure 23-2 shows the different area chart types and layouts available when you select the Area chart in the Components window.
Figure 23-2 Area Chart Types in Create Area Chart Dialog
Chart categories include:
Area: Represents data as a filled-in area. Use area charts to show trends over time, such as sales for the last 12 months. Area charts require at least two groups of data along an axis. The axis is often labeled with increments of time such as months.
Area charts represent these kinds of data values:
Absolute: Each area marker connects a series of two or more data values.
Stacked: Area markers are stacked. The values of each set of data are added to the values for previous sets. The size of the stack represents a cumulative total.
Tip:
Stacked charts are generally preferred over absolute charts. Areas in absolute charts can be visually obscured by other areas, depending on the area's data value.
Split Dual-Y: Dual axis charts are split into two parts. Area markers unique to a particular axis are plotted only on the relevant part. Applies to both absolute and stacked charts.
Range: Area markers and area coverage are determined by high and low values.
All variations of area charts can be configured with a single y-axis or dual y-axis.
Figure 23-3 shows example area charts with Cartesian and polar coordinate systems, as well as a horizontal area chart. It also shows sample split Dual-Y area and range area charts.
Figure 23-3 Area Chart Example
Bar: Represents data as a series of vertical bars. Use bar charts to examine trends over time or to compare items at the same time, such as sales for different product divisions in several regions.
Bar charts represent these kinds of data values:
Clustered: Each cluster of bars represents a group of data. For example, if data is grouped by employee, one cluster might consist of a Salary bar and a Commission bar for a given employee. This kind of chart includes the following variations: vertical clustered bar charts and horizontal clustered bar charts.
Stacked: Bars for each set of data are appended to previous sets of data. The size of the stack represents a cumulative data total.
Split Dual-Y: Dual-axis charts are split into two parts. Bars unique to a particular axis are plotted only on the relevant part. Applies to both absolute and stacked charts.
Range: Bars do not originate from the X-axis. The beginning and end of a bar are determined by high and low values. Useful to create waterfall charts for financial tracking.
All variations of bar charts can be configured with a single y-axis or dual y-axis. Bar charts may also be displayed horizontally using an orientation attribute.
Figure 23-4 shows variations of the bar chart type as displayed in the Create Bar Chart dialog with the Dual-Y Stacked Bar chart selected.
Figure 23-5 shows example bar charts with Cartesian and polar coordinate systems, as well as a horizontal bar chart. It also shows sample split Dual-Y bar and range bar charts.
Figure 23-5 Bar Chart Example
Bubble: Represents data by the location and size of round data markers (bubbles). Use bubble charts to show correlations among three types of values, especially when you have a number of data items and you want to see the general relationships. For example, use a bubble chart to plot salaries (x-axis), years of experience (y-axis), and productivity (size of bubble) for your work force. Such a chart allows you to examine productivity relative to salary and experience.
Figure 23-6 shows example bubble chart with Cartesian and polar coordinate systems.
Figure 23-6 Bubble Chart Example
Combination: Chart that uses different types of data markers (bars, lines, or areas) to display different kinds of data items. Use combination charts to compare bars and lines, bars and areas, lines and areas, or all three combinations. Combination charts may also be stacked to represent cumulative totals.
Figure 23-7 shows variations of the combination chart type as displayed in the Create Combination Chart dialog with the default combination chart selected. Combination charts can be configured with a single y-axis or dual y-axis, and can be stacked. Dual y-axis combination charts can be configured with a split axis.
Figure 23-8 shows example combination charts with Cartesian and polar coordinate systems.
Funnel: Visually represents data related to steps in a process. The steps appear as slices across a vertical or horizontal cone-shaped section. Typically, a funnel chart requires actual values against a stage value, which might be time. An optional target value may be specified for comparison. If target values are specified, a given step or slice fills as its actual value approaches its quota. For example, use the funnel chart to watch a process where the different sections of the funnel represent different stages in the sales cycle.
Figure 23-9 shows example vertical and horizontal funnel charts.
Line: Represents data as a line, as a series of data points, or as data points that are connected by a line. Line charts require data for at least two points for each member in a group. For example, a line chart over months requires at least two months. Typically a line of a specific color is associated with each group of data such as the Americas, Europe, and Asia. Use line charts to compare items over the same time. Line charts can be configured with a single y-axis or dual y-axis. The dual y-axis may be configured as a Split Dual-Y line chart.
Figure 23-10 shows example line charts with Cartesian and polar coordinate systems, as well as a horizontal line chart and a sample split dual-y line chart.
Figure 23-10 Line Chart Example
Pie: Represents a set of data items as proportions of a total. The data items are displayed as sections of a circle causing the circle to look like a sliced pie. Use pie charts to show the relationship of parts to a whole such as how much revenue comes from each product line. A pie chart may also be customized as a donut chart, which has an empty area in the center of the chart.
Figure 23-11 shows an example pie chart, as well as a ring/donut chart, with a chart label.
Scatter: Represents data by the location of data markers. Use scatter charts to show correlation between two different kinds of data values such as sales and costs for top products. Use scatter charts in particular to see general relationships among a number of items.
Figure 23-12 shows example scatter charts with Cartesian and polar coordinate systems.
Figure 23-12 Scatter Chart Example
Spark: A simple, condensed chart that displays trends or variations in a single data value, typically stamped in the column of a table or in line with related text. Spark charts have basic conditional formatting. Since spark charts contain no labels, the adjacent columns of a table or surrounding text provide context for spark chart content
Figure 23-13 shows variations of the spark chart type as displayed in the Create Spark Chart dialog with the default chart selected.
Figure 23-14 shows examples of line, bar, area, and floating bar spark charts.
Figure 23-14 Spark Chart Example
Stock: Represents information related to trade stocks, specifically the opening, high, low, and closing prices of stocks. Use stock charts to explore trends in stock prices, fluctuations and volume of trade. Depending on the type of chart chosen, each stock marker displays two to four values, not counting the optional volume marker. When the volume of trading is included, the volume appears as bars in the lower part of the chart.
Figure 23-15 shows variations of the stock chart type as displayed in the Create Stock Chart dialog with the Open Close Candle chart selected.
Figure 23-16 shows an example stock chart, with four data items.
Figure 23-16 Stock Chart Example
Chart end user and configurable presentation features include a rich variety of options.
Use data labels to display information about the data points. You can customize the text, position, and style.
Figure 23-17 shows a bubble chart and a scatter chart, each configured to show data labels. In the bubble chart, the group's value is displayed in the center of the bubble. In the scatter chart, the label position varies by series. In the first series, the label is positioned below the series marker, and the second series is set to auto which displays the label after the marker. The third series label is configured to display the label before the series marker, and the fourth series label displays the label above the marker.
Figure 23-17 Chart Data Labels
You can add descriptive labels to most chart components and subcomponents, including titles, subtitles, axis labels, footnotes, and legends.
Figure 23-18 shows a bar chart configured to show a title and subtitle. The chart is also configured to show titles for the x-axis, y-axis, legend, and footnote.
Figure 23-18 Bar Chart Configured with Labels for Chart, X-Axis, Y-Axis, and Legend
Charts use client-side layout management for controlling the size of the chart. A chart can automatically adjust to the size of the chart's container, and the user can resize the chart by resizing its container. You can also specify the size of a chart using its inlineStyle or styleClass attributes.
Figure 23-19 shows a portion of a page configured with the af:panelSplitter and dvt:barChart components. The user can drag the splitter to change the bar chart's size.
Figure 23-19 Bar Chart Resized by Dragging a Panel Splitter
When charts are displayed in a horizontally or vertically restricted area, as in a web page sidebar, the chart is displayed in a fully featured, although simplified display.
Chart legends identify the chart's series and associated colors. Figure 23-20 shows a bar chart configured with a legend. In this example, the number of series is greater than the legend area, and the user can scroll through the legend items to see all series on the chart.
Figure 23-20 Bar Chart With Scrollable Legend
Charts support styling of colors, sizes, and text to customize series, markers, lines, and data items. Figure 23-21 shows an area chart configured with custom colors for the series items and borders and a scatter chart configured with custom markers.
Figure 23-21 Charts Showing Styling for Colors and Markers
You can configure charts to allow the user to click on a legend series item to hide a series item from view. The resulting chart can be rescaled or rendered without rescaling.
Figure 23-22 shows a bar chart configured for series show and hide. When the user clicks a series item in the chart legend, the series no longer renders, and the legend changes to show which series item is hidden from view. The user can click the series item again to restore the series view.
Figure 23-22 Bar Chart Configured for Series Show and Hide
You can add reference lines or areas to a specified location or area on a chart's axis.
Figure 23-23 shows an example of a bar chart configured to show a reference line and reference area along its y-axis. In this example, the chart is configured to display a dark blue reference line at 25 on the y-axis. The reference area is configured to display in blue all values between a minimum of 95 and a maximum of 140.
Figure 23-23 Bar Chart Configured With Reference Line and Reference Area
By default, charts apply gradients to chart series. You can remove the gradients to achieve a flatter design or display the series with patterns. Figure 23-24 shows three area charts configured for series effects.
Figure 23-24 Area Charts Configured for Series Effects
You can customize the appearance of individual series in a chart. Depending upon the chart type, you can customize colors, markers, lines, and fill effects. For combination charts, the series is a chart, and you can also specify which chart to display.
Figure 23-25 shows a bubble, scatter, line, and combination chart configured with customized series. The charts illustrate how you might customize series colors, lines, and markers. The combination chart also shows how you might configure the series type to display an area, bar, and line chart.
You can add a data cursor to a chart that the user can move to display detail about a data point.
Figure 23-26 shows a line chart configured with a data cursor. In this example, the user chose to display the detail for the chart's third series in the fourth group.
Figure 23-26 Line Chart Configured With Data Cursor
Charts support the use of a time axis when the chart's data is based on dates. For example, you can use a time axis to display daily sales. The time data can cover regular or irregular time intervals. Time axes also support mixed frequency time data, where the time stamps vary by series.
Figure 23-27 shows four charts configured with a time axis. The horizontal bar chart's time axis contains regular monthly data and is configured to show the year and month with nested labels. The irregular intervals bar chart shows the time axis configured for irregular yearly intervals. The skipGaps bar chart shows the time axis configured to remove the empty space for irregular yearly intervals. The combination chart shows a mixed frequency time axis with time data that varies by series.
Figure 23-27 Charts Configured With a Time Axis
You can configure a chart with a categorical axis, where groups are arranged in a drillable hierarchical structure. These groups can be enhanced with custom styles such as labels and tooltips. Figure 23-28 shows a bar chart and an area chart with categorical axes. The area chart’s axis has stylized data group labels and an uneven hierarchical distribution.
Figure 23-28 Hierarchical Data Groups and Labels
Chart Group Labels support custom CSS styling and tooltip support. Figure 23-29 shows a bar chart where the group labels have different font and background colors, as well as a custom tooltip separate from the series tooltip that appears when hovering over a bar.
Figure 23-29 Custom Label Style and Tooltip
You can configure charts to display popups or context menus using the af:showPopupBehavior tag.
Figure 23-30 shows a bar chart configured to show a popup when the user clicks the chart. The popup displays an output message in a note window.
Figure 23-30 Bar Chart Showing a Popup
Charts can be enabled for single or multiple selection of data markers such as bubbles in a bubble chart or shapes in a scatter chart. Enabling selection is required for popups and context menus and for responding programmatically to user clicks on the data markers.
Figure 23-31 shows a pie chart enabled for multiple selection. Each data marker is highlighted as the user moves over it to provide a visual clue that the marker is selectable. The user can press Ctrl while selecting to add or delete slices from the selection.
Figure 23-31 Pie Chart Enabled for Selection
Pie charts in particular have multiple selection effects to better emphasize the selected slice.
Figure 23-32 shows pie charts with the selection effects highlight, explode, and highlight with explode.
Charts provide the ability to scroll through the data via a view port or simple scrollbar. This feature can be useful for charts containing large amounts of data.
Figure 23-33 shows a line chart configured for scrolling with a view port. As the user moves the view port on the master line chart, the detail chart changes to reflect the selected range.
