Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 3.2.x
Exit Print View
Updated: April 2018
Network Deployment Tasks and Applicable CLI Targets
Use the following table to help identify the applicable CLI namespace targets for Oracle ILOM network deployment tasks.
The following table does not provide the full CLI path to the /SP target on all managed devices. For instance, to access the /SP target from either a multi-domain SPARC server, a blade system CMM, or a Netra FMM, append the applicable CLI properties to the beginning of the /SP target:
  • SPARC multi-domain server, where applicable, append: /Servers/PDomains/PDomain_n
  • Blade system CMM, where applicable, append: /Servers/Blades/Blade_n
  • Netra frame system FMM, where applicable, append: /Servers/ComputeNodes/ComputeNode_n
Note -  Not all network deployment CLI targets are supported on all managed devices. Use the help command to view the namespace targets supported on a managed device. For example,
help /SP/network/services | help /CMM/network/services | help /FMM/network/services
For additional information about modifying default network deployment properties in Oracle ILOM, see the topics listed in the Related Information section that appears after the table.
CLI Properties on Managed Device
User Role Required
View or modify the network management service properties on the server SP, CMM, or FMM.
/SP |CMM |FMM/services
  • /http
  • /https
  • /ssh
    • generate_ new_ key_ type
    • generate_ new_ key_ action
  • /sso
  • /fips
    /ipmi
    /snmp
  • Admin (a)
View or modify the CLI session time-out property on the server SP, CMM, or FMM.
/SP|CMM|FMM/cli
  • timeout
  • legacy_targets
Admin (a)
View or terminate user sessions on server SP, CMM, or FMM.
/SP|CMM|FMM/sessions
Admin (a) for Delete operations
View or set the system identification information on the server SP, CMM, or FMM.
/SP|CMM|FMM
  • hostname
  • system_contact
  • system_description
  • system_location
Admin (a)
Create and display banner messages on the server SP, CMM, or FMM.
/SP|CMM|FMM/preferences/banner
  • connect
  • login
Admin (a)
View or modify the Oracle ILOM date and time properties on the server SP, CMM, or FMM.
/SP|CMM|FMM/clock
  • datetime
  • timezone
  • usentpserver
    Note -  usentpserver requires the network time protocol service to be enabled (see Manage the Network Time Protocol Service in this table).
Admin (a)
View or set the network time protocol service property on the server SP, CMM, or FMM.
/SP|CMM|FMM/clients/ntp/server
  • /1 address
  • /2 address
Admin (a)
Related Information
