Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 3.2.x
Exit Print View
Updated: April 2018
Log Properties
Property
Description
Applicable to:
Event ID
Unique number used to identify the encountered event.
  • System Log
  • Event Log
  • Audit Log
Date and Time
Day and time the event occurred. If the Network Time Protocol (NTP) server is enabled to set the Oracle ILOM time, the Oracle ILOM clock uses Universal Coordinated Time (UTC).
For more information about time stamps, see Log Time Stamps .
  • System Log
  • Event Log
  • Audit Log
Event Type or Type
Hardware dependent event property.
Event type examples:
  • IPMI
  • UI
  • Upgrade
  • Persistence
  • Action or Service Required
  • Warning
  • OK
  • System Log
  • Event Log
  • Audit Log
Subsystem
Hardware dependent property that identifies the subsystem where the event was encountered.
Subsystem examples:
  • System
  • Power
  • Cooling
  • Memory
  • Storage
  • I/O module
  • Processor
  • Blade
  • DCU
  • Firmware
  • System Log
Component
Hardware dependent property that identifies the component where the event was encountered.
Component examples:
  • BLn (Blade n)
  • Hostn
  • /SYS (Host System)
  • CMUn (Processor Board n)
  • DCUn
  • PSn (Power Supply n)
  • Fann (Fan n)
  • Diskn
  • ILOM
  • System Log
Class
Hardware dependent property that identifies the event class.
Class examples:
  • Audit/ Log – For commands that result in a configuration change. Description includes user, command, command parameters, and success/failure.
  • IPMI/Log – For any event that is recorded in the IPMI SEL is also put in the management log.
  • Chassis/State – For changes to the inventory and general system state.
  • Chassis/Action – For shutdown events for server module/chassis, hot insert/removal of FRU components, as well as Reset Parameters button when pushed.
  • Fault/Fault – Description gives the time fault was detected and the suspect component name.
  • Fault/Repair – For Fault Management repairs. Description gives component name.
  • Event Log
  • Audit Log
Severity
Severity level of the event.
Severity examples:
  • Debug
  • Down
  • Critical
  • Major
  • Minor
  • Event Log
  • Audit Log
