Front and Rear Panel Components
Plan Communication With the Server Module During Installation
Optional Component Installation
Modular System Chassis Preparation
Insert the Server Module Into the Chassis
Communicating With the Server Module During Startup
Monitor the Diagnostic Messages
Powering On the Server Module for the First Time
Initial Power-On Task Overview
Power On the System for the First Time
Install Oracle Solaris Software From the Network
Oracle Solaris Configuration Settings
Assign a Static IP Address to the Service Processor
Understanding System Administration Resources
Platform-Specific Oracle ILOM Features
Oracle VM Server for SPARC Overview
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Display the Oracle ILOM -> Prompt
Reset the Server From the Oracle Solaris OS
Reset the Server From Oracle ILOM
Reset the SP to Default Values
Important Hardware RAID Guidelines
Disk Zones for SPARC T3-1 Servers With Sixteen-Disk Backplanes
Displaying Disk Zone Information
Disk Zone Status (zoningcli list)
Enabling and Disabling Disk Zoning In the Field
Enable Disk Zones (zoningcli Command)
Disable Disk Zones (zoningcli Command)
Update Firmware to Enable Zoning
Minimum System Firmware for Valid devalias in Upper Disk Locations
Prepare to Use the FCode Utility
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
Front Service Required Drive LEDs
Error Messages (System Console and Log Files)
Display Status (show-volumes Command, OBP)
Display Status (sas2ircu Utility, LSI)
RAID Drive Replacement Strategies
Changing Server Identification Information
Change Customer FRUdata Information
Change System Identifier Information
Restore Host Power State at Restart
Specify Host Power State at Restart
Disable or Re-Enable Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior With the Keyswitch State
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Using an In-band Connection to the SP
Configure the Host Boot Mode of Oracle VM Server for SPARC
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OpenBoot PROM Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Enabling Automatic System Recovery
Identifying WWN-Designated SAS2 Devices
probe-scsi-all Output Example (SPARC T3-1, Eight-Disk Backplane)
probe-scsi-all Output Example (SPARC T3-1, Sixteen-Disk Backplane)
probe-scsi-all Output Example (SPARC T3-4)
Identify a Disk Slot Using probe-scsi-all (OBP)
Identify a Disk Slot Using prtconf (Oracle Solaris, Onboard Controllers)
Identify a Disk Slot Using prtconf (Oracle Solaris, Single Initiator)
WWN Syntax in an OS Installation on a Specific Device
WWN Syntax in an OS Installation on a RAID Volume
Interpreting Log Files and System Messages
Managing Faults (Oracle Solaris PSH)
Checking if Oracle VTS Software Is Installed
Find the Modular System Serial Number
Find the Server Module Serial Number
Removing the Server Module From the Modular System for Service
Clear the Fault and Verify the Functionality of the Replacement DIMM
Servicing a Service Processor Card
Remove the Service Processor Card
Install the Service Processor Card
Replacing the Server Module Enclosure Assembly
Transfer Components to Another Enclosure Assembly
Returning the Server Module to Operation
The following probe-scsi-all output examples show the difference in how storage devices are listed when zoning is enabled and when it is disabled. There are 10 disks represented in both examples. They are identified as PhyNum 0-9.
Note - The entries for PhyNum 1-6 are omitted in these examples to reduce the size of the examples. The missing entries would not alter the illustration of the concept.
Zoning is disabled:
When zoning is disabled, each disk is visible to both controllers. The following example shows this by listing every disk with controller 0 and with controller 1.
Tip - Note that SASDeviceName and SASAddress for each PhyNum listed under controller 1 matches the corresponding PhyNum’s DeviceName and SASAddress listed under controller 0. This is true for PhyNum 1-6, which were omitted to reduce the size of the table.
{0} ok probe-scsi-all /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/hub@3/storage@2 Unit 0 Removable Read Only device AMI Virtual CDROM 1.00 /pci@400/pci@2/pci@0/pci@4/scsi@0 <==== Controller 1 FCode Version 1.00.56, MPT Version 2.00, Firmware Version 5.00.13.00 Target a Unit 0 Removable Read Only device TEAC DV-W28SS-R 1.0C SATA device PhyNum 6 Target b Unit 0 Disk SEAGATE ST930003SSUN300G 0868 585937500 Blocks, 300 GB SASDeviceName 5000c50017b0c14b SASAddress 5000c50017b0c149 PhyNum 0 [PhyNum 1-6 are omitted to conserve space.] Target 12 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d5c6a3 SASAddress 5000c50003d5c6a1 PhyNum 7 Target 13 Unit 0 Disk SEAGATE ST914603SSUN146G 0768 286739329 Blocks, 146 GB SASDeviceName 5000c50012ef2247 SASAddress 5000c50012ef2245 PhyNum 8 Target 14 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d49c77 SASAddress 5000c50003d49c75 PhyNum 9 Target 15 Unit 0 Encl Serv device SUN SAS2 X16DBP 0302 SASAddress 500605b0000272bd PhyNum 18 /pci@400/pci@1/pci@0/pci@4/scsi@0 <==== Controller 0 FCode Version 1.00.56, MPT Version 2.00, Firmware Version 5.00.13.00 Target a Unit 0 Disk SEAGATE ST930003SSUN300G 0868 585937500 Blocks, 300 GB SASDeviceName 5000c50017b0c14b SASAddress 5000c50017b0c149 PhyNum 0 [PhyNum 1-6 are omitted to conserve space.] Target 11 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d5c6a3 SASAddress 5000c50003d5c6a1 PhyNum 7 Target 12 Unit 0 Disk SEAGATE ST914603SSUN146G 0768 286739329 Blocks, 146 GB SASDeviceName 5000c50012ef2247 SASAddress 5000c50012ef2245 PhyNum 8 Target 13 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d49c77 SASAddress 5000c50003d49c75 PhyNum 9 Target 14 Unit 0 Encl Serv device SUN SAS2 X16DBP 0302 SASAddress 500605b0000272bd PhyNum 18 {0} ok
Zoning is enabled:
In the following example, zoning is enabled and each disk is shown connected to a single SAS-2 controller. PhyNum 0-7 are connected to controller 0 and PhyNum 8-9 are connected to controller 1.
{0} ok probe-scsi-all /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/hub@3/storage@2 Unit 0 Removable Read Only device AMI Virtual CDROM 1.00 /pci@400/pci@2/pci@0/pci@4/scsi@0 <==== Controller 1 FCode Version 1.00.56, MPT Version 2.00, Firmware Version 5.00.13.00 Target a Unit 0 Disk SEAGATE ST914603SSUN146G 0768 286739329 Blocks, 146 GB SASDeviceName 5000c50012ef2247 SASAddress 5000c50012ef2245 PhyNum 8 Target b Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d49c77 SASAddress 5000c50003d49c75 PhyNum 9 Target c Unit 0 Encl Serv device SUN SAS2 X16DBP 0305 SASAddress 50800200000272bd PhyNum 18 Target d Unit 0 Removable Read Only device TEAC DV-W28SS-R 1.0C SATA device PhyNum 6 /pci@400/pci@1/pci@0/pci@4/scsi@0 <==== Controller 0 Target a Unit 0 Disk SEAGATE ST930003SSUN300G 0868 585937500 Blocks, 300 GB SASDeviceName 5000c50017b0c14b SASAddress 5000c50017b0c149 PhyNum 0 [PhyNum 1-6 are omitted to conserve space.] Target 11 Unit 0 Disk SEAGATE ST973402SSUN72G 0400 143374738 Blocks, 73 GB SASDeviceName 5000c50003d5c6a3 SASAddress 5000c50003d5c6a1 PhyNum 7 Target 12 Unit 0 Encl Serv device SUN SAS2 X16DBP 0305 SASAddress 50800200000272bd PhyNum 18 {0} ok
