Skip Navigation Links
Exit Print View
Netra SPARC T3-1B Server Module HTML Document Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Feedback
Support and Accessibility
Installation
Planning the Installation
Shipping Kit Inventory List
Features
Specifications
Site Planning
Preinstalled Software
Front and Rear Panel Components
Server Module Cabling
Plan Communication With the Server Module During Installation
Installing the Server Module
Handling Precautions
ESD Precautions
Tools Needed for Installation
Optional Component Installation
Modular System Chassis Preparation
Insert the Server Module Into the Chassis
Communicating With the Server Module During Startup
Monitor the Diagnostic Messages
Powering On the Server Module for the First Time
Initial Power-On Task Overview
Power On the System for the First Time
Configure the System
Install Oracle Solaris Software From the Network
Oracle Solaris Configuration Settings
Assign a Static IP Address to the Service Processor
Administration
Understanding System Administration Resources
Oracle ILOM Overview
Platform-Specific Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle VM Server for SPARC Overview
Multipathing Software
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Accessing the Server
Log In to Oracle ILOM
Log In to the System Console
Display the ok Prompt
Display the Oracle ILOM -> Prompt
Use a Local Graphics Monitor
Oracle ILOM Remote Console
Controlling the Server
Power On the Server
Power Off the Server
Reset the Server From the Oracle Solaris OS
Reset the Server From Oracle ILOM
Reset the SP to Default Values
Configuring Hardware RAID
Hardware RAID Support
Important Hardware RAID Guidelines
Disk Zones for SPARC T3-1 Servers With Sixteen-Disk Backplanes
Displaying Disk Zone Information
Disk Zone Status (zoningcli list)
Disk Zone Status (probe-scsi-all)
Enabling and Disabling Disk Zoning In the Field
Enable Disk Zones (zoningcli Command)
Disable Disk Zones (zoningcli Command)
Update Firmware to Enable Zoning
Minimum System Firmware for Valid devalias in Upper Disk Locations
Prepare to Use the FCode Utility
FCode Utility Commands
Create a Hardware RAID Volume
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
Front Service Required Drive LEDs
Error Messages (System Console and Log Files)
Display Status (show-volumes Command, OBP)
Display Status (sas2ircu Utility, LSI)
RAID Drive Replacement Strategies
Locate Device Paths
Changing Server Identification Information
Change Customer FRUdata Information
Change System Identifier Information
Configuring Policy Settings
Specify Cooldown Mode
Restore Host Power State at Restart
Specify Host Power State at Restart
Disable or Re-Enable Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior With the Keyswitch State
Configuring Network Addresses
SP Network Address Options
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the Host MAC Address
Using an In-band Connection to the SP
Configuring Boot Mode
Boot Mode Overview
Configure the Host Boot Mode of Oracle VM Server for SPARC
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OpenBoot PROM Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Set the Boot Timeout Interval
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Configuring Devices
Unconfigure a Device Manually
Reconfigure a Device Manually
Monitoring the Server
Monitoring Faults
Enabling Automatic System Recovery
Display Server Components
Locate the Server
Updating the Firmware
Display the Firmware Version
Update the Firmware
Display OpenBoot Version
Display POST Version
Identifying WWN-Designated SAS2 Devices
World Wide Name Syntax
probe-scsi-all Output Example (SPARC T3-1, Eight-Disk Backplane)
probe-scsi-all Output Example (SPARC T3-1, Sixteen-Disk Backplane)
probe-scsi-all Output Example (SPARC T3-4)
Identify a Disk Slot Using probe-scsi-all (OBP)
Identify a Disk Slot Using prtconf (Oracle Solaris, Onboard Controllers)
Identify a Disk Slot Using prtconf (Oracle Solaris, Single Initiator)
WWN Syntax in an OS Installation on a Specific Device
WWN Syntax in an OS Installation on a RAID Volume
Service
Identifying Components
Illustrated Parts Breakdown
Detecting and Managing Faults
Diagnostics Overview
Diagnostics Process
Diagnostics LEDs
Managing Faults (Oracle ILOM)
Interpreting Log Files and System Messages
Managing Faults (Oracle Solaris PSH)
Managing Faults (POST)
Managing Components (ASR)
Checking if Oracle VTS Software Is Installed
Preparing for Service
General Safety Information
Tools Needed for Service
Find the Modular System Serial Number
Find the Server Module Serial Number
Locate the Server Module
Removing the Server Module From the Modular System for Service
Servicing Hard Drives
Drive Hot-Plugging Rules
Remove a Drive
Replace or Add a Drive
Remove a Drive Filler
Install a Drive Filler
Servicing Memory
Memory Faults
Locate a Faulty DIMM (LEDs)
Remove a DIMM
Install a Replacement DIMM
Clear the Fault and Verify the Functionality of the Replacement DIMM
Verify DIMM Functionality
DIMM Configuration Reference
Servicing a REM
Remove a REM
Install a REM
Servicing a FEM
Remove a FEM
Install a FEM
Servicing a Service Processor Card
Remove the Service Processor Card
Install the Service Processor Card
Servicing the ID PROM
Remove the ID PROM
Install the ID PROM
Verify the ID PROM
Servicing a USB Flash Drive
Remove a USB Flash Drive
Install a USB Flash Drive
Servicing the Battery
Replace the Battery
Replacing the Server Module Enclosure Assembly
Transfer Components to Another Enclosure Assembly
Returning the Server Module to Operation
Replace the Cover
Install the Server Module Into the Modular System
Start the Server Module Host
Glossary
Index
Locate Device Paths
Use this procedure to locate device paths specific to your server.
  1. Display the ok prompt.
    See Display the ok Prompt.
  2. From the ok prompt, type:
    {0} ok devalias
    screen                  /pci@400/pci@2/pci@0/pci@0/pci@0/display@0
    mouse                   /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/device@4
    /mouse@1
    rcdrom                   /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/hub@3
    /storage@2/disk@0
    rkeyboard                /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/device@4
    /keyboard@0
    rscreen                  /pci@400/pci@2/pci@0/pci@0/pci@0/display@0:r1280x1024x60
    net3                     /pci@400/pci@2/pci@0/pci@7/network@0,1
    net2                     /pci@400/pci@2/pci@0/pci@7/network@0
    net1                     /pci@400/pci@2/pci@0/pci@6/network@0,1
    net0                     /pci@400/pci@2/pci@0/pci@6/network@0
    net                      /pci@400/pci@2/pci@0/pci@6/network@0
    disk7                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p3
    disk6                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p2
    disk5                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p1
    disk4                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p0
    cdrom                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p6
    scsi1                    /pci@400/pci@2/pci@0/pci@4/scsi@0
    disk3                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p3
    disk2                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p2
    disk1                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p1
    disk0                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p0
    disk                     /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p0
    scsi0                    /pci@400/pci@1/pci@0/pci@4/scsi@0
    scsi                     /pci@400/pci@1/pci@0/pci@4/scsi@0
    virtual-console          /virtual-devices@100/console@1
    name                     aliases
    {0} ok
Related Information