Figure 23-33 Line Chart Configured With Viewport for Scrolling
The user can also choose to zoom in on a specific period by clicking the Marquee Zoom icon that appears when the user hovers over the chart. Figure 23-34 shows a bubble chart configured for marquee zoom. The user can drag the mouse over an area, and the chart zooms into the selected area.
Figure 23-34 Bubble Chart Configured for Marquee Zoom
Charts provide the ability to highlight a series when the user hovers over a legend item or marker. Figure 23-35 shows a bar chart configured with three series. As the user hovers over each series, the remaining series dim from view.
Figure 23-35 Chart Configured for Legend and Marker Dimming
Pie charts provide the ability to aggregate data if your data model includes a large number of smaller contributors in relation to the larger contributors.
Figure 23-36 shows a pie chart configured to aggregate all values less than two percent of the total. In this example, the tooltip shows the total value of the aggregated slices.
Figure 23-36 Pie Chart Showing Other Slice Support
When one slice is separated from the other slices in a pie, this display is referred to as an exploding pie slice. You can explode a slice to make it stand out from the other slices.
Figure 23-37 shows an example of an exploded pie slice.
Figure 23-37 Pie Chart Configured With Exploding Pie Slice
Charts support ADS by sending a Partial Page Refresh (PPR) request when an active data event is received. The PPR response updates the components, animating the changes as needed. Supported ADS events include:
Update
Remove
Insert
Refresh
The following limitations apply:
EL Operators are not supported within the EL Expressions for active attributes.
To insert a chart data item, you must include the series or group in the active data entry.
You can't change the series or group of an existing item.
The dvt:chartSeriesStyle tag is not supported on an inserted data item.
Attribute groups are not supported.
For additional information about using the Active Data Service, see Using the Active Data Service with an Asynchronous Backend.
You may find it helpful to understand other ADF Faces features before you implement your chart. Additionally, once you have added a chart to your page, you may find that you need to add functionality such as validation and accessibility. Following are links to other functionality that chart components can use:
Client-side framework: DVT components are rendered on the client when the browser supports it. You can respond to events on the client using the af:clientListener tag. For more information, see Listening for Client Events.
Partial page rendering: You may want a chart to refresh to show new data based on an action taken on another component on the page. For more information, see Rerendering Partial Page Content.
Personalization: When enabled, users can change the way the chart displays at runtime, those values will not be retained once the user leaves the page unless you configure your application to allow user customization. For information, see Allowing User Customization on JSF Pages.
Accessibility: You can make your chart components accessible. For more information, see Developing Accessible ADF Faces Pages.
Touch devices: When you know that your ADF Faces application will be run on touch devices, the best practice is to create pages specific for that device. For additional information, see Creating Web Applications for Touch Devices Using ADF Faces.
Skins and styles: You can customize the appearance of chart components using an ADF skin that you apply to the application or by applying CSS style properties directly using a style-related property (styleClass or inlineStyle). For more information, see Customizing the Appearance Using Styles and Skins.
Automatic data binding: If your application uses the Fusion technology stack, then you can create automatically bound charts based on how your ADF Business Components are configured. For more information, see "Creating Databound Charts" in Developing Fusion Web Applications with Oracle Application Development Framework.
If you know the UI components on your page will eventually use ADF data binding, but you need to develop the pages before the data controls are ready, then you should consider using placeholder data controls, rather than manually binding the components. Using placeholder data controls will provide the same declarative development experience as using developed data controls. For more information, see the "Designing a Page Using Placeholder Data Controls" section in Developing Fusion Web Applications with Oracle Application Development Framework.
Additionally, data visualization components share much of the same functionality, such as how data is delivered, automatic partial page rendering (PPR), and how data can be displayed and edited. For more information, see Common Functionality in Data Visualization Components.
To use the ADF DVT Chart component, add the selected chart type to a page using the Component Palette window. Then define the data for the chart and complete the additional configuration in JDeveloper using the tag attributes in the Properties window. You can easily configure a custom chart with many pre-built attributes..
The chart component use a standard CollectionModel for its data structure. This class extends the JSF DataModel class and adds on support for row keys and sorting. In the DataModel class, rows are identified entirely by index. This can cause problems when the underlying data changes from one request to the next, for example a user request to delete one row may delete a different row when another user adds a row. To work around this, the CollectionModel class is based on row keys instead of indexes. For more information about collection-based components, see Using Tables, Trees, and Other Collection-Based Components.
Data requirements for charts differ with chart type. Data requirements can be any of the following kinds:
Geometric: Some chart types need a certain number of data points in order to display data. For example, a line chart requires at least two groups of data because a line requires at least two points.
Complex: Some chart types require more than one data point for each marker (which is the component that actually represents the data in a chart). A scatter chart, for example, needs two values for each group so that it can position the marker along the x-axis and along the y-axis. If the data that you provide to a chart does not have enough data points for each group, the chart component does its best to display a chart.
Logical: Some chart types cannot accept certain kinds of data. The following examples apply:
Negative data: Do not pass negative data to a pie chart or a funnel chart.
Null or zero data: A bar or marker will not be visible if its value is zero, but an invisible region will be drawn to provide tooltip information.
Insufficient sets (or series) of data: Dual-Y charts require a set of data for each y-axis. Usually, each set represents different information. For example, the y-axis might represent sales for specific countries and time periods, while the y2-axis might represent total sales for all countries. If you pass only one set of y-axis data, then the chart cannot display data on two different y-axes. It displays the data on a single y-axis.
Data requirements for area, bar, and line charts include:
At least two groups of data are required for area and line charts. A group is represented by a position along the horizontal axis of area, bar, and line charts or vertical axis if the charts have horizontal orientations. In a chart that shows data for a three-month period, the groups might be labeled January, February, and March.
One or more series of data is required. In a chart that shows data for a three-month period, the series might be sales and quota.
Dual-Y charts require two sets of data.
Bar charts support an optional third value to specify bar widths.
Bubble charts require at least three data values for a data marker. Each data marker in a bubble chart represents three group values:
The x value that determines the marker's location along the x-axis.
The y value that determines the marker's location along the y-axis.
The z value that determines the size of the marker.
For more than one group of data, bubble charts require that data be in multiples of three. For example, in a specific bubble chart, you might need three values for Paris, three for Tokyo, and so on. An example of these three values might be: x value is average life expectancy, y value is average income, and z value is population.
When you look at a bubble chart, you can identify groups of data by examining tooltips on the markers. However, identifying groups is not as important as looking at the overall pattern of the data markers.
Combination charts require one set of data for each chart included in the combination chart. Each chart in the combination chart must meet the data requirements for the area, bar, or line chart components on which it is based. For a list of the data requirements for area, bar, or line chart components, see Area, Bar, and Line Chart Data Requirements.
Data requirements for a funnel chart are:
One set of values is required to represent the actual data items or slices in a funnel chart. In a chart that shows where customers get stuck in a process, the actual value would be the actual number of customers experiencing difficulty within a given time period.
One stage value is required to represent the different slices. In a chart that shows where customers get stuck in a process, the stage value is the different steps in the process.
One optional set of values may be provided to represent the target data items for each slice. In a chart that shows where customers get stuck in a process, the target value would be the maximum number of customers tolerable before the process needs to be updated.
One collection of data with one or more sets of data items is required for a pie chart. The data structure is as follows:
A series or set of data is represented by the pie slice. You see legend text for each set of this data. For example, if there is a separate set of data for each country, then the name of each country appears in the legend text.
Data values cannot be negative.
Scatter charts require at least two data values for each marker. Each data marker represents the following:
For more than one group of data, the data must be in multiples of two.
Line, bar, and area spark charts require a single series of data values.
Floating bar spark charts require two series of data values, one for the float offset, and one for the bar value.
Stock charts require values to represent four attributes for each data marker. Data requirements for a stock chart are:
Two set of values are required to represent the opening and closing values of stocks.
For high-low stock charts, two additional sets of values are required to represent the high and low values of stocks for a given time period.
If the type of chart includes volume, one set of data is required to represent the volume of trade for each stock for a given time period.
Because of the many chart types and the significant flexibility of the chart components, charts have a large number of DVT tags. The prefix dvt: occurs at the beginning of each chart tag name indicating that the tag belongs to the ADF Data Visualization Tools (DVT) tag library. The following list identifies groups of tags related to the chart component:
Chart component tags: The nine chart component tags provide a convenient and quick way to create a chart type. They are represented in the Components window as categories of charts with one or more type variations.
Table 23-1 provides a description of the chart component tags and their variations.
Table 23-1 Chart Component Tags
| Chart Tag | Description | Variations |
 | Represents data as a filled in area. | dual y-axis stacked range |
 | Represents data as a series of vertical bars. | dual y-axis stacked range |
 | Represents data by the location and size of the round (bubble) data marker. | |
 | Represents data as a combination of area, bar, or line markers. | dual y-axis stacked |
 | Represents data as a stepped cone. | |
 | Represents data as a series of lines. | dual y-axis stacked |
 | Displays values that are parts of a whole, where each value is shown as a sector of a circle. | donut |
 | Represents data by the location of data markers on a two-dimensional plane. | |
 | Simple, condensed chart that displays trends or variations in a single data value, typically stamped in the column of a table or in line with related text. | area bar floating bar line |
 | Displays stock information and volume of trade for a given time period. | Open-Close Open-Close with Volume Open-High-Low-Close Open-High-Low-Close with Volume |
Chart child component tags: These child tags are supported by most chart components to provide a variety of customization options.
Table 23-2 provides a list and description of these child tags.
Table 23-2 Common Chart Child Tags
| Child Tag | Description |
 | Defines properties for the data item of an area, bar, bubble, combination, line, or scatter chart. |
 | Defines properties for the group of an area, bar, bubble, combination, line, or scatter chart. |
 | Defines properties for the chart legend. |
 | Defines properties for the series of an area, bar, bubble, combination, line, or scatter chart. |
 | Defines formatting properties for the values of a chart. |
 | Defines properties for the x-axis of a chart. |
 | Defines properties for the y-axis of a chart. |
 | Defines properties for the y2-axis of a chart. |
 | Child tags of the  |
 | Defines properties for the data item of a pie chart. |
 | Defines properties for the data item of a funnel chart. |
Chart attributes: Properties of chart components. Attributes may be applicable to all charts or specific to a chart type.
Table 23-3 provides a list and description of commonly used attributes.
Table 23-3 Common Chart Attributes
 | Specifies the type of data change animation indicator. |
 | Specifies the amount of space between bars in a bar chart and the thickness of the bars, expressed as a ratio or percentage. |
 | Specifies an inner string and its font for a ring chart (pie chart). |
 | Specifies if the chart uses Cartesian or Polar coordinates. |
 | Specifies whether or not the data cursor is enabled. |
 | Specifies the position of the data labels. Options depend on the chart type. |
 | Specifies the selection mode for the chart. |
 | Specifies whether this group can be drilled. Valid values are 'off' (default) and 'on'. When set to 'on', the existing drillEvent will be fired when the user clicks/taps on a the group label. |
 | Defines the footnote and its horizontal alignment. |
 | Specifies the hide and show behavior when clicking on legend items. |
 | Specifies the upper limit of range data for range area and range bar charts. |
 | Specifies whether or not to dim other markers when the user hovers over a marker. |
 | Specifies whether or not to initially zoom into the first or last portion of a chart. |
 | Specifies a ratio or percentage of an inner circle in a pie chart to be hidden, turning it into a ring chart. |
 | Specifies the position of data labels. Options depend on the chart type. |
 | Specifies the lower limit of range data for range area and range bar charts. |
 | Specifies the maximum width of bars in a bar chart, expressed in pixels. |
 | Specifies whether the chart is displayed vertically or horizontally. |
 | Defines the color and percentage for the  |
 | Specifies if the shape of the polar grid is circle or polygon. |
 | Specifies the selection effect when a pie slice is selected in a pie chart. |
 | Defines the fill properties for data items. |
 | Specifies the amount of gap in between pie slices in a pie chart and in between funnel segments in a funnel chart. Accepted values lie between 0 and 1. |
 | Specifies the position of the pie chart's data labels. |
 | Specifies if pie chart and bar chart data items should be sorted. On bar charts, accepted values are  |
 | Specifies whether to split information that is provided using the y2-axis. When this attribute is set to 'on' the chart will render the two data sets separately in stacked plot areas that share the same x-axis. |
 | Specifies a value that will correspond to how much of the available plot area the y-axis will occupy. This attribute applies only when the  |
 | Specifies whether or not the data should be stacked. |
 | Specifies the subtitle for the chart. |
 | Defines a time axis type for the chart. |
 | Specifies the common size attributes for all symbols in a chart legend. |
 | Defines the title and its horizontal alignment. |
 | EL variable that iterates through each element in the collection. |
 | Specifies the chart's zoom and scroll behavior. |
Chart facets: All charts with the exception of spark charts, stock charts, funnel charts, and pie charts support facets, which are named sections within a component.
