Skip Navigation Links | |
Exit Print View | |
Sun Dual 10 GbE PCIe 2.0 Fibre Channel Over Ethernet Software User's Guide |
Understanding the FCoE Software
Installation Overview (Windows)
Enabling the FCoE Software (Linux)
Enable FCoE After a Linux Installation
Resolve SAN-Boot Errors (RHEL6.0/OL6.0)
Remove the FCoE Software Package (Linux)
Installing the FCoE Software (Windows)
Upgrade Guidelines for Software Release 15.4 (Windows)
Validation and Storage Certification
Download and Install the Driver (Windows)
Verify the Functionality of the Network Interface
Boot Over a 10GbE Network (Linux)
Set Up the FCoE Boot Option ROM (Windows)
Configure the Cisco Nexus 5000 Series Switch
Configure the Brocade 8000 Series Switch
Configuring Driver Parameters (Linux)
Driver Parameter Settings (Linux)
For the SLES 11 SP2 OS, select the open-fcoe file and the YaST-fcoe-client packages.
For all other Linux operating systems, select the open-fcoe file.
