Chapter 2 Hardware Installation and Removal
Chapter 3 Software Installation
Installing Software for the Oracle Solaris OS
Installing the Fibre Channel Driver
To Install or Update the qlc HBA Driver From a Patch
Diagnostic Support for the Oracle Solaris OS
Installing Software for the Red Hat/SUSE Linux OS
Downloading the Red Hat/SUSE Linux Drivers
To Download the Fibre Channel Driver
Installing the Red Hat/SUSE Linux Drivers
To Install and Load the Red Hat/SUSE Linux Drivers
To Build the Fibre Channel Driver
To Load the Newly Built Fibre Channel Driver
To Manually Load the Fibre Channel Driver
To Automatically Load the Fibre Channel Driver
Diagnostic Support for the Red Hat/SUSE OS
To Install Diagnostic Support for the Red Hat/SUSE Linux OS
Installing Software for the Windows OS
To Install the Fibre Channel Driver
Diagnostic Support for the Windows OS
To Install Diagnostic Support for the Windows OS
The HBA drivers included on the VMware distribution are sufficient for supporting the HBA. No further action is required.
To verify that the drivers loaded successfully, look for the following lines in the /var/log/vmkernel file:
Initialization for qla2300_707_vmw succeeded with module ID 2. [timestamp] b12-4600a vmkernel: 0:00:01:18.878 cpu1:1041)qla2300_707_vmw loaded successfully.
The first line indicates that the fibre channel driver loaded successfully.