Table 23-4 provides a list and description of supported chart facets.
Table 23-4 Chart Facets
 | Wraps the data item component or components to stamp for each row of the model. To stamp multiple data items, wrap them in the  |
 | Specifies the group component to stamp for each column of the model. The properties of the stamp will be processed once for each unique group. To declaratively define multiple groups, wrap them in the  |
 | Specifies the rendering of the optional overview window. |
 | Specifies the series style component to stamp for each row of the model. The properties of the stamp will be processed once for each unique series. To declaratively define multiple series, wrap them in the  |
Spark chart tags: Properties of the spark chart component. Spark charts contain a minimal set of formatting attributes.
Table 23-5 provides a list and description of commonly used spark chart tags.
Table 23-5 Common Spark Chart Attributes
 | Specifies whether or not the axis is scaled to include the baseline value of zero. |
 | Specifies the border color of the data item. |
 | Specifies the color of the bars, line, or area in the spark chart. |
 | Specifies line width in pixels, whether the line is solid, dashed or dotted, and the type of line connector, such as straight, curved, stepped or segmented. |
 l
 | Specifies the colors for the first, last, high, and low markers and whether or not the markers are displayed. |
 | Specifies the shape of the marker, such as  |
 | Specifies the data value for the spark chart |
 | Specifies whether the spark chart is displayed as an area, bar, floating bar, or line. |
 | Defines thresholds for the spark chart. |
 | Specifies text to display when the user hovers over the spark chart. |
For complete descriptions of all the tags, their attributes, and a list of valid values, consult the DVT tag documentation. To access this documentation for a specific chart tag in JDeveloper, select the tag in the Structure window and press F1 or click Component Help in the Properties window.
DVT charts also share many of the same attributes as other ADF Faces and DVT components. For additional information, see Additional Functionality for Chart Components.
When you are designing your page using simple UI-first development, you use the Components window to add a chart to a JSF page. When you drag and drop a chart component onto the page, a Create Chart dialog displays available categories of chart types, with descriptions, to provide visual assistance when creating charts. You can also specify a quick start layout of the chart's legend.
Figure 23-38 shows the Create Bar Chart dialog for bar charts with the default bar chart type and quick start layout selected.
Once you complete the dialog, and the chart is added to your page, you can use the Properties window to specify data values and configure additional display attributes for the chart.
In the Properties window you can click the icon that appears when you hover over the property field to display a property description or edit options. Figure 23-39 shows the dropdown menu for a bar chart component value attribute.
If your application uses the Fusion technology stack, then you can use data controls to create a chart and the binding will be done for you. For more information, see "Creating Databound Charts" in Developing Fusion Web Applications with Oracle Application Development Framework
Before you begin:
It may be helpful to have an understanding of how chart attributes and chart child tags can affect functionality. For more information, see Configuring Charts.
You may also find it helpful to understand functionality that can be added using other ADF Faces features. For more information, see Additional Functionality for Chart Components.
You must complete the following tasks:
Create an application workspace as described in Creating an Application Workspace.
Create a view page as described in Creating a View Page.
To add a chart to a page:
JDeveloper generates only a minimal set of tags when you drag and drop a chart from the Components window onto a JSF page.
The example below shows the code inserted in the JSF page for a bar chart with the quick start layout selected in Figure 23-38.
<dvt:barChart id="chart1"> <dvt:chartLegend id="leg1" rendered="true"/> </dvt:barChart>
After inserting a chart component into the page, you can use the visual editor or Properties window to add data or customize chart features. For information about setting component attributes, see How to Set Component Attributes.
You can configure ADF DVT chart components to render data by specifying the required data model or method in the chart’s value attribute and then configuring an appropriate data item child component to interpret the data values.
The process to add data to charts depends upon the chart's type. In most cases, you specify the data model in the chart's value attribute and configure the chart's data items in the chartDataItem child component. For pie, funnel, and stock charts, you specify the value in the pieDataItem, funnelDataItem, or stockDataItem child component respectively. For spark charts, you specify the spark chart's value in the sparkItem child component.
You can specify the chart's value and chart data items in a managed bean that returns the chart's data or by binding a data control to the chart.
To add data to area, bar, combination, and line charts, specify the data model in the chart's value attribute and configure a chartDataItem for each unique group. For details about data requirements, see Chart Component Data Requirements.
The code below shows an example of a managed bean that defines the data for a line chart that shows weekly portfolio values for four investors. In this example, the ChartDataSource class defines the chart's CollectionModel in the getWeeklyStockData() method which calls the getPortfolioData() method to define the chart's data items.
package view;
import java.util.ArrayList;
import java.util.Calendar;
import java.util.GregorianCalendar;
import java.util.HashMap;
import java.util.Random;
import java.util.List;
import org.apache.myfaces.trinidad.model.CollectionModel;
import org.apache.myfaces.trinidad.model.ModelUtils;
public class ChartDataSource {
* Object representing the data for a single row of the model.
  public static class ChartDataItem extends HashMap<String, Object> {
  @SuppressWarnings("compatibility")
  private static final long serialVersionUID = 1L;
  public ChartDataItem(String series, Object group, Number value) {
    put("series", series);
    put("group", group);
    put("value", value);
  public ChartDataItem(String series, Object group, Object x, Number y) {
    put("x", x);
    put("y", y);
  public ChartDataItem(String series, Object group, Number x, Number y, Number z) {
    put("x", x);
    put("y", y);
    put("z", z);
  public CollectionModel getWeeklyStockData() {
    return getPortfolioData(4, 157, 2013, 6, 1, Calendar.DATE, 7);
  private Random random = new Random(23);
  private double getNextValue(double curValue, double std) {
    if (curValue == 0)
      return 0;
    else
      return Math.max(curValue + random.nextGaussian() * std, 0);
  public CollectionModel getPortfolioData(int numSeries, int numGroups,
                                          int startYear, int startMonth,
                                          int startDate, int dateField,
                                          int addCount)
    List<ChartDataItem> dataItems = new ArrayList<ChartDataItem>();
    GregorianCalendar cal;
    double curValue;
    for(int series=0; series<numSeries; series++) {
      cal = new GregorianCalendar(startYear, startMonth, startDate);
      curValue = 100;
      for(int group=0; group<numGroups; group++) {
        dataItems.add(new ChartDataItem("Investor " + (series+1), cal.getTime(),
                                         curValue));
        cal.add(dateField, addCount);
        curValue = getNextValue(curValue, 10);
    return ModelUtils.toCollectionModel(dataItems);
The example below shows the code on the JSF page that defines the line chart and references the ChartDataSource class. In this example, the managed bean is named chartDataSource.
<dvt:lineChart id="chart1" value="#{chartDataSource.weeklyStockData}"
               timeAxisType="enabled" var="row">
  <dvt:chartLegend id="leg1" rendered="true" position="top"/>
  <f:facet name="dataStamp">
    <dvt:chartDataItem id="cdi1" series="#{row.series}" group="#{row.group}"
                    value="#{row.value}"/>
  </f:facet>
</dvt:lineChart>
Figure 23-40 shows the line chart that is displayed if you configure the line chart using the ChartDataSource class.
Figure 23-40 Line Chart Showing Portfolio Data for Four Investors
Before you begin:
It may be helpful to have an understanding of how chart attributes and child tags can affect functionality. For more information about configuring charts, see Configuring Charts.
Add an area, bar, combination, or line chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
To add data to an area, bar, combination, or line chart:
Optionally, create the managed bean that will return the chart's data model.
If you need help creating classes, see "Working with Java Code" in Developing Applications with Oracle JDeveloper. For help with managed beans, see Creating and Using Managed Beans.
In the Structure window, right-click dvt:typeChart and choose Go To Properties.
In the Properties window, expand the Data section, and enter a value for the Var field.
The var property is the name of an EL variable that references each element in the data collection. In the second code example above, the var attribute is defined as row. The relevant code is shown below.
In the Properties window, do one of the following:
To reference a managed bean that returns the chart's data model, expand the Common section and specify the EL expression that references the data model in the Value field.
You can enter a static numeric value or specify an EL expression that references the managed bean and metric value.
For example, to specify an EL expression for a managed bean named chartDataSource that includes the class referenced in the first code sample above, enter the following in the Value field: #{chartDataSource.weeklyStockData}.
For help with creating EL expressions, see How to Create an EL Expression.
To bind the chart to a data control, click Bind to ADF Control to select a data collection.
For more information about using data controls to supply data to your chart, see "Creating Databound Charts" in Developing Fusion Web Applications with Oracle Application Development Framework.
If you specified a managed bean for the chart's data model, do the following to add a chartDataItem to the chart:
In the Structure window, right-click dvt:typeChart and choose Insert Inside Chart > Facet dataStamp.
To add multiple chart data items, right-click f:facet - dataStamp and choose Insert Inside Facet data Stamp > Group.
Right-click f:facet - dataStamp or af:group and choose Insert Inside (Facet data Stamp or Group) > Chart Data Item.
To add additional data items, right-click af:group and choose Insert Inside Group > Chart Data Item for each additional data item.
Right-click dvt:chartDataItem and choose Go to Properties.
In the Properties window, in the Common section, enter a value for the Value field. If creating a range area or range bar chart, enter values for the High and Low fields instead.
For example, to reference the value defined in the chartDataSource managed bean, enter the following in the Value field: #{row.value}.
In this example, row is the variable that you defined in the previous step, and value is defined in the chartDataSource bean's getPortfolioData() method shown in the first code sample above.
Expand the Data section, and enter a value in the Group field.
To use the same chartDataSource managed bean, enter the following in the Group field: #{row.group}.
Enter a value in the Series field.
To use the same chartDataSource managed bean, enter the following in the Series field: #{row.series}.
To customize the tooltip that is displayed when the user moves the focus to a data point, enter a value in the shortDesc field.
Configure any additional properties as needed to customize the data item.
For example, you can add a label or configure a series marker. For additional information, see Customizing Chart Display Elements.
If your chart includes time data on the x-axis, you can enable a time axis. For additional information, see How to Configure a Time Axis.
If your bar chart has discrete data points of varying weight or importance, you can enter a value in the Z field in the Data section. This value will be used to change the width of the bars.
If your area or bar chart has range data, you can enter values in the High and Low fields instead of Value. These values will be used to represent the upper and lower limits of each data point.
To configure additional chart data items, repeat Step f through Step i for each additional data item.
To add data to a pie chart, specify the data model in the pie chart's value attribute and configure a pieDataItem for each unique series. For information about pie chart data requirements, see Pie Chart Data Requirements.
The process to add data to pie charts is similar to the process for adding data to area, bar, bubble, combination, line, and scatter charts. The primary difference is that you add a pieDataItem instead of a chartDataItem to the chart.
The code below shows a simple example for configuring a pie chart from a managed bean. In this example, the getDefaultPieData() method is added to the chartDataSource bean referenced in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts.
public CollectionModel getDefaultPieData() {
    dataItems.add(new ChartDataItem("Series 1", "Group A", 42));
    dataItems.add(new ChartDataItem("Series 2", "Group A", 55));
    dataItems.add(new ChartDataItem("Series 3", "Group A", 36));
    dataItems.add(new ChartDataItem("Series 4", "Group A", 22));
    dataItems.add(new ChartDataItem("Series 5", "Group A", 22));
The example below shows the code on the JSF page that defines a pie chart and references the ChartDataSource class. In this example, the managed bean is named chartDataSource.
<dvt:pieChart id="chart1" value="#{chartDataSource.defaultPieData}" var="row">
    <dvt:pieDataItem label="#{row.series}" value="#{row.value}" id="pdi1"/>
  </dvt:pieChart>
Figure 23-41 shows the pie chart at run time. In this example, the pie chart is rendered with a legend, and the data labels show the percentage of each slice as a portion of the total.
Figure 23-41 Pie Chart Configured From Managed Bean
Before you begin:
Add a pie chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
To add data to a pie chart:
In the Structure window, right-click dvt:pieChart and choose Go To Properties.
For example, to specify an EL expression for a managed bean named chartDataSource that includes the method to supply data to a pie chart, as shown in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts, enter the following in the Value field: #{chartDataSource.defaultPieData}.
If you specified a managed bean for the chart's data model, do the following to add a pieDataItem to the pie chart:
Right-click dvt:pieChart and choose Insert Inside Pie > Pie Data Item.
In the Insert Pie Data Item dialog, enter a label and value for the data item.
For example, to use the chartDataSource managed bean, enter the following for the label and value, respectively:
#{row.series}
#{row.value}
In the Structure window, right-click dvt:pieChart and choose Go to Properties.
The var property is the name of an EL variable that references each element in the data collection. In the second code sample in How to Add Data to Area, Bar, Combination, and Line Charts, the var attribute is defined as row. The relevant code is shown below.
InnerRadius: Enter a value between 0 and 1 to determine the size of the ring hole.
CenterLabel: Enter a string to add a chart label in the center of the ring.
CenterLabelStyle: Enter values to style and format the center label.
SliceGaps: Enter a value between 0 and 1 to determine the size of gaps between individual pie slices.
For example, you can customize the label or explode the pie slice. For additional information, see Customizing Chart Display Elements.
To add additional pie data items, repeat Step a through Step e for each additional data item.
To add data to a bubble or scatter chart, specify the data model in the chart's value attribute and configure a chartDataItem for each unique group. For details about data requirements, see Chart Component Data Requirements.
The process to add data to bubble or scatter charts is similar to the process for adding data to area, bar, bubble, combination, line, and scatter charts. The primary difference is that you must also specify values for the x-axis and y-axis. For bubble charts, you must also specify values for the z-axis, which represents the size of the bubbles.
The example below shows a simple example for configuring a bubble chart from a managed bean. In this example, the getDefaultBubbleData() method is added to the chartDataSource bean referenced in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts.
public CollectionModel getDefaultBubbleData() {
  // Each data item below defines a series, group, x, y, and z value
  dataItems.add(new ChartDataItem("Series 1", "Group A", 15, 25, 5));
  dataItems.add(new ChartDataItem("Series 1", "Group B", 25, 30, 12));
  dataItems.add(new ChartDataItem("Series 1", "Group C", 25, 45, 12));
  dataItems.add(new ChartDataItem("Series 2", "Group A", 15, 15, 8));
  dataItems.add(new ChartDataItem("Series 2", "Group B", 20, 35, 14));
  dataItems.add(new ChartDataItem("Series 2", "Group C", 40, 55, 35));
  dataItems.add(new ChartDataItem("Series 3", "Group A", 10, 10, 8));
  dataItems.add(new ChartDataItem("Series 3", "Group B", 18, 55, 10));
  dataItems.add(new ChartDataItem("Series 3", "Group C", 40, 50, 18));
  dataItems.add(new ChartDataItem("Series 4", "Group A", 8, 20, 6));
  dataItems.add(new ChartDataItem("Series 4", "Group B", 11, 30, 8));
  dataItems.add(new ChartDataItem("Series 4", "Group C", 30, 40, 15));
For scatter charts, only the x-axis and y-axis positions are required. The example below shows a simple example for configuring a scatter chart from a managed bean. In this example, the getDefaultScatterData() method is added to the chartDataSource bean referenced in the first code sample shown in How to Add Data to Area, Bar, Combination, and Line Charts
public CollectionModel getDefaultScatterData() {
  dataItems.add(new ChartDataItem("Series 1", "Group A", 15, 15));
  dataItems.add(new ChartDataItem("Series 1", "Group B", 25, 43));
  dataItems.add(new ChartDataItem("Series 1", "Group C", 25, 25));
  dataItems.add(new ChartDataItem("Series 2", "Group A", 25, 15));
  dataItems.add(new ChartDataItem("Series 2", "Group B", 55, 45));
  dataItems.add(new ChartDataItem("Series 2", "Group C", 57, 47));
  dataItems.add(new ChartDataItem("Series 3", "Group A", 17, 36));
  dataItems.add(new ChartDataItem("Series 3", "Group B", 32, 52));
  dataItems.add(new ChartDataItem("Series 3", "Group C", 26, 28));
  dataItems.add(new ChartDataItem("Series 4", "Group A", 38, 22));
  dataItems.add(new ChartDataItem("Series 4", "Group B", 43, 43));
  dataItems.add(new ChartDataItem("Series 4", "Group C", 58, 36));
Figure 23-42 shows the bubble chart and scatter chart displayed at runtime. The tooltips show the data from the first ChartDataItem defined in the code samples to supply data to bubble and scatter charts, as shown in How to Add Data to Bubble or Scatter Charts.
Figure 23-42 Bubble and Scatter Charts Configured From Managed Bean
Before you begin:
Add a bubble or scatter chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
To add data to a bubble chart:
The var property is the name of an EL variable that references each element in the data collection. For the bubble and scatter charts shown in Figure 23-42, the var attribute is defined as row.
For example, to specify an EL expression for a managed bean named chartDataSource that includes the method referenced in the first code sample in How to Add Data to Bubble or Scatter Charts, enter the following in the Value field: #{chartDataSource.defaultBubbleData}.
Expand the Data section, and enter a value in the X field.
To use the managed beans shown in the code samples to supply data to bubble and scatter charts, as shown in How to Add Data to Bubble or Scatter Charts, enter the following in the X field: #{row.x}.
Enter a value in the Y field.
For example, enter the following in the Y field: #{row.y}.
For bubble charts, enter a value in the Z field.
For example, enter the following in the Z field: #{row.z}.
Enter a value in the Group field.
For example, enter the following in the Group field: #{row.group}.
For example, enter the following in the Series field: #{row.series}.
To configure additional chart data items, repeat Step 5 through Step 12 for each additional data item.
To add data to a funnel chart, specify the data model in the chart's value attribute and configure a funnelDataItem for each unique group. For details about data requirements, see Chart Component Data Requirements.
The process to add data to funnel charts is similar to the process for adding data to area, bar, horizontal bar, bubble, combination, line, and scatter charts. The primary difference is that you add a funnelDataItem instead of a chartDataItem to the chart.
The example below shows a simple example for configuring a funnel chart from a managed bean. In this example, the getDefaultFunnelData() method and the overloaded ChartDataItem constructor are added to the chartDataSource bean referenced in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts.
public ChartDataItem(String series, Number value, Number targetValue) {
    put("targetValue", targetValue);
public CollectionModel getDefaultFunnelData() {
        dataItems.add(new ChartDataItem("Series 1", 46, 60));
    dataItems.add(new ChartDataItem("Series 2", 34, 50));
    dataItems.add(new ChartDataItem("Series 3", 30, 30));
    dataItems.add(new ChartDataItem("Series 4", 11, 25));
The example below shows the code on the JSF page that defines a funnel chart and references the ChartDataSource class. In this example, the managed bean is named chartDataSource.
<dvt:funnelChart id="chart1" value="#{chartDataSource.defaultFunnelData}" var="row">
  <dvt:funnelDataItem label="#{row.series}" value="#{row.value1}" targetValue="#{row.targetValue1}" id="pdi1"/>
</dvt:funnelChart>
Figure 23-43 shows the funnel chart at run time. The target values specified are optional, and allow the generation of an incomplete funnel as seen below.
Figure 23-43 Funnel Chart Configured From Managed Bean
Before you begin:
Add a funnel chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
To add data to a funnel chart:
In the Structure window, right-click dvt:funnelChart and choose Go To Properties.
In the Property Inspector, do one of the following:
For example, to specify an EL expression for a managed bean named chartDataSource that includes the method shown in the first code sample above, enter the following in the Value field: #{chartDataSource.defaultFunnelData}.
If you specified a managed bean for the chart's data model, do the following to add a funnelDataItem to the funnel chart:
Right-click dvt:funnelChart and choose Insert inside dvt:funnelChart > Funnel Data Item.
In the Insert Funnel Data Item dialog, enter a label and value for the data item.
#{row.series}
#{row.value}
In the Structure window, right-click dvt:funnelChart and choose Go to Properties.
In the Property Inspector, expand the Data section, and enter a value for the Var field.
For example, you can customize the label. For additional information, see Customizing Chart Display Elements.
To add additional funnel data items, repeat Step 1 through Step 6 for each additional data item.
To add data to a stock chart, specify the data model in the chart's value attribute and configure a stockDataItem for each unique group. For details about data requirements, see Chart Component Data Requirements.
The process to add data to funnel charts is similar to the process for adding data to area, bar, horizontal bar, bubble, combination, line, and scatter charts. The primary difference is that you add a stockDataItem instead of a chartDataItem to the chart.
The example below shows a simple example for configuring a stock chart from a managed bean. In this example, the getDefaultStockData() method and the overloaded chartDataItem constructor are added to the chartDataSource bean referenced in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts.
public ChartDataItem(Object group, Number open, Number close, Number high, Number low, Number volume) {
    put("series", "STOCK");
    put("open", open);
    put("close", close);
    put("high", high);
    put("low", low);
    put("volume", volume);
public CollectionModel getDefaultStockData() {
        dataItems.add(new ChartDataItem("Apr 2011",20.00,22.00,23.00,19.00,2000000));
        dataItems.add(new ChartDataItem("Jun 2011",22.00,24.00,24.00,19.00,4000000));
        dataItems.add(new ChartDataItem("Jul 2011",24.00,22.00,24.00,19.00,1000000));
        dataItems.add(new ChartDataItem("Aug 2011",22.00,26.00,28.00,19.00,3000000));
        dataItems.add(new ChartDataItem("Sep 2011",18.00,22.00,24.00,16.00,8000000));
        dataItems.add(new ChartDataItem("Oct 2011",20.00,22.00,22.00,19.00,9000000));
        dataItems.add(new ChartDataItem("Dec 2011",23.00,28.00,29.00,23.00,5000000));
The example below shows the code on the JSF page that defines a stock chart and references the ChartDataSource class. In this example, the managed bean is named chartDataSource.
<dvt:stockChart value="#{chartDataSource.defaultStockData}" var="row">
    <dvt:stockDataItem series="#{row.series}" group="#{row.group}" volume ="#{row.volume}" high="#{row.high}"
                       low = "#{row.low}" close="#{row.close}" open="#{row.open}"/>
</dvt:stockChart>
The figure shows the stock chart at run time. In this example, the stock chart has a volume section, and the values are reflected in the y-axis.
Figure 23-44 Stock Chart Configured From Managed Bean
Before you begin:
Add a stock chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
To add data to a stock chart:
Spark charts are simple, charts that display trends or variations, often in the column of a table, or inline with text. Line, bar, and area spark charts require a single series of data values. Figure 23-45 shows an example of a line spark chart in a table column.
Figure 23-45 Line Spark Chart in Table of Stock Prices
Floating bar spark charts require two series of data values, one for the float offset, and one for the bar value. Figure 23-46 shows an example of a floating bar spark chart.
Figure 23-46 Floating Bar Spark Chart
In a simple UI-first development scenario you can insert a spark chart using the Components window and bind it to data afterwards.
You can provide data to spark charts in any of the following ways:
Specify data statically in child dvt:sparkItem tags. The example below shows an example of providing static data to a spark chart.
