ナビゲーションリンクをスキップ | |
印刷ビューの終了 | |
マニュアルページセクション 1: ユーザーコマンド Oracle Solaris 11.1 Information Library (日本語) |
- ask for help regarding SCCS error or warning messages
/usr/bin/sccshelp [argument]...
The sccs-help utility retrieves information to further explain errors messages and warnings from SCCS commands. It also provides some information about SCCS command usage. If no arguments are given, sccs-help prompts for one.
An argument may be a message number (which normally appears in parentheses following each SCCS error or warning message), or an SCCS command name. sccs-help responds with an explanation of the message or a usage line for the command.
When all else fails, try /usr/bin/sccshelp stuck.
directory containing files of message text
sccs(1), sccs-admin(1), sccs-cdc(1), sccs-comb(1), sccs-delta(1), sccs-get(1), sccs-prs(1), sccs-prt(1), sccs-rmdel(1), sccs-sact(1), sccs-sccsdiff(1), sccs-unget(1), sccs-val(1), what(1), sccsfile(4), attributes(5)
