Chapter 2 Hardware Installation and Removal
Chapter 3 Software Installation
Installing Software for the Oracle Solaris OS
Installing the Fibre Channel Driver
To Install or Update the qlc HBA Driver From a Patch
Installing Software for the Red Hat/SUSE Linux OS
Downloading the Red Hat/SUSE Linux Drivers
To Download the Fibre Channel Driver
Installing the Red Hat/SUSE Linux Drivers
To Install and Load the Red Hat/SUSE Linux Drivers
To Build the Fibre Channel Driver
To Load the Newly Built Fibre Channel Driver
To Manually Load the Fibre Channel Driver
To Automatically Load the Fibre Channel Driver
Diagnostic Support for the Red Hat/SUSE OS
To Install Diagnostic Support for the Red Hat/SUSE Linux OS
Installing Software for the VMware Technology
Installing Software for the Windows OS
To Install the Fibre Channel Driver
Diagnostic Support for the Windows OS
To Install Diagnostic Support for the Windows OS
Diagnostic support for the HBA is included in the Oracle VTS software. The Oracle VTS software is available for download at: http://support.oracle.com/
For information about the Oracle VTS software, see the Oracle VTS documentation at: http://docs.oracle.com/cd/E19719-01/index.html
The qlctest utility, which is provided as part of the Oracle VTS software, supports the following functions:
Connectivity verification
Firmware version and checksum testing
Self-testing
Loopback tests
External
Internal, single-bit
Internal, 10-bit
Mailbox