<dvt:sparkChart> <dvt:sparkItem value="20"/> <dvt:sparkItem value="15"/> <dvt:sparkItem value="30"/> </dvt:sparkChart>
Specify data using EL Expression in child dvt:sparkItem tags.
The example below shows an example of providing data to spark charts using EL Expressions to produce the table shown in Figure 23-45.
<af:table summary="Table" value="#{sparkChart.tableData}" var="row"
          columnStretching="last"
          rowBandingInterval="1" id="t1" width="230"
          disableColumnReordering="true"
          contentDelivery="immediate" autoHeightRows="8">
  <af:column sortable="false" headerText="Stock Symbol" align="start" id="c1"
             rowHeader="true">
    <af:outputText value="#{row[0]}" id="ot4"/>
  </af:column>
  <af:column sortable="false" headerText="Prices for 2014" id="c2">
    <dvt:sparkChart id="sparkchart1" subType="line" axisScaledFromBaseline="off"
                    shortDesc="Sparkchart in Table">
      <dvt:sparkItem value="#{row[1]}" id="si6"/>
      <dvt:sparkItem value="#{row[2]}" id="si5"/>
      <dvt:sparkItem value="#{row[3]}" id="si4"/>
      <dvt:sparkItem value="#{row[4]}" id="si3"/>
      <dvt:sparkItem value="#{row[5]}" id="si2"/>
      <dvt:sparkItem value="#{row[6]}" id="si1"/>
    </dvt:sparkChart>
  </af:column>
</af:table>
In this example, the spark chart's data is defined in a managed bean named sparkChart. The example below shows the managed bean. The class is defined as SparkchartSample, and the getTableData() method defines the columns for the table.
import java.util.Arrays;
public class SparkchartSample {
  public List <List <Object>> getTableData() {
    List <List <Object>> list = new ArrayList <List <Object>>();
    // Create a random number generator with a constant seed
    Random rand = new Random(5);
    String stocks[] = {"ORCL", "AAPL", "MSFT", "YHOO", "CSCO", "PALM", "GOOG",
                       "SAP", "HPQ", "IBM", "INTC", "RIMM"};
      Arrays.sort(stocks); // sort to look nice
        for(int i=0; i<stocks.length; i++)
          List <Object> row = new ArrayList <Object>();
          row.add(stocks[i]);
          for(int j=0; j<6; j++) {
            // Let the value vary between 40 and 70 (for simplicity)
            row.add((rand.nextDouble()*30) + 40);
          list.add(row);
        return list;
Use af:iterator to stamp spark items.
The example below shows an example of using af:iterator to provide data to a bar spark chart.
<dvt:sparkChart subType="bar" id="sc5">
  <af:iterator value="#{sparkChart.collection}" var="row" id="i3">
    <dvt:sparkItem value="#{row.close}" id="si9"/>
  </af:iterator>
</dvt:sparkChart>
In this example, the iteration is defined in the sparkChart managed bean. The example below shows the collection() method that creates the spark items.
import java.util.Map;
public List <Map <String,Object>> getCollection() {
  List <Map <String,Object>> list = new ArrayList <Map <String,Object>>();
  // Generate some sort of stock data
  double open[] =  {5,   6,   4.5, 6.3, 4.1, 7.6, 8.4, 11.5, 10.5, 11.3};
  double close[] = {6.8, 4.2, 6.7, 4.5, 7.1, 8.6, 10.4, 10.0, 12.5, 14.5};
  for(int i=0; i<open.length; i++)
      Map <String,Object> row = new HashMap <String,Object>();
      row.put("open", open[i]);
      row.put("close", close[i]);
      list.add(row);
  return list;
Figure 23-47 shows the runtime view of the spark chart that displays if you create the spark chart defined in the af:iterator examples above.
Figure 23-47 Sparkchart Data Items Stamped by af:iterator
Before you begin:
If you plan on displaying your spark chart in a table, create the ADF table. If you need help creating the table, see How to Display a Table on a Page.
Add a spark chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
To add data to a spark chart:
Create the managed bean that will return the chart's data model.
To use an af:iterator to stamp the spark chart data items, do the following:
Right-click dvt:sparkChart and choose Insert Inside Spark Chart > Iterator.
In the Structure window, right-click af:iterator and choose Go to Properties.
In the Properties window, expand the Common section, and enter a value for the Value field.
Reference the EL expression that returns the value for the spark chart data item. To reference the method used in the collection() method example above, specify the following for the value: #{sparkChart.collection}.
Enter a value for the Var field.
The var property is the name of an EL variable that references each element in the data collection. In the collection() method example above, the var attribute is defined as row.
Configure any additional properties as needed to customize the iterator.
For example, you can specify a maximum number of rows. For more information about working with af:iterator, click Component Help.
To add the spark chart data items, do the following:
Right-click dvt:sparkChart or af:iterator and choose Insert Inside (Spark Chart or Iterator > ADF Data Visualizations) > Spark Item.
In the Structure window, right-click dvt:sparkItem and choose Go to Properties.
You can enter a static numeric value or reference an EL expression that returns the value for the spark chart data item. To reference the method used in the collection() method example above, specify the following for the Value: #{row.close}.
For example, you must specify a FloatValue for floating bar spark charts. For additional information about the available attributes, click Component Help.
To add additional spark chart data items, repeat Step a through Step d for each additional data item.
You can also bind the spark chart to a data control if your application uses the Fusion technology stack. To do so, click Bind to ADF Control in the Properties window to select a data collection. For more information about using data controls to supply data to your chart, see "Creating Databound Charts" in Developing Fusion Web Applications with Oracle Application Development Framework.
You can customize most aspects of the ADF DVT Chart component's display, including its labels, legend, axes, series, and animation effects. Some chart types also allow the addition of reference objects, stacking behavior, or a dual Y-Axis.
Pie charts also support the ability to aggregate smaller values or explode a pie slice.
You can customize the style and position of chart data labels on all charts other than spark charts. Depending on the chart type, you can also add a title, subtitle, footnote, legend title, or axis title.
Tip:
Use data labels sparingly because they cause clutter and decrease readability. Use data labels primarily to highlight outliers or important values and not to show values for all data points.
To configure chart data labels, configure the attributes of the dvt:chartDataItem or dvt:pieDataItem chart child component.
If you want the style and position of all chart or pie data items to be the same, you can configure attributes directly on the chart component.
Before you begin:
Add a chart to your page. For help with adding a chart to a page, see How to Add a Chart to a Page.
Add data to your chart. For additional information, see Adding Data to Charts.
To configure data labels for charts:
In the Structure window, right-click dvt:chartDataItem or dvt:pieDataItem and choose Go to Properties.
In the Properties window, expand the Appearance section.
To customize the data label colors, enter a value for the following:
Color: Specify the RGB value in hexadecimal notation or choose Expression Builder from the attribute's dropdown menu to enter an expression that evaluates to the RGB value.
For example, enter #008000 to render the data label in green.
BorderColor: For all charts except spark charts, specify the RGB value in hexadecimal notation or choose Expression Builder from the attribute's dropdown menu to enter an expression that evaluates to the RGB value.
For example, enter #FF0000 to render the data label in red.
BorderWidth: For all charts except spark charts, specify a numeric value or choose Expression Builder from the attribute's dropdown menu to enter an expression that evaluates to the numeric width value.
For example, enter 4 to render the data label border width at 4 units.
To customize the position and style of the data label on area, bar, bubble, combination, line, and scatter charts:
In the Properties window, expand the Data section.
From the DataLabelPosition attribute's dropdown list, choose a location for the data label.
By default, the DataLabelPosition attribute is set to auto which will center the label on bubble and stacked bar charts, render the label inside the bar edge for non-stacked bar charts, and render the label after the marker on line, area, and scatter charts.
You can select Center to position the label on the center of the data point. For bubble charts, if the label is too long, the content will be truncated.
You can also select aboveMarker, belowMarker, beforeMarker, and afterMarker to position the label above, below, before, or after the marker for area, bubble, line, and scatter charts. For bar charts, you can also select insideBarEdge which renders the label inside the bar edge or outsideBarEdge to render the data label on top of the bar for positive data values and below the bar for negative data values.
To customize the text style of the data label, in the Style section, enter a value for the StyleClass or InlineStyle attributes.
For example, if you want to specify a bold font for the data label, enter the following for the InlineStyle attribute:
font-weight:bold;
To customize the position or text style of a specific chart data item, in the Properties window, configure the LabelPosition, Style, or InlineStyle attributes of the dvt:chartItem child component.
If you configure label positions on both the chart and its child data item, the values you set for the chart's data item will override any settings on the chart.
To customize the position and style of the data label on pie charts:
In the Properties window, from the SliceLabelPosition attribute's dropdown list, choose a location for the data label.
By default, the SliceLabelPosition is set to auto which will position the label inside if there is enough space in the slice, and outside the slide otherwise. You can select inside or outside to explicitly position the label inside or outside the slice respectively or none to remove the label entirely.
font-weight:bold;
To configure a chart label, add the chart child component as needed, and configure the style and position of the label. Depending upon the chart type, you can specify labels for the chart's title, subtitle, and footnote.
Sparkcharts are condensed charts that contain minimal formatting and have little support for labels. Use the spark chart's container to provide descriptive text for the spark chart.
Before you begin:
To add a title, subtitle or footnote to a chart:
To configure a chart axis label, add a child axis component as needed, and configure the style and position of the label. Depending on the chart type, you can specify the legend title, or axis title and tick labels.
Before you begin:
To configure chart axis labels:
For information about customizing chart legend titles, see How to Configure Chart Legends.
You can add a legend to all charts except the spark chart to identify the chart's series and associated colors. If you chose a quick start layout that included a legend when you created your chart, you should already have a legend on the page.
After you have added the legend, you can customize its position, configure a legend title, or disable scrolling.
Before you begin:
To configure a chart legend:
You can customize the appearance of numeric values on charts using the dvt:chartValueFormat or dvt:chartTickLabel tags.
Figure 23-48 shows the effect of adding dvt:chartValueFormat and dvt:chartTickLabel tags to a bar chart configured to display monthly salaries for a fictitious department. In this example, the top bar chart is using default numeric formatting. The bar chart at the bottom of the figure is configured to display the series value and axis label as currency values.
Figure 23-48 Bar Chart Configured to Display Currency Values
Before you begin:
Use the dvt:chartValueFormat tag to format numeric values for the chart's value, value label, or axis values.
The dvt:chartValueFormat tag allows you to specify the scaling for numeric display.
To format numeric values on a chart's value, value label, or axis values:
Use the dvt:chartTickLabel tag to format the values on the axis labels.
The dvt:chartTickLabel tag allows you to specify the scaling for numeric display. It also has a rotation property to specify whether the chart will automatically rotate the labels by 90 degrees in order to fit more labels on the axis. The rotation will only be applied to categorical labels for a horizontal axis. It also has a position property to specify whether the axis labels will be positioned inside or outside the chart.
To format numeric values on a chart's axis label:
You can specify specific patterns for the numeric values or change the numeric display to currency or percent by adding the af:convertNumber tag to the dvt:chartValueFormat or dvt:chartTickLabel tags. For additional information about using the af:convertNumber tag, see Validating and Converting Input.
To specify numeric patterns, currency, or percent using af:convertNumber:
Depending upon the chart type, you can configure a time axis on the x-axis or customize the properties of a chart's x-axis, y-axis, y2-axis, or z-axis.
If your x-axis includes time data, then you can enable the time axis display. Charts include support for time data that is based on regular or irregular intervals. Charts also support mixed frequency time data, where the individual series contain differing dates.
Figure 23-49 shows four charts configured for a time axis. In the horizontal bar chart, the time data is spaced equally. The vertical bar chart shows an example of irregularly spaced data, and the chart provides a visual clue that there is no data for 2014. The second vertical bar chart does not show the visual clue for the missing data. The combination chart shows mixed frequency time data. In this example, the time data is different for each series (chart) in the combination chart.
