Chapter 2 Hardware Installation and Removal
Chapter 3 Software Installation
Installing Software for the Oracle Solaris OS
Installing the Fibre Channel Driver
To Install or Update the qlc HBA Driver From a Patch
Diagnostic Support for the Oracle Solaris OS
Installing Software for the Red Hat/SUSE Linux OS
Downloading the Red Hat/SUSE Linux Drivers
To Download the Fibre Channel Driver
To Load the Newly Built Fibre Channel Driver
To Manually Load the Fibre Channel Driver
To Automatically Load the Fibre Channel Driver
Diagnostic Support for the Red Hat/SUSE OS
To Install Diagnostic Support for the Red Hat/SUSE Linux OS
Installing Software for the VMware Technology
Installing Software for the Windows OS
To Install the Fibre Channel Driver
Diagnostic Support for the Windows OS
To Install Diagnostic Support for the Windows OS
After you download the drivers, as described in Downloading the Red Hat/SUSE Linux Drivers, you can install the drivers by following the steps in this section:
The driver installation makes extensive use of the build.sh script, which is located in driver source (extras/build.sh).
From the source code, you can build a qla2xxx.ko module and a qla2xxx_conf.ko module for the host. You can then choose to load the driver manually or automatically, as described in To Load the Newly Built Fibre Channel Driver.
# tar -xvzf *.tgz # cd qlogic # ./drvrsetup (this extracts the source files directory into the current directory) # cd qla2xxx-x.yy.zz (x.yy indicates the driver version; zz indicates the file extension, which is typically .ko for kernel modules (binaries)).
# ./extras/build.sh install
This build script does the following:
