Skip Navigation Links | |
Exit Print View | |
Sun Dual 10 GbE PCIe 2.0 Fibre Channel Over Ethernet Software User's Guide |
Understanding the FCoE Software
Installation Overview (Windows)
Enabling the FCoE Software (Linux)
Enable FCoE During the Linux Installation
Enable FCoE After a Linux Installation
Remove the FCoE Software Package (Linux)
Installing the FCoE Software (Windows)
Upgrade Guidelines for Software Release 15.4 (Windows)
Validation and Storage Certification
Download and Install the Driver (Windows)
Verify the Functionality of the Network Interface
Boot Over a 10GbE Network (Linux)
Set Up the FCoE Boot Option ROM (Windows)
Configure the Cisco Nexus 5000 Series Switch
Configure the Brocade 8000 Series Switch
Configuring Driver Parameters (Linux)
Driver Parameter Settings (Linux)
The Red Hat Enterprise Linux 6.0 or Oracle Linux 6.0 instance on an external volume might not boot properly after the installation because of a mismatch in the /etc/fstab values.
/dev/mapper/vg_ai4270m21-lv_home /home ext4 defaults,_netdev 1 2 UUID=dce3bd61-ed1c-4538-96b6-e16f91881a09 /boot ext4 defaults,_netdev 1 2
/dev/mapper/vg_ai4270m21-lv_home /home ext4 defaults,_netdev 0 0 UUID=dce3bd61-ed1c-4538-96b6-e16f91881a09 /boot ext4 defaults,_netdev 0 0
