Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 3.2.x
Exit Print View
Updated: April 2018
Launch a Fault Management Shell Session (CLI)
Before You Begin
  • Admin (a) role privileges are required to launch the Fault Management Shell from the Oracle ILOM CLI.
To launch the Oracle ILOM Fault Management Shell, from the Oracle ILOM CLI, do the following:
  1. From the Oracle ILOM CLI, type the following command to launch the Oracle ILOM Fault Management Shell:
    start /SP|CMM/faultmgmt/shell
    One of the following Fault Management Shell command prompts appears:
    • faultmgmtsp> appears for Oracle SP managed devices.
    • faultmgmtcmm> appears for Oracle CMM managed devices.
    Note - After you start the Fault Management Shell and until you exit the Fault Management Shell, you can issue only commands that are specific to the Fault Management Shell.
  2. Issue any of the following Fault Management Shell commands:
  3. To display help information for a Fault Management Shell command, type:
    help command
    where command can be one of the following:
    • fmadm
    • fmdump
    • fmstat
  4. To exit the Fault Management Shell, at the faultmgmt prompt, type:
    exit
    Note - To issue standard Oracle ILOM CLI commands, you must first exit the Fault Management Shell.
Related Information
