Skip Navigation Links
Exit Print View
StorageTek 8 Gb FC PCIe HBA From QLogic Installation Guide
For HBA Models SG-XPCIE1FC-QF8-Z, SG-PCIE1FC-QF8-Z, SG-XPCIE1FC-QF8-N, SG-PCIE1FC-QF8-N and SG-XPCIE2-QF8-Z, SG-PCIE2FC-QF8-Z, SG-XPCIE2-QF8-N, SG-PCIE2FC-QF8-N, 7106958, 7106957
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Chapter 3 Software Installation
Installing Software for the Oracle Solaris OS
Installing the Fibre Channel Driver
To Install or Update the qlc HBA Driver From a Patch
Diagnostic Support for the Oracle Solaris OS
Installing Software for the Red Hat/SUSE Linux OS
Downloading the Red Hat/SUSE Linux Drivers
To Download the Fibre Channel Driver
Installing the Red Hat/SUSE Linux Drivers
To Install and Load the Red Hat/SUSE Linux Drivers
To Build the Fibre Channel Driver
To Load the Newly Built Fibre Channel Driver
To Manually Load the Fibre Channel Driver
To Automatically Load the Fibre Channel Driver
Diagnostic Support for the Red Hat/SUSE OS
To Install Diagnostic Support for the Red Hat/SUSE Linux OS
Installing Software for the VMware Technology
Installing Software for the Windows OS
To Install the Fibre Channel Driver
Diagnostic Support for the Windows OS
To Install Diagnostic Support for the Windows OS
Installing a CLI for Updating the BIOS and FCode
Chapter 4 Known Issues
The qlc HBA driver for the Solaris OS is included with the Oracle Solaris 10 01/13 and the Oracle Solaris 11.1 OSes (or later). You must load the latest qlc driver by installing the appropriate platform patches and SRUs:
You can download these patches and SRUs at:
http://support.oracle.com
  1. Log in as the root user.
  2. Navigate to the directory that contains the patch.
  3. Add the latest patch by using the patchadd command.
    # patchadd patch-number