Figure 23-49 Charts Configured for Regular, Irregular, and Mixed Frequency Time Data
To configure a time axis, set the timeAxisType attribute's value to enabled for regular or irregular data, set it to skipGaps to not indicate empty space in irregular data, and set it to mixedFrequency for time data that varies by series.
The example below shows the code snippet on the JSF page that defines the horizontal bar chart, bar charts, and combination chart, with the timeAxisType definition highlighted in bold font.
<af:panelBox text="Time Axis Nested Labels: Year and Month"
             showDisclosure="false">
  <dvt:barChart orientation="horizontal" value="#{chartDataSource.monthlyTimeData}"
             var="row" hoverBehavior="dim" timeAxisType="enabled">
      <dvt:chartDataItem series="#{row.series}" group="#{row.group}"
    </f:facet>
  </dvt:barChart>
</af:panelBox>
<af:panelBox text="Time Axis with Irregular Intervals" showDisclosure="false">
  <dvt:barChart value="#{chartDataSource.yearlyIrregularTimeData}"
    </f:facet>
    <dvt:chartXAxis>
      <dvt:majorTick rendered="true"/>
    </dvt:chartXAxis>
  </dvt:barChart>
</af:panelBox>
<af:panelBox text="timeAxisType= skipGaps" showDisclosure="false">
  <dvt:barChart value="#{chartDataSource.yearlyIrregularTimeData}" var="row" hoverBehavior="dim" timeAxisType="skipGaps">
      <dvt:chartDataItem series="#{row.series}" group="#{row.group}" value="#{row.value}"/>
    </f:facet>
    <dvt:chartXAxis>
    </dvt:chartXAxis>
  </dvt:barChart>
</af:panelBox>
<af:panelBox text="Mixed Frequency Time Axis" showDisclosure="false">
  <dvt:comboChart value="#{chartDataSource.yearlyMixedFrequencyTimeData}"
                  var="row" hoverBehavior="dim" timeAxisType="mixedFrequency">
      <dvt:chartDataItem series="#{row.series}" group="#{row.group}" x="#{row.x}" y="#{row.y}"/>
    </f:facet>
  </dvt:comboChart>
The code that defines the charts' collection models and populate them with data is stored in the chartDataSource managed bean shown in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts.
The example below shows the getMonthlyTimeData(), getYearlyIrregularTimeData(), and getYearlyMixedFrequencyTimeData() methods. In this example, the getMonthlyTimeData() method calls the getTimeData() method which is a reusable method that takes the series, group, and time data as its arguments.
public CollectionModel getYearlyIrregularTimeData() {
  dataItems.add(new ChartDataItem("Series 1", new GregorianCalendar(2011, 7, 27).getTime(), 55));
  dataItems.add(new ChartDataItem("Series 1", new GregorianCalendar(2012, 7, 27).getTime(), 60));
  dataItems.add(new ChartDataItem("Series 1", new GregorianCalendar(2013, 7, 27).getTime(), 75));
  dataItems.add(new ChartDataItem("Series 1", new GregorianCalendar(2015, 1, 27).getTime(), 70));
  dataItems.add(new ChartDataItem("Series 1", new GregorianCalendar(2016, 1, 27).getTime(), 35));
  dataItems.add(new ChartDataItem("Series 2", new GregorianCalendar(2011, 7, 27).getTime(), 45));
  dataItems.add(new ChartDataItem("Series 2", new GregorianCalendar(2012, 7, 27).getTime(), 40));
  dataItems.add(new ChartDataItem("Series 2", new GregorianCalendar(2013, 7, 27).getTime(), 65));
  dataItems.add(new ChartDataItem("Series 2", new GregorianCalendar(2015, 1, 27).getTime(), 65));
  dataItems.add(new ChartDataItem("Series 2", new GregorianCalendar(2016, 1, 27).getTime(), 45));
public CollectionModel getYearlyMixedFrequencyTimeData() {
  dataItems.add(new ChartDataItem("Series 1", "Group 1", new GregorianCalendar(2011, 7, 27).getTime(), 55));
  dataItems.add(new ChartDataItem("Series 1", "Group 2", new GregorianCalendar(2013, 7, 27).getTime(), 60));
  dataItems.add(new ChartDataItem("Series 1", "Group 3", new GregorianCalendar(2015, 7, 27).getTime(), 75));
  dataItems.add(new ChartDataItem("Series 1", "Group 4", new GregorianCalendar(2017, 7, 27).getTime(), 70));
  dataItems.add(new ChartDataItem("Series 1", "Group 5", new GregorianCalendar(2019, 7, 27).getTime(), 35));
  dataItems.add(new ChartDataItem("Series 2", "Group 1", new GregorianCalendar(2012, 1, 27).getTime(), 45));
  dataItems.add(new ChartDataItem("Series 2", "Group 2", new GregorianCalendar(2013, 7, 27).getTime(), 40));
  dataItems.add(new ChartDataItem("Series 2", "Group 3", new GregorianCalendar(2014, 7, 27).getTime(), 65));
  dataItems.add(new ChartDataItem("Series 2", "Group 4", new GregorianCalendar(2016, 1, 27).getTime(), 65));
  dataItems.add(new ChartDataItem("Series 2", "Group 5", new GregorianCalendar(2020, 7, 27).getTime(), 45));
  dataItems.add(new ChartDataItem("Series 3", "Group 1", new GregorianCalendar(2010, 7, 27).getTime(), 15));
  dataItems.add(new ChartDataItem("Series 3", "Group 2", new GregorianCalendar(2012, 7, 27).getTime(), 20));
  dataItems.add(new ChartDataItem("Series 3", "Group 3", new GregorianCalendar(2014, 7, 27).getTime(), 35));
  dataItems.add(new ChartDataItem("Series 3", "Group 4", new GregorianCalendar(2016, 7, 27).getTime(), 30));
  dataItems.add(new ChartDataItem("Series 3", "Group 5", new GregorianCalendar(2018, 7, 27).getTime(), 55));
public CollectionModel getMonthlyTimeData() {
  return getTimeData(2, 10, 2013, 7, 1, Calendar.MONTH, 1);
private double getValue() {return Math.random() * 100;}
public CollectionModel getTimeData(int numSeries, int numGroups,
                       int startYear, int startMonth, int startDate,
                       int dateField, int addCount){
  GregorianCalendar cal = new GregorianCalendar(startYear, startMonth, startDate);
      dataItems.add(new ChartDataItem("Series " + (series+1), cal.getTime(), getValue()));
Before you begin:
To configure a chart time axis:
enabled if your chart includes regular or irregular time data. Select skipGaps if your chart includes irregular time data where the time skip should not be highlighted, such as in stock data where the weekend periods do not matter. Select mixedFrequency if your chart contains mixed frequency time data.Charts include support for customizing the x-axis, y-axis, and y2-axis. Depending upon the axis type, you can customize the minimum and maximum values of the data and axis, add a title, specify tick mark increments, configure viewport boundaries, and specify whether the axis baseline starts at the minimum value of the data or at zero.
To customize a chart axis, add the dvt:chartXAxis, dvt:chartYAxis, or dvt:chartY2Axis component to the chart and configure the properties for the axis in the Properties window.
Table 23-6 lists the chart axis attributes and the axis on which they apply. Most attributes have default settings which are based upon the data, and you only need to change these if you want to modify the defaults. However, you must specify values for the title, attributeChangeListener, and binding attributes if you want to use them.
Table 23-6 Chart Axis Attributes
| Name | Description | X-Axis Support? | Y-Axis Support? | Y2-Axis Support? |
 | Specifies whether the tick marks of the y1 and y2 axes are aligned. | No | No | Yes |
 | Method reference to a listener for renderer changes to a property without the application's specific request. | Yes | Yes | Yes |
 | Specifies whether the axis baseline starts at the minimum value of the data or at zero. | Yes | Yes | Yes |
 | Specifies a binding reference to store a specific instance of the axis from a backing bean. Set this attribute only to access code in a backing bean. | Yes | Yes | Yes |
 | Specifies the maximum data value on a numerical axis. If not set, attribute defaults to the maximum value of the data set. | Yes | Yes | Yes |
 | Specifies the minimum data value on a numerical axis. If not set, attribute defaults to the maximum value of the data set. | Yes | Yes | Yes |
 | Specifies the component's identifier. | Yes | Yes | Yes |
 | Specifies the increment for the major ticks of a numerical axis. | Yes | Yes | Yes |
 | Specifies the maximum value of the axis. | Yes | Yes | Yes |
 | Specifies the maximum width or height of the axis | Yes | Yes | Yes |
 | Specifies the minimum value of the axis. | Yes | Yes | Yes |
 | Specifies the minimum increment between tick marks on a numerical axis. | Yes | Yes | Yes |
 | Specifies the increment for the minor ticks of the axis. | Yes | Yes | Yes |
 | Specifies the location of the axis label in relation to the plot area. | No | Yes | Yes |
 | Specifies whether the axis is rendered. | Yes | Yes | Yes |
 | Specifies whether the axis is linear or logarithmic | Yes | Yes | Yes |
 | Specifies the width or height of the axis | Yes | Yes | Yes |
 | Specifies the title of the axis. | Yes | Yes | Yes |
 | Specifies the end group of the current viewport on group or time axes. | Yes | No | No |
 | Specifies the start group of the current viewport on group or time axes. | Yes | No | No |
 | Specifies the maximum x-coordinate or y-coordinate of the current viewport on bubble and scatter charts. | Yes | Yes | No |
 | Specifies the minimum x-coordinate of the current viewport | Yes | Yes | No |
Chart axes also support optional child components which allow you to customize the major and minor tick marks, axis tick labels, and axis lines.
dvt:majorTick and dvt:minorTick: Specifies the line color, style, and width and baseline color, style and width of the chart's tick marks.
dvt:chartAxisLine: Specifies the line color and width of the axis line.
dvt:chartTickLabel: Specifies the scaling, styling, and rotation of the chart's tick labels.
For details about configuring dvt:chartTickLabel, see How to Format Chart Numerical Values and How to Configure Chart Element Labels.
dvt:referenceArea and dvt:referenceLine: Specifies a reference area or line on the axis.
For information about adding a reference area or line to your chart, see Adding Reference Objects to a Chart.
Before you begin:
To customize a chart axis, axis line, and axis major or minor ticks:
You can add a second y-axis to area, bar, combination, and line charts. This feature is useful if you have two series with different ranges of data. For example, you could have a bar chart that shows salary on one y-axis and commission percent on the second.
To configure a dual y-axis, add the dvt:chartSeriesStyle component to your chart, and set the assignedToY2 attribute to true. For instructions to configure the dvt:chartSeriesStyle component, see How to Customize a Chart Series.
You can add reference areas or lines to all charts except pie charts using the dvt:referenceLine or dvt:referenceArea components. Reference areas are associated with the chart's axis and typically are associated with the y-axis. Use reference areas or lines to show target values or ranges.
Figure 23-50 shows the line chart displayed in Figure 23-40 with a reference area and reference line. In this example, the reference area is configured with a light blue color and a range between 200 and 250. The reference line is configured with a green color and a value of 25.
Figure 23-50 Line Chart Configured With Reference Area and Reference Line
The example below shows the code snippet on the JSF page that defines the reference area and line. In this example, the reference area and line are configured as children of the chart's y-axis.
<dvt:chartYAxis title="Portfolio Value (thousands of USD)">
  <dvt:referenceArea id="ra1" color="#A0CEEC" maximum="250" minimum="200"
                     displayInLegend="on" text="Target Portfolio Value"/>
  <dvt:referenceLine id="rl1" color="#008000" value="25" displayInLegend="on"
                     text="Target Minimum" rendered="true" lineWidth="3"/>
</dvt:chartYAxis>
You can also specify multi-segment reference lines or areas as shown in Figure 23-51. In this example, the bar chart is configured with a multi-segment reference line, and the line chart is configured with a multi-segment reference area. In these examples, the target values vary by year.
Figure 23-51 Multi-Segment Reference Line and Reference Area
Multi-segment reference lines or reference areas are defined by adding the dvt:referenceAreaItem or dvt:referenceLineItem elements as children of the dvt:referenceArea and dvt:referenceLine components. You can explicitly define a reference area or line item for each segment in the reference line or area, or use the af:iterator tag to loop through the segments.
