Go to main content
Oracle® Server X6-2 Service Manual
Exit Print View
Updated: January 2021
Install the Battery
  1. Unpack the replacement battery.
  2. Press the new battery into the battery retainer with the positive side (+) facing up.
  3. If there was a PCIe card installed in the PCIe riser slot 2, reinstall it.
    See Install a PCIe Riser Into PCIe Slot 1 or 2
  4. Return the server to operation.
    1. Install the server top cover.
      See Install the Server Top Cover.
    2. Close the fan door.
    3. Return the server to the normal rack position.
      See Return the Server to the Normal Rack Position.
    4. Reconnect the power cords to the server power supplies and reconnect the data cables.
      See Reconnect Data Cables and Power Cords.
    5. Power on the server.
      See Power On the Server.
      Verify that the Power/OK status indicator is steady on.
    Note -  If the service processor is configured to synchronize with a network time server using the Network Time Protocol (NTP), the Oracle ILOM clock will be reset as soon as the server is powered on and connected to the network; otherwise, proceed to the next step.
  5. If the service processor is not configured to use NTP, do one of the following:
    • Reset the Oracle ILOM clock using the Oracle ILOM CLI or the web interface.
      For instructions, refer to the Oracle Integrated Lights Out Manager (ILOM) 5.0 Documentation Library at https://www.oracle.com/goto/ilom/docs.
    • Use the BIOS Setup Utility to reprogram the host clock.
      For the BIOS Main menu screen that supports this procedure, refer to the Oracle X6 Series Servers Administration Guide at https://www.oracle.com/goto/x86admindiag/docs.
