The following components can be serviced with the server in the maintenance position:
Storage drives
Fan modules
Power supplies
DVD drive module
PCIe risers
PCIe cards and cables
SAS cables
NVMe cables
DIMMs
Internal USB flash drives
Motherboard battery
Processors
Disk backplane
FIM (front indicator module)
Motherboard
If the server is installed in a rack with extendable slide-rails, use this procedure to extend the server to the maintenance position.
Caution - To reduce the risk of personal injury, stabilize the expansion rack cabinet and extend all anti-tilt devices before extending the server from the rack. |
For instructions for stabilizing the rack, see the Stabilize the Rack for Installation in Oracle Server X6-2 Installation Guide.
Although the cable management arm (CMA) that is supplied with the server is hinged to accommodate extending the server, you should ensure that all cables and cords are capable of extending.
When in an open position, the release latch covers engage the slide-rail release latches [frame 1].
The server is now in the extended maintenance position. .