The example below shows the code snippets on the JSF page that define the bar and line charts. The code related to the reference area and reference line is highlighted in bold.
              var="row" timeAxisType="enabled" inlineStyle="width:650px">
    <dvt:chartDataItem series="Series 1" group="#{row.group}"
  </f:facet>
  <dvt:chartYAxis maximum="100">
    <dvt:referenceLine color="#A0CEEC" displayInLegend="on" text="Target Value"
                       lineWidth="3" shortDesc="Target Value">
      <af:iterator id="it1" value="#{chartDataSource.yearlyIrregularTimeData}"
                   var="row">
        <dvt:referenceLineItem x="#{row.series == 'Series 1' ? row.group:0}"
                          value="#{row.series == 'Series 1' ? row.value + 15:0}"/>
      </af:iterator>
    </dvt:referenceLine>
  </dvt:chartYAxis>
  <dvt:chartLegend rendered="true"/>
</dvt:barChart>
<dvt:lineChart value="#{chartDataSource.yearlySingleTimeData}" var="row"
               timeAxisType="enabled" inlineStyle="width:650px" id="chart1">
  </f:facet>
  <dvt:chartYAxis>
    <dvt:referenceArea color="#A0CEEC" displayInLegend="on" text="Target Range"
                       shortDesc="Target Range">
      <af:iterator id="it3" value="#{chartDataSource.yearlySingleTimeData}"
                   var="row">
        <dvt:referenceAreaItem x="#{row.group}" minimum="#{row.value - 15}"
                               maximum="#{row.value + 15}"/>
      </af:iterator>
    </dvt:referenceArea>
  </dvt:chartYAxis>
</dvt:lineChart>
The data for the bar chart is defined in the getYearlyIrregularTimeData() method and is shown in the second code sample in Customizing a Chart Axis, and the line chart's data is defined in the getYearlySingleTimeData() method. Both methods are contained in the chartDataSource managed bean.
The code below shows the getYearlySingleTimeData() method that defines the line chart's collection model and populates it with sample data.
public CollectionModel getYearlySingleTimeData() {
                new GregorianCalendar(2010, 1, 27).getTime(), 35));
                new GregorianCalendar(2011, 1, 27).getTime(), 55));
                new GregorianCalendar(2012, 1, 27).getTime(), 60));
                new GregorianCalendar(2013, 1, 27).getTime(), 75));
                new GregorianCalendar(2014, 1, 27).getTime(), 65));
                new GregorianCalendar(2015, 1, 27).getTime(), 55));
                new GregorianCalendar(2016, 1, 27).getTime(), 85));
                new GregorianCalendar(2017, 1, 27).getTime(), 70));
                new GregorianCalendar(2018, 1, 27).getTime(), 75));
                new GregorianCalendar(2019, 1, 27).getTime(), 45));
                new GregorianCalendar(2020, 1, 27).getTime(), 50));
To add a reference object to a chart, add the dvt:referenceArea or dvt:referenceLine component as a child of the chart's associated axis. The process is the same for all charts except the spark charts which use reference objects wrapped inside a reference object set for reference areas and lines.
To specify segmented reference lines or areas, add the dvt:referenceAreaItem or dvt:referenceLineItem as a child of the dvt:referenceArea or dvt:referenceLine. To use af:iterator to loop through the reference items, add the af:iterator as a child of the chart's axis and then add the reference item.
To add a reference line or object to a spark chart, add the dvt:referenceObjectSet component to the spark chart and configure a dvt:referenceObject for each reference line or area. Consult the tag documentation for additional information.
Before you begin:
To add a reference line or reference area to a chart:
Stacked charts show cumulative values across groups. Stacked charts typically contain two or more series which are aggregated into one bar, area, or line. For example, you might want to show the total sales of three products, grouped by city. In a clustered bar chart, the bar chart would display three bars, one for each product. In a stacked bar chart, the three bars would be aggregated into one bar for each city.
Figure 23-52 shows the effect of stacking series in a bar chart. In this example, the five series in the clustered bar chart at the top of the figure are configured as a stacked bar chart at the bottom of the figure.
Figure 23-52 Stacked Bar Chart
If you chose a quick start layout that included a stacked display, then JDeveloper automatically stacked the series by group. Otherwise, you can enable stacking by setting the stack attribute to on.
Before you begin:
To configure a stacked chart:
on.You can customize the fill of all series in a chart by setting the seriesEffect attribute on the chart component.
You can customize the appearance of individual series in a chart by adding the dvt:chartSeriesStyle component to your chart. Depending upon the chart type, you can customize colors, markers, lines, fill effects and click actions. For combination charts, you can also specify which chart to display.
Spark charts contain only a single series and do not support seriesEffect or chartSeriesStyle. To customize the spark chart, enter values for the dvt:sparkChart component in the Properties window. You can customize the series color and specify which markers are displayed. For more information, click Component Help in the Properties window.
To customize an individual series in a chart, add the dvt:chartSeriesStyle component and configure its properties in the Properties Window.
Table 23-7 lists the attributes available on the chartSeriesStyle component and the chart types for which they apply.
Table 23-7 dvt:chartSeriesStyle Tags
| Chart Tag | Description | Supported Chart Types |
 | Method reference to an action. | area, bar, bubble, combination, line |
 | Method reference to an action listener. | area, bar, bubble, combination, line |
 | Specifies the color of an area series. | area, combination (with area) |
 | Specifies whether the series should be assigned to the Y2 axis. | area, bar, combination, line |
 | Method reference to an attribute change listener. | all |
 | Specifies the border color of the series. | all |
 | Specifies the border width of the series | all |
 | Specifies the color of the series. | all |
 | Specifies whether the series is displayed in the chart legend | all |
 | Specifies whether this group can be drilled. Valid values are 'off' (default) and 'on'. When set to 'on', the existing  | all |
 | Specifies the id of the component. | all |
 | Specifies the appearance of the line. | combination (with line), line |
 | Specifies the appearance of line connectors | area, bubble, scatter, combination (with line), line |
 | Specifies the width of the line in pixels. | combination (with line), line |
 | Specifies the color of the data item markers, if different than the series color. | area, bubble, combination (with area or line), line, scatter |
 | Specifies whether the data item markers are displayed. | area, bubble, combination (with area or line), line, scatter |
 | Specifies the shape of the data item markers. | area, bubble, combination (with area or line), line, scatter |
 | Specifies the size of the data item markers if displayed. | area, bubble, combination (with area or line), line, scatter |
 | Specifies the pattern of the series. | all |
 | Specifies whether the component is rendered. | all |
 | Identifies the series for which the series style applies. | all |
 | String value that specifies which series will be stacked together. | area, bar, combination, line |
 | Specifies whether the series is displayed as an area, bar, line, or lineWithArea chart. | combination |
Before you begin:
It may be helpful to have an understanding of how chart attributes and child tags can affect functionality. For information about configuring charts, see Configuring Charts.
You may also find it helpful to understand functionality that can be added using other ADF Faces features. See Additional Functionality for Chart Components.
To customize a chart series:
To customize the series fill effects for all series in the chart, specify a value for the seriesEffect attribute.
Before you begin:
To configure series fill effects for all series in a chart:
Chart groups support hierarchical labels for data item groups. These labels can be customized with styles, tooltips, and drilling.
You can customize chart group hierarchies by adding the dvt:chartGroup component to your chart. To create each level of hierarchy, you can nest an additional dvt:chartGroup tag. The hierarchy group labels can be unevenly distributed and support custom styling, including font face and size, text color and backgrounds.
Spark charts contain only a single series and do not supportchartGroup. To customize the spark chart, enter values for the dvt:sparkChart component in the Properties window. You can customize the series color and specify which markers are displayed. For more information, click Component Help in the Properties window.To customize an individual group in a chart, add the dvt:chartGroup component to the chart and configure its attribute values in the Properties Window.
Table 23-8 lists the attributes available on the chartGroup tag.
Table 23-8 dvt:chartGroup Attributes
| Attribute | Description |
 | Specifies the name of the group. The name will be used as a group label. |
 | Specifies the group ID for matching the group with the  |
 | Specifies the label style for the group specified by the  |
 | Specifies whether the component is rendered. Valid values are 'true' (default) and 'false'. |
 | Specifies the text that appears as a tooltip upon hovering over the component. The tooltip is used for the group |
Before you begin:
To customize a chart group:
Chart groups support hierarchical nesting to represent multi-level grouping in data. Figure 23-53 shows two charts with a hierarchical X-axis. The bar chart has even hierarchical distribution and the default styling on group labels. The area chart has uneven distribution and custom styles applied.
Figure 23-53 Hierarchical Group Labels in Chart Axis
The example below shows the code snippet on the JSF page for the bar and area charts with custom hierarchical labels, with the relevant code for the labels highlighted in bold font.
<dvt:barChart value="#{chartDataSource.brandData}" var="row"  inlineStyle="width:700px;height:400px" title="Hierarchical Group Labels">
                <dvt:chartDataItem series="#{row.brand}" group="" groupId="#{row.region}_#{row.year}" value="#{row.value}"/>
        </f:facet>
        <f:facet name="groupStamp">
                <dvt:chartGroup group="#{row.region}" groupId="#{row.region}">
                        <dvt:chartGroup group="#{row.year}" groupId="#{row.region}_#{row.year}"/>
                </dvt:chartGroup>
        </f:facet>
        <dvt:chartYAxis title="Number of units sold"/>
        <dvt:chartValueFormat type="group" tooltipLabel="Region" />
        <dvt:chartValueFormat type="group" tooltipLabel="Year" />
        <dvt:chartValueFormat type="series" tooltipLabel="Department" />
</dvt:barChart>
<dvt:areaChart value="#{chartDataSource.defaultAreaData}" var="row"  inlineStyle="width:700px;height:400px" title="Hierarchical Group Labels with Uneven Hierarchy and Custom Styling">
        </f:facet>
                <dvt:chartGroup group="Group AA" groupId="Group AA"  shortDesc="Outermost group" labelStyle="font-size: 20px; ">
                        <dvt:chartGroup group="Inner #{row.group}" groupId="#{row.group}" shortDesc="Sub Level 1" labelStyle="font-size: 14px; font-family: Comic Sans MS"  rendered="#{row.group != 'Group B' and row.group != 'Group C'}"/>
                        <dvt:chartGroup group="Group AB" groupId="Group AB"  shortDesc="Sub Level 1" labelStyle="font-size: 20px; ">
                                <dvt:chartGroup group="Inner #{row.group}" groupId="#{row.group}" shortDesc="Sub Level 2" labelStyle="font-size: 14px; font-family: Comic Sans MS" rendered="#{row.group == 'Group C'}"/>
                        </dvt:chartGroup>
                </dvt:chartGroup>
        </f:facet>
        <dvt:chartLegend rendered="false"/>
</dvt:areaChart>
Before you begin:
It may be helpful to have an understanding of how chart attributes and child tags can affect functionality. SeeConfiguring Charts.
You may also find it helpful to understand functionality that can be added using other ADF Faces features. SeeAdditional Functionality for Chart Components.
To create a chart group hierarchy:
Use the Other slice to aggregate smaller data sets visually into one larger set for easier comparison, as shown in Figure 23-36. To configure the Other slice, set a value for the otherThreshold attribute which specifies the percentage under which the slice would be aggregated into the Other slice. Optionally, you can set a value for the Other slice color.
Before you begin:
You may also find it helpful to understand functionality that can be added using other ADF Faces features. For more information, see Additional Functionality for Chart Components.
To configure the pie chart Other slice:
You can configure the slices of a pie chart so that each slice is separated from the other using the sliceGaps attribute of the dvt:pieChart tag or the explode attribute of the dvt:pieDataItem tag. You can specify a value between 1 and 10 for the distance between the slices.
Figure 23-54 shows the pie chart displayed in Figure 23-41 configured for exploding slices. In this example, the explode attribute for the pie chart's data item is defined as 0.25.
