Go to main content
Sun Storage 6 Gb SAS PCIe HBA, Internal Installation Guide For HBA Models SGX-SAS6-INT-Z and SG-SAS6-INT-Z
Exit Print View
Updated: May 2017
Removing the HBA
If you need to remove the HBA from the system, for any reason, follow the procedure in this section.
To Remove the HBA:
  1. Prepare your operating system for HBA removal.
  2. Attach an antistatic wrist strap.
    See Observing ESD and Handling Precautions.
  3. Turn off the power to the system, all drives, enclosures, and system components.
  4. Refer to the service manual for your specific system to locate the HBA in the chassis of the system.
  5. Unscrew the bracket screw securing the HBA to the system, if applicable, or disengage the system retention mechanism that is securing the HBA to the system.
  6. Pull up on the HBA to unseat it from the PCI Express slot.
  7. Refer to the service manual for your specific system to reattach the cover to the system.
