Skip Navigation Links
Exit Print View
StorageTek 8 Gb FC PCIe HBA From QLogic Installation Guide
For HBA Models SG-XPCIE1FC-QF8-Z, SG-PCIE1FC-QF8-Z, SG-XPCIE1FC-QF8-N, SG-PCIE1FC-QF8-N and SG-XPCIE2-QF8-Z, SG-PCIE2FC-QF8-Z, SG-XPCIE2-QF8-N, SG-PCIE2FC-QF8-N, 7106958, 7106957
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Chapter 3 Software Installation
Installing Software for the Oracle Solaris OS
Installing the Fibre Channel Driver
To Install or Update the qlc HBA Driver From a Patch
Diagnostic Support for the Oracle Solaris OS
Installing Software for the Red Hat/SUSE Linux OS
Downloading the Red Hat/SUSE Linux Drivers
To Download the Fibre Channel Driver
Installing the Red Hat/SUSE Linux Drivers
To Install and Load the Red Hat/SUSE Linux Drivers
To Build the Fibre Channel Driver
To Load the Newly Built Fibre Channel Driver
To Manually Load the Fibre Channel Driver
To Automatically Load the Fibre Channel Driver
Diagnostic Support for the Red Hat/SUSE OS
To Install Diagnostic Support for the Red Hat/SUSE Linux OS
Installing Software for the VMware Technology
Installing Software for the Windows OS
To Install the Fibre Channel Driver
Diagnostic Support for the Windows OS
To Install Diagnostic Support for the Windows OS
Installing a CLI for Updating the BIOS and FCode
Chapter 4 Known Issues
If you need to update the fibre channel BIOS and FCode, you can do so by using the SANsurfer command-line interface (CLI).
If you have not done so already, you can download the SANsurfer CLI package from the QLogic support site for Oracle at:
http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
Follow the installation instructions in the README.TXT file. Installation instructions are also available in the QLogic document, SANsurfer FC HBA CLI User's Guide (SN0054614-00), which can be found on the QLogic web site, http://www.qlogic.com.
For instructions on how to update the BIOS and FCode, see the SANsurfer FC HBA CLI User's Guide at the QLogic web site.
