man pages section 3: Curses Library Functions
Exit Print View
Updated: July 2014
delay_output(3CURSES)
Name
curs_util, unctrl, keyname, filter, use_env, putwin, getwin, delay_output, flushinp - curses miscellaneous utility routines
Synopsis
cc [ flag ... ] file ... –lcurses [ library ... ]
#include <curses.h>
char *unctrl(chtype c);
char *keyname(int c);
int filter(void);
void use_env(char bool);
int putwin(WINDOW *win, FILE *filep);
WINDOW *getwin(FILE *filep);
int delay_output(int ms);
int flushinp(void);
Description
The unctrl() macro expands to a character string which is a printable representation of the character c. Control characters are displayed in the ^X notation. Printing characters are displayed as is.
With the keyname() routine, a character string corresponding to the key c is returned.
The filter() routine, if used, is called before initscr() or newterm() are called. It makes curses think that there is a one-line screen. curses does not use any terminal capabilities that assume that they know on what line of the screen the cursor is positioned.
The use_env() routine, if used, is called before initscr() or newterm() are called. When called with FALSE as an argument, the values of lines and columns specified in the terminfo database will be used, even if environment variables LINES and COLUMNS (used by default) are set, or if curses is running in a window (in which case default behavior would be to use the window size if LINES and COLUMNS are not set).
With the putwin() routine, all data associated with window win is written into the file to which filep points. This information can be later retrieved using the getwin() function.
The getwin() routine reads window related data stored in the file by putwin(). The routine then creates and initializes a new window using that data. It returns a pointer to the new window.
The delay_output() routine inserts an ms millisecond pause in output. This routine should not be used extensively because padding characters are used rather than a CPU pause.
The flushinp() routine throws away any typeahead that has been typed by the user and has not yet been read by the program.
Return Values
Except for flushinp(), routines that return an integer return ERR upon failure and an integer value other than ERR upon successful completion.
flushinp() always returns OK.
Routines that return pointers return NULL on error.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
curs_initscr(3CURSES), curs_scr_dump(3CURSES), curses(3CURSES), attributes(5)
Notes
The header <curses.h> automatically includes the headers <stdio.h> and <unctrl.h>.
Note that unctrl() is a macro, which is defined in <unctrl.h>.
