man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
box(3CURSES)
Name
curs_border, border, wborder, box, whline, wvline - create curses borders, horizontal and vertical lines
Synopsis
cc [ flag ... ] file ... –lcurses [ library ... ]
#include <curses.h>
int border(chtype ls, chtype rs, chtype ts, chtype bs, chtype tl,
     chtype tr, chtype bl,chtype br);
int wborder(WINDOW *win, chtype ls, chtype rs, chtype ts,
     chtype bs, chtype tl, chtype tr, chtype bl, chtype br);
int box(WINDOW *win, chtype verch, chtype horch);
int hline(chtype ch, int n);
int whline(WINDOW *win, chtype ch, int n);
int vline(chtype ch, int n);
int wvline(WINDOW *win, chtype ch, int n);
Description
With the border(), wborder(), and box() routines, a border is drawn around the edges of the window. The arguments and attributes are:
ls
left side of the border
rs
right side of the border
ts
top side of the border
bs
bottom side of the border
tl
top left-hand corner
tr
top right-hand corner
bl
bottom left-hand corner
br
bottom right-hand corner
If any of these arguments is zero, then the following default values (defined in <curses.h>) are used respectively instead: ACS_VLINE, ACS_VLINE, ACS_HLINE, ACS_HLINE, ACS_ULCORNER, ACS_URCORNER, ACS_BLCORNER, ACS_BRCORNER.
box(win, verch, horch) is a shorthand for the following call:
wborder(win, verch, verch, horch, horch , 0, 0, 0, 0)
hline() and whline() draw a horizontal (left to right) line using ch starting at the current cursor position in the window. The current cursor position is not changed. The line is at most n characters long, or as many as fit into the window.
vline() and wvline() draw a vertical (top to bottom) line using ch starting at the current cursor position in the window. The current cursor position is not changed. The line is at most n characters long, or as many as fit into the window.
Return Values
All routines return the integer OK, or a non-negative integer if immedok() is set. See curs_outopts(3CURSES).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curs_outopts(3CURSES), curses(3CURSES), attributes(5)
Notes
The header <curses.h> automatically includes the headers <stdio.h> and <unctrl.h>.
Note that border() and box() may be macros.
