Skip Navigation Links
Exit Print View
StorageTek 8 Gb FC PCIe HBA From QLogic Installation Guide
For HBA Models SG-XPCIE1FC-QF8-Z, SG-PCIE1FC-QF8-Z, SG-XPCIE1FC-QF8-N, SG-PCIE1FC-QF8-N and SG-XPCIE2-QF8-Z, SG-PCIE2FC-QF8-Z, SG-XPCIE2-QF8-N, SG-PCIE2FC-QF8-N, 7106958, 7106957
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Chapter 3 Software Installation
Installing Software for the Oracle Solaris OS
Installing the Fibre Channel Driver
To Install or Update the qlc HBA Driver From a Patch
Diagnostic Support for the Oracle Solaris OS
Installing Software for the Red Hat/SUSE Linux OS
Downloading the Red Hat/SUSE Linux Drivers
To Download the Fibre Channel Driver
Installing the Red Hat/SUSE Linux Drivers
To Install and Load the Red Hat/SUSE Linux Drivers
To Build the Fibre Channel Driver
To Load the Newly Built Fibre Channel Driver
To Manually Load the Fibre Channel Driver
To Automatically Load the Fibre Channel Driver
Diagnostic Support for the Red Hat/SUSE OS
To Install Diagnostic Support for the Red Hat/SUSE Linux OS
Installing Software for the VMware Technology
Installing Software for the Windows OS
To Install the Fibre Channel Driver
Diagnostic Support for the Windows OS
To Install Diagnostic Support for the Windows OS
Installing a CLI for Updating the BIOS and FCode
Chapter 4 Known Issues
Diagnostic support for the HBA is available through the SANsurfer PRO graphical user interface (GUI) utility or the SANsurfer command-line interface (CLI) utility. These utilities support the following functions:
  1. Go to the QLogic support site for Oracle at:
    http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
  2. Locate the table containing the HBA model that you want (SG-model-number).
  3. At the bottom of the table, click Windows.
  4. Locate the SANsurfer CLI (command-line interface) or SANsurfer PRO (GUI) diagnostic utility.
  5. Click Download to copy diagnostic archive to a local file system.
  6. Click Readme link for additional information.