Figure 23-54 Pie Chart Configured For Exploding Slices
You can also configure an individual slice to explode using the explode attribute. You can also configure a selected slice to automatically explode using the SelectionEffect attribute of the pie chart. Figure 23-55 shows the same pie chart configured to explode the Series 1 slice.
Figure 23-55 Pie Chart Configured With Single Exploding Slice
To configure an individual slice, you can use an EL expression to identify the slice and the value for the explode attribute. The individual slices in a pie chart are its series, and you can reference the series number in the EL expression.
For example, to set the explode attribute for the first series (slice) in the pie chart to 0.5, enter the following for the EL expression: #{row.series == 'Series 1' ? 0.5 : 0}. If you wanted to set the explode attribute for the third series to 0.25, you could enter the following for the EL expression: #{row.series == 'Series 3' ? 0.25 : 0}.
Before you begin:
To explode pie slices:
To configure chart animation, add the af:transition tag as a child of the chart component and configure the trigger type and transition effect.
Before you begin:
To configure chart animation:
Charts also support skinning to customize the color and font styles for the top level components as well as the axes, legend, series, marquee icon, labels, and plot area. You can also use skinning to define the animation duration and chart series effect.
The code below shows the skinning key for a chart configured to show patterns for its series fill effect.
af|dvt-chart
    -tr-series-effect: pattern;
For the complete list of chart skinning keys, see the Oracle Fusion Middleware Data Visualization Tools Tag Reference for Oracle ADF Faces Skin Selectors. For additional information about customizing your application using skinning and styles, see Customizing the Appearance Using Styles and Skins.
You can add a variety of interactive features to ADF DVT charts, including data cursors, hide and show behavior, hover behavior, selection support, popups, context menus, and zoom and scroll.
Add a data cursor to your chart to allow the user to focus more easily on data points. For charts where selection and other click interactivity is not enabled, the data cursor can be used to provide feedback for the closest data item to the mouse or touch gesture.
The data cursor is enabled by default for area and line charts on touch devices. To add the data cursor explicitly, set the dataCursor attribute to on and define the data cursor's behavior.
Figure 23-56 shows the line chart displayed in Figure 23-40 configured with a data cursor. In this example, the data cursor displays the series name, group value and series value. The box surrounding the data detail is displayed in the same color as the series fill color.
Figure 23-56 Line Chart With Data Cursor Showing Investor Detail
Before you begin:
It may be helpful to have an understanding of how chart attributes and child tags can affect functionality. For more information about configuring charts, see Configuring Charts.
To configure a chart data cursor:
The content displayed in the data cursor's tooltip is determined by the dvt:chartDataItem or dvt:pieDataItem component's shortDesc attribute. You can edit this value in the Properties window for dvt:chartDataItem or dvt:pieDataItem.
To configure hide and show behavior, which permits the user to click on a legend series item to hide or show a series item, configure the chart's hideAndShowBehavior attribute.
Figure 23-57 shows a bar chart configured for hide and show behavior support. The user can click multiple legend items to hide the respective series items, and click again to show them again. The legend items have a white fill to indicate which series are hidden.
Figure 23-57 Bar Chart Configured for Hide and Show Behavior
Before you begin:
To configure hide and show behavior:
To configure legend and marker dimming, set the chart's hoverBehavior attribute to dim. As the user hovers over each series, the remaining series dim from view.
Before you begin:
To configure legend and marker dimming:
dim.Charts can be enabled for single or multiple selection of data markers. Enabling selection is required for popups and context menus and for responding programmatically to user clicks on the data markers. To enable selection support, set the chart's dataSelection attribute to single or multiple.
After you have enabled selection support, you can specify a selection listener that will respond to user clicks on the chart.
Figure 23-58 shows a bar chart configured for multiple selection support. The user can click to select a single bar or use Ctrl-Click to select multiple bars. The bars highlight to show which bars are selected, and a message is displayed at the top of the page indicating which row key was selected.
Figure 23-58 Bar Chart Configured for Multiple Selection
The example below shows the code on the JSF page that defines the bar chart and selection listener, with the selection code highlighted.
<af:group id="g1">
  <af:outputText inlineStyle="font-size:large;" value="Selection Listener" id="ot1"/>
  <af:spacer width="50px"/>
  <af:outputText partialTriggers="chartSelect"
                 value="#{chartDataSource.selectionState}"
                 inlineStyle="font-size:larger;" id="ot2"/>
  <af:panelGroupLayout id="pgl1" layout="horizontal">
    <dvt:barChart id="chartSelect" value="#{chartDataSource.defaultBarData}"
                  var="row" dataSelection="multiple"
                  selectionListener="#{chartDataSource.selectionListener}">
      <dvt:chartLegend id="leg1" rendered="false"/>
      <f:facet name="dataStamp">
        <dvt:chartDataItem id="cdi1" value="#{row.value}" group="#{row.group}"
                           series="#{row.series}"/>
      </f:facet>
    </dvt:barChart>
  </af:panelGroupLayout>
</af:group>
In this example, the code that defines the bar chart is included in a method named defaultBarData(), and the selection listener is defined in a method named selectionListener().
The code below shows the defaultBarData() and selectionListener() methods. The methods and imports were added to the chartDataSource class created in the first code sample in How to Add Data to Area, Bar, Combination, and Line Charts.
// Additional imports needed by selection listener
import oracle.adf.view.faces.bi.component.chart.UIChartBase;import org.apache.myfaces.trinidad.event.SelectionEvent;
import org.apache.myfaces.trinidad.model.RowKeySet;
// Bar Chart data
public CollectionModel getDefaultBarData() {  List<ChartDataItem> dataItems = new ArrayList<ChartDataItem>();  dataItems.add(new ChartDataItem("Series 1", "Group A", 42));  dataItems.add(new ChartDataItem("Series 1", "Group B", 34));  dataItems.add(new ChartDataItem("Series 2", "Group A", 55));  dataItems.add(new ChartDataItem("Series 2", "Group B", 30));  dataItems.add(new ChartDataItem("Series 3", "Group A", 36));  dataItems.add(new ChartDataItem("Series 3", "Group B", 50));  dataItems.add(new ChartDataItem("Series 4", "Group A", 22));  dataItems.add(new ChartDataItem("Series 4", "Group B", 46));  dataItems.add(new ChartDataItem("Series 5", "Group A", 22));  dataItems.add(new ChartDataItem("Series 5", "Group B", 46));  return ModelUtils.toCollectionModel(dataItems);
// Selection state
private String m_selection = "No Nodes Selected";
public String getSelectionState() {
  return m_selection;
// Selection Listener
public void selectionListener(SelectionEvent event) {
  UIChartBase chart = (UIChartBase) event.getComponent();
  RowKeySet rowKeySet = chart.getSelectedRowKeys();
  if(rowKeySet != null && rowKeySet.size() > 0) {
    StringBuilder sb = new StringBuilder("Selection: ");
    for(Object rowKey : rowKeySet) {
      sb.append(rowKey).append(", ");
  // Remove the trailing comma and set the selection string
    sb.setLength(sb.length()-2);
    m_selection = sb.toString();
  else
Before you begin:
To configure chart selection support:
In the Structure window, right-click dvt:typeChart and choose Go to Properties.
From the DataSelection dropdown list, select single or multiple to enable selection support.
Optionally, to enable a selection listener, do the following.
Create the method or methods that define the selection listener, and add it to the chart's managed bean.
If you need help creating classes, see "Working with Java Code" in Developing Applications with Oracle JDeveloper. For help with managed beans, see Creating and Using Managed Beans.
In the Properties window, in the SelectionListener field, enter the name of the selection listener.
For example, for a managed bean named chartDataSource and a method named selectionListener(), enter the following in the SelectionListener field:#{chartDataSource.selectionListener}.
You can also choose Edit from the SelectionListener attribute's dropdown menu to select a managed bean and method in the Edit Property: Selection Listener dialog, or choose Expression Builder to enter an expression that returns the selection listener.
Configure any additional elements as needed.
For example, to duplicate the multiple selection example in this section, add the af:outputText components shown in the first code sample in How to Configure Selection Support.
The process to add a popup or context menu is essentially the same. Add the af:showPopupBehavior tag as a child of one of the chart's data items, define the trigger type as click for popup menus or contextMenu for context menus, and add an af:popup containing the desired behavior to the page.
Figure 23-59 shows the pie chart displayed in Figure 23-41 configured for popup support. If the user clicks one of the pie slices, a note window pops up with a message.
Figure 23-59 Pie Chart Configured With a Note Window Popup
The example below shows the code on the page for the popup menu shown in Figure 23-59. In this example, the af:showPopupBehavior component uses the popupId to reference the af:popup component. The af:popup component is configured with the af:noteWindow component which is configured to display a simple message in the af:outputFormatted component. The triggerType of the af:showPopupBehavior tag is set to click, and the note window will launch when the user clicks one of the pie chart's slices.
<af:group id="g1">
  <dvt:pieChart id="chart1" value="#{chartDataSource.defaultPieData}"
                var="row" dataSelection="single">
    <dvt:chartLegend id="leg1" rendered="true"/>
    <dvt:pieDataItem label="#{row.series}" value="#{row.value}" id="pdi1">
      <af:showPopupBehavior popupId="::noteWindowPopup" triggerType="click"
                            align="afterStart"/>
    </dvt:pieDataItem>
  </dvt:pieChart>
  <af:popup childCreation="deferred" autoCancel="disabled"
            id="noteWindowPopup" clientComponent="true"
            launcherVar="source" eventContext="launcher">
    <af:noteWindow id="nw1">
      <af:outputFormatted value="This is an example of a chart popup" id="of1"/>
    </af:noteWindow>
  </af:popup>
</af:group>
You can change the popup to a context menu by simply changing the trigger type for the af:showPopupBehavior component to contextMenu as shown in the following code snippet:
<af:showPopupBehavior popupId="::noteWindowPopup" triggerType="contextMenu"/>
Before you begin:
Add a popup component to your page. For help with configuring the af:popup component, see Using Popup Dialogs, Menus, and Windows.
To add a popup or context menu to a chart:
You can configure your chart to include marquee zoom and scroll which permits the user to focus on an area of the chart or scroll through the data using the mouse. This feature can be useful for large data sets.
Figure 23-60 shows a bubble chart configured for marque zoom and scroll. The user can select an area on the chart and then release the mouse button to zoom in on the selected area. The user can also scroll the mouse wheel upward to zoom in on chart data. To restore the chart to its original display, the user can scroll the mouse wheel downward.
Figure 23-60 Bubble Chart Configured for Marquee Zoom and Scroll
To configure marque zoom and scroll, set a value for the chart's zoomAndScroll attribute.
Before you begin:
To configure marquee zoom and scroll:
In the Properties window, expand the Behavior section.
From the ZoomAndScroll dropdown list, select the desired zoom and scroll behavior. By default, this attribute is set to off. Available options include:
delayed: Specifies that the chart update will wait until the zoom or scroll action is done. Both zoom and scroll will be enabled.
Specify a delay if the chart display is slow to render.
delayedScrollOnly: Specifies that the chart update will wait until the scroll action is done. The marquee zoom icon will not be displayed.
live: Specifies that the chart will be updated continuously as it is being manipulated. Both zoom and scroll will be enabled.
liveScrollOnly: Specifies that the chart will be updated continuously as it is being manipulated. The marquee zoom icon will not be displayed.
You can also choose Expression Builder from the ZoomAndScroll attribute's dropdown menu to enter an expression that returns the zoom and scroll behavior.
You can add a viewport to the chart which uses a small form factor to display the entire data set, and then configure the original line chart to display a subset of the data.
Figure 23-61 shows the line chart in Figure 23-40 configured with an overview port. When the user zooms in on a chart area, the viewport changes to match the user's selection. The user can stretch or shrink the viewport dragging the handles on each side of the viewport.
Figure 23-61 Line Chart Configured With Overview
To configure an overview window, add the overview facet and overview window to the chart, and configure the chart's axis for the overview range.
Before you begin:
To add an overview window to your chart:
