Skip Navigation Links | |
Exit Print View | |
Sun Dual 10 GbE PCIe 2.0 Fibre Channel Over Ethernet Software User's Guide |
Understanding the FCoE Software
Installation Overview (Windows)
Enabling the FCoE Software (Linux)
Enable FCoE During the Linux Installation
Enable FCoE After a Linux Installation
Resolve SAN-Boot Errors (RHEL6.0/OL6.0)
Remove the FCoE Software Package (Linux)
Installing the FCoE Software (Windows)
Upgrade Guidelines for Software Release 15.4 (Windows)
Validation and Storage Certification
Download and Install the Driver (Windows)
Verify the Functionality of the Network Interface
Boot Over a 10GbE Network (Linux)
Set Up the FCoE Boot Option ROM (Windows)
Configure the Cisco Nexus 5000 Series Switch
Configure the Brocade 8000 Series Switch
Configuring Driver Parameters (Linux)
Driver Parameter Settings (Linux)
This guide provides software installation instructions for the Fibre Channel Over Ethernet (FCoE) software for Oracle's Sun Dual 10GbE PCIe 2.0 adapters. This guide also describes how to configure the FCoE software for the Linux and Microsoft Windows Server operating systems. ixgbe is the name of the driver for the Intel 82599-based devices.
These instructions are designed for enterprise system administrators with experience installing network hardware and software.
Note - In this guide, the term “x86” refers to 64-bit and 32-bit systems manufactured using processors compatible with the AMD64, Intel Xeon, or Intel Pentium product families.
The following topics are included in this section:
For late-breaking information and known issues about this product, refer to the product notes at:
http://www.oracle.com/pls/topic/lookup?ctx=E25048-01
Provide feedback on this documentation at:
http://www.oracle.com/goto/docfeedback
