oracle home
Oracle
Solaris 11.2 Desktop User's Guide
Exit Print View
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Solaris 11.2 Information Library
Oracle
Solaris 11.2 Desktop ...
Updated: July 2014
Language:
English
Oracle
July 2014
Describes how to use the Oracle Solaris Desktop and its components.
Document Information
Using This Documentation
How This Book Is Organized
Product Documentation Library
Access to Oracle Support
Feedback
1 Getting Started With the Desktop
Overview of the Desktop
Desktop Components
Desktop Sessions
Starting a Session
How to Log In to the Desktop
How to Use a Different Language
How to Use a Different Keyboard Layout
Locking the Screen
Setting Programs to Start Automatically When You Log In
About the Startup Programs Tab
Enabling/Disabling Startup Programs
How to Add a New Startup Program
Removing a Startup Program
Editing a Startup Program
About the Options Tab
Ending a Session
2 Using the Desktop Windows
Windows Overview
Types of Windows
Working With Windows
Moving a Window
Resizing a Window
How to Resize a Window
Minimizing a Window
Maximizing a Window
Unmaximizing a Window
Closing a Window
Giving Focus to a Window
3 Using the Desktop Workspaces
Workspaces Overview
Working With Workspaces
Switching Workspaces
Adding and Deleting Workspaces
How to Add Workspaces
How to Delete Workspaces
4 Using the Desktop Panels
Panel Overview
Top Edge Panel
Bottom Edge Panel
Managing Panels
Moving a Panel
Hiding a Panel
Adding a New Panel
Deleting a Panel
Setting Panel Properties
About the General Properties Tab
About the Background Properties Tab
Managing Panel Objects
Interacting With Panel Objects
Selecting an Applet
Adding an Object to a Panel
How to Add an Object to a Panel
Modifying the Properties of an Object
How to Modify the Properties of an Object
Moving a Panel Object
How to Move a Panel Object
Locking a Panel Object
Removing a Panel Object
Applets
Launchers
Adding a Launcher to a Panel
How to A dd a Launcher to a Panel From the Panel Pop-up Menu
How to Add a Launcher to a Panel From a Menu
How to Add a Launcher to a Panel From the File Manager
Modifying a Launcher
How to Modify the Launcher Properties
Launcher Properties
Launcher Commands and Locations
Buttons
Force Quit
Lock Screen
Log Out
Run
Search for Files
Show Desktop
Menus
How to Add a Menubar or Main Menu to a Panel
How to Add a Submenu to a Panel
Drawers
How to Add a Menu as a Drawer to a Panel
How to Add an Object to a Drawer
How to Modify Drawer Properties
Panel Objects
Menubar
Window Selector Applet
Notification Area Applet
Window List
Usage
Preferences
Command Assistant Applet
5 Using the Desktop Applications
Applications Overview
Working With Files
Opening a File
Filtering the File List
Choosing a Folder
Opening a Location
Opening Remote Locations
Adding and Removing Bookmarks
Showing Hidden Files
Saving a File
Saving a File in Another Location
Replacing an Existing File
Creating a Folder
6 Using the Main Menubar
About the Main Menubar
About the Applications Menu
How to Start an Application
Using the Places Menu
Using the System Menu
Using the Administration Menu
Customizing the Panel Menubar
How to Edit Menus
7 Using Time Slider
Time Slider Preferences Pane
Enabling and Disabling the Time Slider Service
How to Enable Time Slider
How to Disable Time Slider
Working with Time Slider Snapshots
Managing Snapshots Using Time Slider
How to Delete an Existing Snapshot From Time Slider
How to Change the Storage Space Available to Snapshots
How to Choose a Specific ZFS File System to Snapshot
How to Replicate Snapshots to an External Storage Device
Managing Snapshots From a File Manager
How to View the Available Snapshots in File Manager
How to View the Previous Version of a File or Folder
How to Compare Versions of a File or Folder
How to Restore a Previous Version of a File
How to Take a Manual Snapshot
How to Delete a Snapshot From a File Manager
8 Using the File Manager
File Manager Overview
Spatial Mode
Spatial Mode Windows
Displaying the Home Folder in a Spatial Window
Displaying a Parent Folder
Displaying a Folder in a Browser Window
How to Display a Folder in a Browser Window
Closing Folders
Opening a Location
Browser Mode
Browser Windows
Showing and Hiding File Browser Window Components
Using the Location Bar
Displaying Home Folder
Displaying a Folder
Using the Tree From the Side Pane
Using Navigation History
Navigating History List Using the Go Menu
Navigating History List Using the Toolbar
Navigating Your History List Using History in the Side Pane
Opening Files
Executing the Default Action
Executing Non-Default Actions
How to Add Actions Associated With a File Type
How to Modify Actions
Searching Files
Saving Searches
Managing Files and Folders
Using Views to Display Files and Folders
Arranging Your Files in Icon View
Arranging Your Files in List View
Changing the Size of Items in a View
Working With Files and Folders
Selecting Files and Folders
Selecting Files Matching a Specific Pattern
Moving or Copying a File or Folder
How to Drag a File to Copy or Move It to a New Location
How to Cut or Copy and Paste to the New Location
How to Duplicate a File or Folder
How to Create a Folder
How to Rename a File or Folder
How to Move a File or Folder to the Trash
How to Delete a File or Folder
Creating a Symbolic Link to a File or Folder
How to Create a Symbolic Link to a File or Folder
Using Drag and Drop
Viewing the Properties of a File or Folder
How to View the Properties of a File of Folder
Changing Permissions
How to Change Permissions for a File
How to Change Permissions for a Folder
Adding Notes to Files and Folders
How to Add a Note Using the Properties Dialog
How to Add a Note Using Notes in the Side Pane
Creating Documents by Using a Template
How to Create a Document From a Template
Using Bookmarks
Adding or Deleting a Bookmark
How to Edit a Bookmark
Using Trash
Displaying the Items in the Trash
Emptying Trash
Viewing Hidden Files
Hiding a File or Folder
Using Item Properties
How to Display the Item Properties Window
Modifying the Appearance of Files and Folders
Using Icons and Emblems
How to Change the Icon for a File or Folder
How to Add an Emblem to a File or Folder
How to Create a New Emblem
Changing Backgrounds
How to Change the Background of a Window, Pane, or Panel
Using Removable Media
Mounting Media
How to Mount a Device Manually
Displaying Media Contents
Displaying Media Properties
Ejecting Media
How to Eject a USB Flash Drive
Navigating Remote Servers
Accessing a Remote Server
Accessing Network Places
Accessing Special URI Locations
Setting File Manager Preferences
Views
Behavior
Display
List Columns
Preview
Media
Extending the File Manager
Scripts
Installing File Manager Scripts
Writing File Manager Scripts
Extensions
9 Using the Desktop Tools and Utilities
Running Applications
How to Run an Application From the Command Line
Taking Screenshots
Overview of the Yelp Help Browser
Yelp Help Browser Interface
Working With Yelp
How to Open a Document Through the GUI
Searching Documents
How to Search in a Current Page
How to Search Indexed Documents
How to Open a New Window
How to Display Information About a DocBook Document
How to Print the Current Page
How to Print a Docbook Document
How to Close a Window
How to Set Preferences
How to Add a Bookmark
How to Edit Bookmarks
How to Display Help
Navigating the Yelp Help Browser
Opening Documents from the Command Line
10 Configuring the Desktop
About Preference Tools
Assistive Technologies
Keyboard Shortcuts
How to Add a Custom Shortcut
How to Edit a Keyboard Shortcut
Preferred Applications
Setting Look and Feel Preferences
Appearance
Theme Preferences
How to Create a Custom Theme
How to Install a New Theme
How to Delete a Theme Option
Desktop Background Preferences
Font Preferences
How to Choose Fonts
Font Rendering
Visual Effects
How to Enable and Configure a Customized Set of Visual Effects
Show Icons in Menus
Editable Menu Shortcut Keys
Toolbar Button Labels
Windows
Screensaver
Setting Screensaver Preferences
Setting Default Screensaver Preferences for All Users
Restoring Default Screensaver Settings for a User
Modifying Screensaver Preferences
Modifying Look and Feel of Your Screensaver
How to Add a Screensaver Display
Disabling a Screensaver Display
Setting Internet and Network Preferences
Network
Network Proxy
Desktop Sharing
Setting Keyboard Preferences
Keyboard
General
Layouts
Keyboard Layout Options
Accessibility
Audio Feedback
Mouse Keys
Typing Break
Input Method Selector
How to Activate or Deactivate IM
Setting Hardware Preferences
Monitor Preference Tool
Sound Preference Tool
Playback Preferences
Recording Preferences
Sound Theme Preferences
Application Sound Preferences
Setting Session Preferences
Configuring Startup Applications
Appendix A Using the Mouse
Mouse Button Conventions
Mouse Preference Tool
General Mouse Preferences
Mouse Accessibility Preferences
Mouse Pointers
Appendix B Using the Keyboard
Global Shortcut Keys
Window Shortcut Keys
Application Keys
Access Keys
