Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 3.2.x
Exit Print View
Updated: April 2018
Host Serial Console Session Tasks and Applicable CLI Target
Use the following table to help identify the applicable CLI namespace targets for starting or ending a host serial console session.
Note -  This feature is for text-only serial console redirection. For remote graphical console redirection from Oracle ILOM , use the applicable remote system console (Oracle ILOM Remote System Console or Oracle ILOM Remote System Console Plus).
Host Serial Console Tasks
CLI Properties on Managed Device
User Role Required
View, start, or stop a remote serial host console session.
/HOST/console
  • bootlog
  • history
  • start
  • stop
  • show
Note -  Host console properties vary from system to system. Use the Help command to determine which host console properties are supported on your server. For example: help /HOST/console
Note -  To issue the full CLI path for host console from a multi-domain SPARC server, append /Servers/PDomains/PDomain_n to the beginning of the /HOST/console target.
Note -  To issue the full CLI path for host console from the CMM, append /Servers/Blades/Blade_n to the beginning of the /HOST/console target.
Note -  To issue the full CLI path for host console from the FMM, append /Servers/ComputeNodes/ComputeNode_n to the beginning of the /HOST/console target.
  • Console (c)
Related Information
